Like Tree2Likes
Old 10-05-2011, 03:54 PM   #15946
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by k_bojar View Post
nevermind, found the rules had to go thru the link on the 2011 NA finals
I feel your pain! I don't like that roll cage either
T-Sal
gashuffer is offline   Reply With Quote
Old 10-05-2011, 03:55 PM   #15947
gashuffer's Avatar
Originally Posted by monkeyracing View Post
Anyone have a link to the Japanese rules? I'm interested to see how a series that demands factory parts, right down to the screws, could allow chopping the chassis to pieces.
Because no matter what they're are those that are secret squirrels.
T-Sal
Old 10-05-2011, 04:11 PM   #15948
monkeyracing's Avatar
You lost me. Easy to do, especially if you're nuts!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-05-2011, 04:21 PM   #15949
gashuffer's Avatar
You refer to Teching, tearing down cars, No? I simply mean that there are those who like to cheat at any possible chance they can. Hence "secret squirrel".
What are you talking about?
T-Sal
Old 10-05-2011, 04:27 PM   #15950
Squirrel -> nut.
Yep, there are loads of people looking for any advantage possible, no matter what.
Stab it and steer.
Old 10-05-2011, 04:54 PM   #15951
gashuffer's Avatar
Nice one.
T-Sal
Old 10-05-2011, 06:57 PM   #15952
frank b's Avatar
Need help....
Best pack for the mini m05 looking for 4000 mah lipo with hi c rating....
frank b is offline   Reply With Quote
Old 10-05-2011, 08:54 PM   #15953
tony gray's Avatar
Unless you're using some super low turn motor you dont need a high C rating in a Mini...
tony gray is offline   Reply With Quote
Old 10-05-2011, 08:57 PM   #15954
Tp3200 40C (208grams) is all you need baby .....
bertrandsv87 is offline   Reply With Quote
Old 10-06-2011, 11:47 AM   #15955
Default M05 PRO S-Spec
whats so great about the M05 PRO S-Spec kit?
if i was to order this car would it be a good car to start with?
is it worth the extra moola?
hotrod306 is offline   Reply With Quote
Old 10-06-2011, 01:27 PM   #15956
I started with it, paid $200 for it. If I had to do it over, I'd just get the pro.
http://www.tamiyausa.com/product/ite...oduct-id=58443
The S-Spec has an aluminum rear suspension mount with 1 degree of toe built in, so with the 1.5 degree hubs you get a total of 2.5 degrees of toe.
http://www.tamiyausa.com/product/ite...oduct-id=84204
With that plate you're also limited to the short wheelbase bodies, so you can only mount 210mm wheelbase bodies. Tamiya, HPI, and ABC all make nice bodies at 210mm.
You can build the kit with the included plastic rear suspension mounts which will give you the ability to run medium or long wheelbase, but at that point, you might as well just buy an M05 Pro.
Aside from that, it has black abs plastic shocks which I feel are an upgrade from the clear blue units.
Feijai is offline   Reply With Quote
Old 10-06-2011, 05:46 PM   #15957
Default M05 Kits (Standard or Pro)
Need some help getting over the line choosing between the M05 and M05PRO kits, also Include the newer M05S-SPEC TRF kit as well as reading previous pages a member said it was better value.
I know the exact differences but is it better to just get a new and good cheap M05 kit and upgrade only the parts you really need or do the people in the know (Veteran Racers) just get the M05 PRO and be done with it.
Looking at racing in Victoria some time soon, i just want the common sense approach so driver skill is more important than throwing money around.
What has confused me is that over at rc-mini.net they canned the clear shocks and thought i better just get the standard kit and get the right parts slowly rather than start throwing things out out of box.
flexsta is offline   Reply With Quote
Old 10-06-2011, 06:41 PM   #15958
GasGod's Avatar
Pro comes w/bearings.no body- I got the swift kit w/esc(couldn't wait for the Mugen CRX), added bearings.Itwas $112 all together shipped
need ta order front tower-$12 ,got shocks for free--thanks Tom--
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 10-06-2011, 07:45 PM   #15959
Just wondering if anyone ever had to replace the the TA03 ball diff due to wear on the gear? Is there a replacement gear only available?
stocker is offline   Reply With Quote
Old 10-07-2011, 04:24 AM   #15960
sosidge's Avatar
There's not much in it. Depends on prices to an extent.
If you already have a body and electrics then a Pro (or preferably S-spec) is the obvious choice.
If not, then a standard kit is OK (especially if your races specify the Tamiya motor), but bear in mind that you WILL end up replacing a lot of the parts with the Pro/S-spec ones. IMHO an M-05 needs oil shocks, short springs, upgraded steering posts, upgraded servo saver, bearings and a ball diff before you even think about putting it on a track. The S-spec has all those parts (except the ball diff) and a bit more besides.
I bought a standard kit but if I had my time again I would buy an S-spec and a ball diff (plus the obvious body, tyres and electrics) and be confident I had a good racer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
