Like Tree173Likes
Old 08-27-2011, 08:56 PM   #15541
M03 bumper will have to be custom fitted, because I need the body to also fit with no mods whatsoever !!!!
bertrandsv87 is offline   Reply With Quote
Old 08-27-2011, 09:24 PM   #15542
monkeyracing's Avatar
Has anyone seen results from the first day of racing at the TCS finals? Really curious to see how things have been affected by the new, very strict, handout motor rules in the mini class.
FYI, for this race they've set up a handout system where you go to pre-tech, get a motor, install it right there and race. After the race the car is impounded and you uninstall the motor at post-tech. No oil, motor spray or comm drops allowed. Stock bullet connectors and wire...wow. Should make things interesting. The fast guys will still be the fast guys, but the rest of the field might tighten up.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-27-2011, 10:34 PM   #15543
Too much control !!!!! Control esc / tire sauce ???? Maybe they should all run the same bodies , same radio settings , same servos, etc......
Old 08-27-2011, 10:44 PM   #15544
Fluffy622's Avatar
Yeah wow that much control is CRAZY! Isn't part of the sport and fun being able to tune your car and hopefully get the edge over your buddy? Or just being bored and curious and wanting to play with your car? That's a lot of freedom being taken away.
Fluffy622 is offline   Reply With Quote
Old 08-27-2011, 11:11 PM   #15545
It's about spec racing. I support the move wholeheartedly.
Stab it and steer.
Old 08-28-2011, 09:15 AM   #15546
justchris's Avatar
Originally Posted by scoop View Post
Just spend some time on www.rc-mini.net
All will be revealed
Many thanks !!!!!!!!!
TC6 Savox ] TC6.1 Sanwa ]
XL 5.9 Optifuel] M11X 2.4G ] 6000 IP lipo
justchris is offline   Reply With Quote
Old 08-28-2011, 10:30 AM   #15547
Zac_with_no_K's Avatar
Can anyone please help me out with this?
If I use short springs that are smaller than the stock springs, do I need to use a bunch of those clip on spacers so the shock isn't compressed at all?
I'll be using my stock Tamiya TA05 oil filled shocks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 08-28-2011, 10:49 AM   #15548
MD
MD's Avatar
Trader Rating: 113 (100%+)
You need to put spacers inside the shock to limit the travel.
MD is offline   Reply With Quote
Old 08-28-2011, 12:21 PM   #15549
Thank you MD, that really makes a lot more sense.
What type of spacers would I use? Do I put them at the bottom, under the shock piston?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-28-2011, 01:33 PM   #15550
MD
MD's Avatar
I put then under the piston. I've used rubber "o" rings or plastic spacers, just so they're the same thickness. I'm sure other drivers have ideas.
Old 08-28-2011, 02:58 PM   #15551
Oh okay. I know I have some left over o rings. I'm guessing you only need to use 2 or 3 of them?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-28-2011, 03:06 PM   #15552
MD
MD's Avatar
I think you can start with two on one shock and then adjust from there. It might take three.
Old 08-28-2011, 03:09 PM   #15553
From memory three front and two back but then you have to put the front shock back together a different way because there is so little travel left in the piston that you can no longer slide in the spring platform! Lol
scoop is offline   Reply With Quote
Old 08-28-2011, 03:32 PM   #15554
Can't wait to get started on that!
Thanks MD and Scoop
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-28-2011, 08:02 PM   #15555
2 orings is as far as you can go. I had 3~4 pieces before and after 3 packs (crashes included ), the oring somehow lost a little bit of its elasticity and stretched causing unequal shock length. Plastic spacers are the way to go
cheapskate.brok is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
