Like Tree51Likes
Old 08-25-2011, 04:24 PM   #15511
Firefox's Avatar
Originally Posted by tony gray View Post
You cant compare them directly like that. The H/W 13T is a 380 size can so the number of turns relative to the 'normal' brushless is different.
Will a larger size motor fit the M05 ?
Let me restate the question, what size brushless motors fit the M05 chassis ?
And what would be equivalent brushless motor to the HW 13T motor in a larger size ?
thanks
Tamiya M05, Associated SC10.
Firefox is offline   Reply With Quote
Old 08-25-2011, 04:50 PM   #15512
tony gray's Avatar
I'll put it another way.
The H/W is a 380 rotor inside, but the physical size of the motor (due to the cooling fins) is the same as any normal 540 brushless. So, an M05 will take any normal 540 sized brushless.
There is no direct comparative motor that I know of. Some people say 21.5, some say 17.5. But then the ESC factor and boost etc comes into it.
tony gray is offline   Reply With Quote
Old 08-25-2011, 09:16 PM   #15513
Originally Posted by Firefox View Post
Personally, I'd like to see HK selling a 17.5T (and 21.5T) version of the 13T motor.
Hobbywing has a 17.5t large rotor ezrun motor. I've run the 13.5t and it's got less top end than the 13t finned can motor. It has more torque though and ran cooler.
Sydewynder is offline   Reply With Quote
Old 08-26-2011, 03:55 AM   #15514
Tim K's Avatar
Originally Posted by nytryder View Post
Quick question....I hate the chatter that the stock axles make on my m05. I was thinking about getting the spec-R (double jointed)cvd's, however they are kind of pricey. Are the less expensive (single jointed) cv's good enough, or should I spend the extra dough on the spec-R's?
Run the Tamiya 53597, they're a good solid uni. I briefly sold and used the Spec R cvd's. Yes they eliminate wheel chatter and smooth out the drive train, but if you hit anything or roll over there is a good chance they will break. I had a number of complaints about them. One racer simply swapped from a diff to a spool and the stress was enough to break them. I can't comment on the Yeah Racing brand as I haven't used them.
Tim K is offline   Reply With Quote
Old 08-26-2011, 04:27 AM   #15515
cannon's Avatar
Trader Rating: 35 (100%+)
Tim
The Yeah Racing ones seem to be standing up to the wear and tear
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-26-2011, 04:58 AM   #15516
Tim K's Avatar
That's good to know.
I suppose the big question is, will they stand up to Calvin using them?
Old 08-26-2011, 05:18 AM   #15517
cannon's Avatar
Nothing ... I repeat nothing can withstand 50 Cal
Old 08-26-2011, 05:57 AM   #15518
The Spec R shafts on touring cars don't last that long either. Did Hudy made the shaft for Yeah Racing?
cheapskate.brok is offline   Reply With Quote
Old 08-26-2011, 11:37 AM   #15519
Default sweep mn 25 degree tyres on carpet
Any good for indoor carpet racing?
scoop is offline   Reply With Quote
Old 08-26-2011, 11:55 AM   #15520
Firefox's Avatar
I do remember reading that the HW 13T was a 380 on the inside, in a 540 size case.
I believe HW also sells a 17.5 and a 21.5 motor and I believe these are actual 540's.
thanks for the reply
Old 08-26-2011, 12:47 PM   #15521
All the .5 turns are full 540 motors. If you look at the others that arent they all have the same can with all the cooling fin's.
Old 08-26-2011, 01:21 PM   #15522
monkeyracing's Avatar
Does anyone happen to know how windings work and how they're given either an even or a .5 designation? Just curious. I've always suspected the .5 thing was just a way to make the BL motors seem special or different from brushed.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 08-26-2011, 02:52 PM   #15523
Anyway to make a mini bumper extension to cushion the blows to the front wheels???? That seems to be the only solution to most of the wear and tear !
bertrandsv87 is offline   Reply With Quote
Old 08-26-2011, 03:06 PM   #15524
tony gray's Avatar
Like the idea of Mini Racing at 75km/h + Of course you do.
You've seen our videos, now get the lowdown on how we build our cars for the insane spectacle that is - VELODROME RACING
HERE on rc-mini.net
Old 08-26-2011, 06:29 PM   #15525
Zac_with_no_K's Avatar
If I use short springs that are smaller than the stock springs, do I need to use a bunch of those clip on spacers so the shock isn't compressed at all?
I'll be using my stock Tamiya TA05 oil filled shocks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
