Like Tree200Likes
Old 08-03-2011, 04:36 AM   #15346
craypot's Avatar
Originally Posted by Sith Lord View Post
Just in case........ Some bigger pics wouldn't go astray
if you're reading this threat can we expect a rock crawler-mini hybrid soon?
craypot is offline   Reply With Quote
Old 08-03-2011, 05:21 AM   #15347
Sith Lord's Avatar
Trader Rating: 21 (100%+)
M05 on 5inch 2.2's There's a project!
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 08-03-2011, 08:24 AM   #15348
RC MARKET's Avatar
Arrowmax
M05 ECS Drive Shaft
RC MARKET is offline   Reply With Quote
Old 08-03-2011, 11:46 AM   #15349
Timbulb's Avatar
Who sells those driveshafts?
Timbulb is offline   Reply With Quote
Old 08-03-2011, 11:20 PM   #15350
hi! newbie here ...i have a stock m03 and i changed the motor to a sports tuned one with 18t pinion gear, my question is why is the esc (teu 104bk) and the motor gets so hot? is my pinion gear wrong?
slk128 is offline   Reply With Quote
Old 08-03-2011, 11:26 PM   #15351
cannon's Avatar
Trader Rating: 35 (100%+)
Use a 20 tooth pinion
Also how long were you running around for ?
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-03-2011, 11:36 PM   #15352
just around 5mins...so 20t would make it run cooler?
Old 08-04-2011, 02:15 AM   #15353
academygaz's Avatar
RC Market I'd guess.
In other news, I've just cut and drilled a Blitz C30 body to an M03, it clears the servo fine, and I think the nose is long enough to fit over a Xevo chassis, which means you can run it 210mm without it looking goofy.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 08-04-2011, 05:45 AM   #15354
Tim K's Avatar
Good to see another brand of double joint universals ... I hope they are stronger than the Spec R items.
The Spec R items worked well and reduced steering chatter when you're on full steering lock ... but I wouldn't run them if you use a spool.
Tim K is offline   Reply With Quote
Old 08-04-2011, 05:49 AM   #15355
cannon's Avatar
There is also Yeah racing ones just released
Old 08-04-2011, 09:36 AM   #15356
The yeah racing ecs look like they can fit an M03 better than the Arrowmax ecs . In any case, I fitted losi lcd's (losa3333) in my M03 with alot of grinding of the ball that holds the pin and the outdrive !!! Yeah racing might also be a better fit than the lcd's ,but might weigh more because of lost lcd material .......
bertrandsv87 is offline   Reply With Quote
Old 08-05-2011, 01:00 PM   #15357
2 Questions....
I got the m05 MiTo model and as I was putting it together it dawned on me that the diff isn't sealed and needs something to keep it from diffing out. would some really heavy diff fluid work? I was thinking 300k or even heavier?
The guy at the lhs said he has one and he just used some shoegoo to lock it. I don't want a locked diff do I?
Also, I just realized that this model is the long wheelbase. The guys at the track I'm racing at said i need the medium wheelbase. Can the wheelbase be adjusted? I thought I read somewhere that they are.
nytryder is offline   Reply With Quote
Old 08-05-2011, 01:35 PM   #15358
superspeed's Avatar
smaller pinion, longer runtime
bigger pinion, more topspeed
Smaller pinion should make motor run cooler. Both over-gear or under-gear are no good. One overheats everything, and other one lose lots of performance.
superspeed is offline   Reply With Quote
Old 08-05-2011, 01:36 PM   #15359
superspeed's Avatar
Originally Posted by nytryder View Post
2 Questions....
Stock diff uses grease only.
Wheelbase is adjustable, check the manual, you'll need a medium wheelbase body.
Old 08-05-2011, 02:09 PM   #15360
Thanks!
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
