Like Tree4Likes
Old 09-23-2011, 11:33 AM   #15811
jsinclair's Avatar
I just put my m-05 together last night. The speed control has a low voltage cut off to protect "LF" batteries, what is a "LF" batt? And what voltage cut off is it set up for? Thanks
jsinclair is offline   Reply With Quote
Old 09-23-2011, 11:46 AM   #15812
jcr
LF stands for LiFe batteries. Haven't figure out what the cut off voltage is at.
jcr is offline   Reply With Quote
Old 09-23-2011, 12:49 PM   #15813
sosidge's Avatar
Originally Posted by jcr View Post
Are you sure it is 66.5mm? That seems kind of long.
I built up the Super Mini CVA with 3mm spacer and got 56mm total length.
Sorry, I meant 56.5.
Old 09-23-2011, 01:02 PM   #15814
jsinclair's Avatar
Ill figure it out tonight, and post my results here. My charger has a motor drive function, and ill just keep dropping the voltage until it cuts out.
Old 09-23-2011, 04:41 PM   #15815
monkeyracing's Avatar
The lowest voltage recommended for LiFe is 2.4v per cell.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-24-2011, 10:12 PM   #15816
clayrace24's Avatar
Trader Rating: 40 (100%+)
Default Mini Motors /esc question
I just put a stock Johnson motor in my M05 Pro after running it on a 17.5 and the dropoff in speed is significant. I'm running a really cheap futaba esc, but have a Sphere and a Cyclone I couild use if I choose to. Should it make any difference at all in punch to run a better controller? Been a while since I ran a brushed motor. Is it still recommended to do the water dip treatment on a new Johnson motor?
Clay
B44.3,Tamiya M05 Mini Cooper and lots of airplanes
clayrace24 is offline   Reply With Quote
Old 09-24-2011, 10:23 PM   #15817
clayrace24's Avatar
Is anyone using the rear sway bar on the long chassis setup? I can't figure out how to get it to work due to the position of the shocks in the long setup. Help is appreciated.
Clay
Old 09-24-2011, 11:18 PM   #15818
jcr
Clay
On another note what Esc is good for silver can? Is the stock tamiya teu 104bk good enough?
Old 09-24-2011, 11:28 PM   #15819
Unless you're running at a very competitive level - national or international - the stock ESC will do the job just fine. I've seen more than a few guys with the old stock 101BK easily win against others running Tekins, Novaks, LRPs, etc. You might find more adjustments in a higher end ESC, like drag brakes, but the stock one will do fine.
As for motors, we've just started running controlled 17.5T/2200kv motors at our club. They match the top speed of a good silver can quite well, but definitely pull harder out of the corners. Is this what you're experiencing, or is it an actual loss of top speed?
Jim
Stab it and steer.
Old 09-25-2011, 01:18 AM   #15820
caltek1's Avatar
Trader Rating: 33 (100%+)
Default Swaybar MO5L
See attached pictures for the rear swaybar on a MO5L. I do not use a front swaybar only on the rear. I also find at some tracks that it not useful, so I just disconnect one of the rear supports.
BTW,
Car setup has changed since these pictures.
Calvin.
Tamiya mini cooper-dsc_0282.jpg   Tamiya mini cooper-dsc_0278.jpg   Tamiya mini cooper-dsc_0280.jpg
caltek1 is offline   Reply With Quote
Old 09-25-2011, 01:59 AM   #15821
clayrace24's Avatar
Both punch and top speed are noticeably less. The motor I put in was previosly used and I know nothing of it's history. I have a brand new one that I'm going to put in next and see how that goes.
Thanks for the input .
Clay
Old 09-25-2011, 03:17 AM   #15822
caltek1's Avatar
Default Latest Incarnation of my MO5L
A couple of dirty pictures of my MO5 LWB after racing. Certainly needs a clean.
Tamiya mini cooper-dsc_0567.jpg   Tamiya mini cooper-dsc_0574.jpg   Tamiya mini cooper-dsc_0576.jpg   Tamiya mini cooper-dsc_0575.jpg   Tamiya mini cooper-dsc_0578.jpg
Old 09-25-2011, 03:44 AM   #15823
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Cal, that's a disgustingly dirty car for a photo shoot
Interesting Lipo pack you got there what is it?
I'm sick and tired of buying Lipo's that get pregnant and I have to throw away!
Question: What causes this swellage and is this one you have any better?
P.S I treat my Lipo's with the utmost respect, charge them at a sensible rate & don't short circuit them, what's going on is it just me?
www.tamiyarcmini.com ..............Check out my new web page
"Remember when all else fails stick to the gunuine Tamiya parts because you could of saved heaps!"
Mr_Gleeman is offline   Reply With Quote
Old 09-25-2011, 04:06 AM   #15824
caltek1's Avatar
John,
It's like its owner, dirty.
The Lipo is a LRP 4600 30C. These are not cheap. I got one to try and have been happy with it, although the IP3800 is very popular and will be the next batteries I get for mini.
I don't balance my packs and I don't touch them after racing. Just leave them until the next week and top up when i get to the track.
My batteries get a workout as I practice normally once a week and race twice a week when I'm home. Other than that they get left for periods of up to a month were they stay in the Lipo sack.
I have only had problems with swelling packs in Touring Car and the old 4000 IP Lipo packs. I must add that I thoroughly abused those packs and still have a couple I use for practice. These I would run to cutoff, which I had set at 3.8 volts per cell. This certainly hurts the batteries as they do not last as long. They are soon destined for greenier pastures.
BTW,
I have cleaned the car, ready for tomorrow night, providing the rain disappears and the sun comes out.
Later,
Calvin.
Old 09-25-2011, 09:02 AM   #15825
YankeeFan123's Avatar
Trader Rating: 30 (100%+)
If anyone has a body that will go on a m03 that has the longer wheelbase, already painted or not and they would sellit,as long as itdoesnt have any cracksplease PM me
Brenden Edwards
B5M| T5M
YankeeFan123 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
daktulos, shmit 1
