Like Tree23Likes
Old 08-31-2011, 02:27 PM   #15586
YankeeFan123's Avatar
Trader Rating: 30 (100%+)
Originally Posted by evilancer View Post
I decided to try the mini class of racing, found this M05 pro for sale locally. It came with pretty much every single upgrade Tamiya makes, plus alot of extra tires, used and brand new, a new unpainted Fiat Abarth body, ESC, servo, extra motors, lots of spare parts!
It also came with an extra ball diff, is this a TA03 ball differential?
Jon
Sweet ride! Im not sure. You gotta wait until someone else who knows a little more to answer your question.
Brenden Edwards
B5M| T5M
YankeeFan123 is offline   Reply With Quote
Old 08-31-2011, 03:21 PM   #15587
monkeyracing's Avatar
It appears to be the TA03 diff with hardened outdrives. Good stuff!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 09-01-2011, 12:06 AM   #15588
Sith Lord's Avatar
Trader Rating: 21 (100%+)
I can see a few upgrades you don't have......
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 09-01-2011, 05:50 PM   #15589
Whoooo! BL mini is here! In case you're wondering about why we spec'd 2200kv instead of 3300kv, the following quote applies "When a mini is running within a second a lap of touring stock, we have a problem." The hotted up silver cans were running in that neighbourhood.
We run shorter tracks, indoors, on carpet and we're tryng to make the class entry level again. The HW 13T was way too much motor for our needs.
Anyway, enjoy some RC porn!
Stab it and steer.
Old 09-01-2011, 06:07 PM   #15590
flat4's Avatar
Send a message via Yahoo to flat4
that's great to hear, you wouldn't mind sharing chassis setup? (by the way nice to know other people race an MO6)
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 09-01-2011, 07:28 PM   #15591
Chassis is set up pretty much per instructions, with kit tires on front and S grips on back. Using the 54000 dampers with 35wt all around. Rear set to 54mm, fronts 55-56mm. I do have the front upright that allows the dampers to be stood up as well.
All the alloy bits are more for durability than anything else. It's a rough class!
Stab it and steer.
Old 09-01-2011, 09:17 PM   #15592
Madulla's Avatar
Gotta love using a $100 Soldering Iron for a $90 complete brushless setup. I can't wait for the weekend. I wish it was Sunday right now.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 09-01-2011, 09:24 PM   #15593
cannon's Avatar
Trader Rating: 35 (100%+)
The point you miss with the HW 13T (3000kv) motor is that it is a 380 size motor and with the Tamiya maximum 20t pinion setup it is not that fast
Enjoy your choice. BL Mini racing is good
I hope ORCA continue to support the motor in the future.
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-01-2011, 09:55 PM   #15594
Fluffy622's Avatar
So what kind of speeds are you getting out of your HW 13t BL setup? I also race on a small, indoor, carpet track and I don't want it to go to much faster than a good silver can.
HobbyTown USA SFSD~Team Associated TC6.1 VTA~Futaba~Savox~Novak~HPI Racimg
I'M NOT FAT.....IM FLUFFY!!!
Fluffy622 is offline   Reply With Quote
Old 09-01-2011, 10:02 PM   #15595
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
My new shell.
Team Losi Malaysia
Upgrade Rc
James khoo is offline   Reply With Quote
Old 09-01-2011, 10:14 PM   #15596
The HW 13T is equivalent to either a really good silver can, or about the same as a black can. The primary difference would be torque, lots of torque. Pretty dang zippy and really good bang for the buck.
Stab it and steer.
Old 09-01-2011, 10:30 PM   #15597
James khoo's Avatar
Do anyone have the hard cup joint part number for TA03 diff? It this the part number #53217?
Please let me know,TQ.
J
Team Losi Malaysia
Upgrade Rc
Old 09-01-2011, 11:02 PM   #15598
Smile
Originally Posted by sipaboy View Post
Who has some setup tips and what mods you did. TCS mod tips which work or what setups are popular. More concerned on M03 or M04.
After you have thrown out the standard tyres, motor, battery, springs, plastic steering gear. This is what you need. I have won a few races and bee second, third many times. Lipo battery, brushless motor & speedy, blue springs front, red rear. Long wheel base is better for longer tracks. Tyres front are Ride 3035 with hard insert. Rear are Ride 3020 (cool days, Cross on hot days. Ride height 1-2mm off ground. Toe in 1.5mm rear and toe out on front by a few mm. Use hop up aluminium parts wherever you can afford. Good luck, I've given up so if you are interested, I am selling mine (0407225064)
flyingman55 is offline   Reply With Quote
Old 09-02-2011, 03:09 AM   #15599
J
yup, I'm running those. Compatible with TA03 and Manta Ray ball diff.
cheapskate.brok is offline   Reply With Quote
Old 09-02-2011, 11:35 AM   #15600
flat4's Avatar
Default noob question...
Being new to mini's I am not sure what parts cross over from one chassis to anther. So my question is what rear hub carrier's will fit on a MO6? I bent one of mine this morning while practicing.
Also how strong are the rear arms on the mini's/Mo6, I know the the force of impact will go some where on this chassis, would getting aluminum hub carriers just cause some thing else to break that would take longer to fix/repair?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
