Like Tree81Likes
Old 11-07-2011, 12:36 PM   #16096
monkeyracing's Avatar
A heads up for those of you who might order the Tamiya rear aluminum damper stay mount (54326) to replace the fragile kit part. RC Mart and a a few other sites fail to mention that you need the carbon damper stay (54300) to go with it.
The plastic kit part can be made to work with judicious use of a Dremel, but it'll make you grouchy and covered with plastic dust. Not me, though. I'm a flippin' ray of sunshine.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-07-2011, 05:31 PM   #16097
clayrace24's Avatar
Trader Rating: 42 (100%+)
Default 3Racing fast gears for M05
I was wondering if any of the guys racing at West Coast RC are using the 3Racing gearset that allows taller gearing options for the M05 Pro. I got a set and was looking for feedback on perfoirmance prior to use.
Thanks,
Clay
B44.3,Tamiya M05 Mini Cooper and lots of airplanes
clayrace24 is offline   Reply With Quote
Old 11-07-2011, 06:13 PM   #16098
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
Looking for a nice clean M03, M03R or M05 pro for my sons birthday. Anyone have a clean one they want to part with drop me a PM.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 11-07-2011, 06:51 PM   #16099
Thanks,
Clay
They're illegal. WCRC Tuesday mini races are tcs spec gearing(20t pinion) and stock spur/trans gears. 3 racing aluminum bling parts (steering rack, uprights, heat sinks, etc...)are ok.
nytryder is offline   Reply With Quote
Old 11-07-2011, 09:14 PM   #16100
hanzo3's Avatar
Trader Rating: 55 (100%+)
I need help with my M05 pro. Want to run it at TQraceway and WCRC. Ball diff or spool? 60D tires or sweeps? I am using savox 1251. How much steering travel for the mini?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 11-07-2011, 09:33 PM   #16101
gtfour93's Avatar
Trader Rating: 22 (100%+)
There was a NIB M-05 Pro in the FS section not too long ago.
gtfour93 is offline   Reply With Quote
Old 11-07-2011, 11:40 PM   #16102
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
My 1968 Mini will be on display at the LA Auto show at the CarDomain booth..
Just got picked!!
akura2 is offline   Reply With Quote
Old 11-08-2011, 08:38 AM   #16103
kaiser's Avatar
i just wanted to pop in and say hi.
i've had my mo3 mini for a couple of years but have only run it in the street. my main thing up until now has always beed 2wd mod buggy, but my local shop is now running a carpet oval on thursday evenings and i'm trying to get a mini class going.
i've read through rc-mini.net, what a wealth of knowledge.
i'm going to start with a black can and a teu-101 esc, some 60d's and a new body and go from there.
vintage for life! Jrx2/JrxPro/RC10/RC10ce/RC10 graphite/RC10 oin/RC10T/RC10T2/RCPS sprinter/Optima x2/Scorpion/too many old tamiya's to list
RCHR.biz
kaiser is offline   Reply With Quote
Old 11-08-2011, 09:03 AM   #16104
sweep 40's and 33's are good for tq and wcrc. Tires for west coast are a never ending challenge becsause the grip levels change drastically from practice to race time. Lately I have had pretty good success there with the Ride "inch up" tires/wheels, but having all 4 compounds can get pricey. sweeps are smaller diameter so you lose a little top speed on the long straight at west coast but they work good on the infield.
Ta03 ball diff with ceramic bearings is the ticket, build per instructions.
I set my steering up for maximum throw without driveshaft binding(suggest running Tamiya cv's instead of the stock dogbone setup) and use my radio to trim back epa and speed as needed.
Old 11-08-2011, 10:47 AM   #16105
Also, Minis are sensitive to your driving style. I'm super aggressive so my set up may not fit you at all. I rarely will drive other peoples cars, cause they feel too "twitchy" for me. However, with that being said, the Mini set up at WCR defies conventional logic. Set your car up soft in front and stiffer in the rear for the spring rates. Put your ride height down on the deck. Other than that, you'll need to experiment to find something that fits you.
Granpa is offline   Reply With Quote
Old 11-08-2011, 11:33 AM   #16106
Y'know, I dislike NASCAR and most other forms of oval racing, but running minis on an oval is a blast. We've run oval night several times this year and it never fails to entertain.
Stab it and steer.
Old 11-08-2011, 11:55 AM   #16107
hanzo3's Avatar
The m05 I got used came with a spool. When would a spool be good to use for a mini? Anyone know where I can get a tao3 ball diff locally in socal?
Chris TRF419 TA05V2
Old 11-08-2011, 12:37 PM   #16108
kaiser's Avatar
i can't stand most forms of circle track, except for dirt oval. but racing a mini on any track is fun.
RCHR.biz
Old 11-08-2011, 01:26 PM   #16109
kaiser's Avatar
what kind of tires would you guys run on carpet?
i got a set of m-grips and hard inserts on the way.
i also have a pair of ride slicks on the front currently, but after reading through rc-mini i figured m-grips to be a good starting point.
RCHR.biz
Old 11-08-2011, 01:57 PM   #16110
I usually run a harder front/softer rear combo as is usually suggested. I've found when running oval it's best to have a little understeer, as I generally keep it pinned all the way around. If you let off a little the front end will still bite and get you around. Be sure to rotate tire l-r between races. Also, watch out, because the outside tires are going to get grabby at around 4 minutes!
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
