Like Tree136Likes
Old 07-24-2011, 03:51 AM   #15286
I)arkness's Avatar
once you get a slight amount of play between the blade and outdrive housing it will start to wear at a very slow rate, this happens to all gear/ ball diffs.
you either have to keep replacing blades so its snug, or just change the out drives every so often.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 07-24-2011, 07:00 AM   #15287
BrodieMan's Avatar
(I posted this ? on the M05 thread but looks like this is the active thread for the mini)
Two guys at my club have the M05 and both have the same problem. One rear tire is - Toe, the other is +. Their hubs are on the right side, same with the arms, hinge pins look straight. I couldn't figure it out so I thought someone here might have an idea. I thought maybe it's something curious about the mini, like the XXX4 having the arms labeled backwards.
thanks
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 07-24-2011, 07:05 AM   #15288
cannon's Avatar
Trader Rating: 35 (100%+)
thanks
Have they assembled the arms the correct way around. Check the marks on the arm parts
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-24-2011, 07:17 AM   #15289
Fluffy622's Avatar
Originally Posted by caltek1 View Post
Fluffy622,
I googled that brand of ESC and motor and it seems very different to the systems we use. I know we only use the Hobbywing or other OEM products. These being, Yeah Racing and Venom.
Regards,
Calvin.
Yeah I've never seen that kind of motor and esc before either. I have always used Castle Creations in my other RC's. What kind of Hobbywing motor and ESC combo would you recommend?
Thanks Calvin
Fluffy622 is offline   Reply With Quote
Old 07-24-2011, 08:27 PM   #15290
bmr
Trader Rating: 27 (100%+)
This is a dupe from the M05 Pro thread. Saw that old thread before this one...
Hey Gang,
I just chewed up another gear in the mini, the plastic gear that the pinion rides on. Today in my M05, last weekend in the kid's M03. Both gears are the same pattern... half the width of the teeth are gone on the side closest to the motor. I verified pinion alignment in both cars after the M03 incident last week, yet had the same problem in my M05. Both time the motor screws were still tight. Same exact problem in two different cars. What am I missing here?
bmr is offline   Reply With Quote
Old 07-25-2011, 12:27 AM   #15291
caltek1's Avatar
Hello bmr,
Did you use the same pinion in both cars? If it is the stock Tamiya offering, when they get old the teeth become serrated and sweep back. (The pinion will look like shark teeth). This will cause the damage you are describing to the mini spur gear.
I suggest using the Tamiya flourine coated 20 tooth pinion gear. The other option is that the motor may have moved or your have got debris into the car and it has damaged the spur. Worse case is the grub screw coming out of the pinion, however you would normally know that.
Regards,
Calvin.
caltek1 is online now   Reply With Quote
Old 07-25-2011, 12:29 AM   #15292
caltek1's Avatar
Fluffy622,
I recommend the Hobbywing system, however a Venom or Yeah racing system is the same.
Later,
Calvin.
Old 07-25-2011, 02:07 AM   #15293
Hey Calvin!
Hows the M05S build going?
mr lee is offline   Reply With Quote
Old 07-25-2011, 08:07 AM   #15294
Fluffy622's Avatar
Thanks for the help again Calvin. I got my M05 lowered down and at the 225mm wheelbase now and she handles a lot better. Boy what a big difference than can make. But my problem is now that I'm running the 225mm wheelbase, my mini cooper bodies don't fit anymore cuz they are 215mm. What good bodies are out there besides the new proline and HPI bodies that fit the 225mm wheelbase?
And also does anyone know the part number for the front body posts?
Thanks again!
Adam
Old 07-25-2011, 08:11 AM   #15295
Misiek's Avatar
Thanks again!
Adam
Tamiya Suzuki Swift Body is pretty good.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMGA1&P=7
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 07-25-2011, 09:12 AM   #15296
bmr
Hello bmr,
Regards,
Calvin.
Thanks for the reply, Calvin.
It was two different pinions and two different motors. The M03 pinion was brand new. Maybe trash got in both cars. I couldn't find the flourine gear where I could get it in time for this weekend so I ordered a Robinson metric gear and a new gear set. I'll reload and try again!
Thanks again.
Old 07-25-2011, 09:14 AM   #15297
Misiek's Avatar
Hello bmr,
Regards,
Calvin.
Can I get a part number for Tamiya flourine coated 20T pinion gear?
Old 07-25-2011, 09:49 AM   #15298
bmr
53509
RC Mart
Old 07-25-2011, 12:45 PM   #15299
Fluffy622's Avatar
Doesn't 20T mean it has 20 teeth? cause that thing has like 38 teeth
Old 07-25-2011, 01:35 PM   #15300
bmr
Generic picture I presume.
He is another link with the right picture.
RC Mushroom
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
