Like Tree198Likes
Old 08-11-2011, 08:20 AM   #15436
Originally Posted by Smallshinyant View Post
Thanks for the ideas folks. The Black can motor is a closed motor so i cannot take it apart to maintain.
You are right it did have the plastic bits but they have all been replaced with the fancy bearings a few races ago. If it was not for the fact that my local track has such a long straight on most of it layouts this would not be an issue as through the twisty bits I can make a gain on most of the cars in the pack, it just when we hit top speed i appear to max out before a lot of the others. Does I am currently running NiMh batteries(LiPo's on order) i presume that will not effect the top speed?
Batteries can make a huge difference.
Even tho the Blackcan is a "sealed" motor, there are ways to clean and polish the comm. Please go to the Silvercan thread on this forum and do a bit of research. A clean comm can make as much as a 2,000 rpm difference. Several people have posted how to do this.
Granpa is offline   Reply With Quote
Old 08-11-2011, 08:55 AM   #15437
academygaz's Avatar
Blitz Volvo C30 body, sat on my M03. It sits a bit strange on the rear as I need to lower the rear body mounts (lowest hole combined with 7mm rear ride height is too high), but otherwise, it goes straight on.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 08-11-2011, 09:41 AM   #15438
Not a bad body at all, but I would like to see a picture of it with the M03 at 5mm ride height... ...
bertrandsv87 is offline   Reply With Quote
Old 08-11-2011, 02:04 PM   #15439
Hello just sharing my daughter's M05. Front has zero toe, camber link lower position (like M03). Red springs front, blue rear, 40wt/3hole, 5mm ride height, standard kit gear diff w/ little grease.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 08-12-2011, 05:03 PM   #15440
spring71's Avatar
Smile
Hello, Mini racers.
New Mini bodies are arrived from ABC HOBBY.
Click Here to see the new Mini bodies
Click Here to see the Mini Parts Store.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 08-13-2011, 07:40 PM   #15441
Does anyone know if there are hardened outdrive cups for the stock new style (2 flat sides not the splines) gear diff?
Sydewynder is offline   Reply With Quote
Old 08-15-2011, 12:19 AM   #15442
tony gray's Avatar
No, your eyes aren't deceiving you, and the picture isn't distorted. That's exactly what the Ofna JL12E looks like as you pull it out of the box.
Luckily the chassis underneath makes up for the shocker up on top.
Read our full review now - HERE
tony gray is offline   Reply With Quote
Old 08-15-2011, 12:54 AM   #15443
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Thanks for the review, was always a bit curious about that car but couldn't really find much info about it.
Dan is offline   Reply With Quote
Old 08-15-2011, 01:02 AM   #15444
The diff is garbage on that Active Hobby's remake.
Dan if you want to see the car let me know.
I guess there are no hardened outdrive cups for the stock m05/m06 gear diff.
Old 08-15-2011, 01:16 AM   #15445
tony gray's Avatar
It's not a 'remake' as such. It's a 100% Active Hobby car, just in a different box...
As for the diffs, well the first A210's were pretty poor, but since then we've seen quite a few go for a long time with no problem, and certainly we had no trouble with car in testing.
Oh, hardened outdrives? Not that we know of....
Old 08-15-2011, 01:22 AM   #15446
Take the diff apart and look at the holes in the diff gear. There are ridges around the holes that stick out further that the diff balls. The diff rings rubs/rides on these ridges so you can't properly tightened the diff....unless it's a new diff gear and they fixed this problem......
Old 08-15-2011, 01:30 AM   #15447
Dan
Dan's Avatar
Syde, you own an Atlas?
Old 08-15-2011, 01:33 AM   #15448
Messed with one for awhile. More like trying to get the diffs right. Mr. All Speed has it now. Everything else on the car is ok, plastic. There was an SS version that has hopups on it. Tony Gray or Tim K has one and reviewed it awhile back.
Old 08-15-2011, 02:00 AM   #15449
tony gray's Avatar
I think they must have heard your cries of anguish.
Our car has a spool up front and the rear diff is pretty much perfect.
We redid a few of the things in the car but didn't feel the need to even touch the diff.
Old 08-15-2011, 02:40 AM   #15450
I hope so but don't be fooled by the smooth feel of the rings riding on plastic. Hold the outdrives still and try to turn the gear. If it slips and you tighten the diff and it continues to slip........
The car I was setting up originally had a spool up front too which was turned into a diff. That's how I found out about the problem.
For the price I guess it's ok.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
