Like Tree198Likes
Old 07-01-2011, 07:58 AM   #15211
IndyRC_Racer's Avatar
Could someone please help me rate the following 60D Tamiya Mini tires from most to least grip?
Kit (treaded)
M-Grip (treaded)
S-Grip (treaded)
Type-B (slick)
Type-A (slick)
I'm trying to figure out what sets of Tamiya tires might work best on a parking lot asphalt surface. So far on my M-03 I like Type-A fronts with S-Grip rears. I have a friend running an M-06 and the Kit fronts were wearing quickly and didn't offer enough steering with S-Grip rears.
Has anyone else noticed that the 60D M-Grip tires seem to have a softer side wall compare to the S-Grip?
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 07-01-2011, 08:53 AM   #15212
Kit (treaded)
M-Grip (treaded)
S-Grip (treaded)
Type-B (slick)
Type-A (slick)
You pretty much have them in the right order. Except the type A is hard to rate since there were a number of variations. Being a relative newcomer to racing Minis, 8-10 years, compared to some I race with, I may not know of all the variants. From personal experience the new A has less grip than the B and frankly lost grip quickly. The old A was better. From some of the veteran Mini guys there were some old, old A types that were better than the old. Sounds silly I know, but that's what they are called around here.
Granpa is offline   Reply With Quote
Old 07-01-2011, 10:59 AM   #15213
superspeed's Avatar
type B is for higher temp track
type A is for lower temp track
both belted slicks are good choice for clean and smooth track.
superspeed is offline   Reply With Quote
Old 07-01-2011, 04:55 PM   #15214
stitchy's Avatar
M-05 S Spec pre order link is up!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 07-03-2011, 03:42 PM   #15215
Originally Posted by stitchy View Post
Nice looking kit, but I need some Spec tires #1016. Starting to do some Tues. nite races at WC again. Check with Bad Santa about the schedule. We'd like to see you and Jeff come race again.
Old 07-05-2011, 09:25 PM   #15216
jonest's Avatar
Is Type A suitable for carpets?
jonest is offline   Reply With Quote
Old 07-06-2011, 10:30 AM   #15217
Starteur's Avatar
Yes , with a blue sedan insert!
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 07-06-2011, 12:41 PM   #15218
academygaz's Avatar
Does the HPI BMW 2002 body fit the M03? I mean in the area at the bottom of the windscreen, does it clear the servo?
And the Tamiya Alfa Giulia?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 07-06-2011, 07:46 PM   #15219
Misiek's Avatar
I'm getting ready to build TFR 54000 shocks, any advise for a first time builder? (I run my mini on carpet, blue springs up front and yellow/neon in the rear).
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 07-07-2011, 05:38 AM   #15220
Tim K's Avatar
The BMW body is a tight fit ... if you like to run your bodies to look like the real car, then it will fit. With a 55mm diameter tyre on and the M03M lowered, you will have a 2mm gap between the top of the tyre and the wheel arch. So it will look scale.
If you like to run your bodies low with the top of the tyre hidden up inside the wheel arch it won't be possible unless you cut the body to clear the servo mount.
I had the Alfa Giulia body on an M03M ... to get the body low enough at the front I had to cut out a small square at the base of the windscreen to clear the RH servo mount and get it to fit correctly. Hope that helps.
Tim K is offline   Reply With Quote
Old 07-07-2011, 09:44 AM   #15221
academygaz's Avatar
Hmmm tight fit then. I think the best plan of action is to pick up the M05 chassis parts and update the M03 into M05.....again, as I've done it before. Thanks Tim!
Old 07-08-2011, 07:23 PM   #15222
toast.'s Avatar
Trader Rating: 14 (100%+)
I finished my M05 pro build and after 2 hours of total run time I notice that my car is losing speed. Everything electrical seems connected properly, my esc is not overheating. If I lift the car up the wheels will spin but the second I set it down it just makes noise but doesnt move.
Needs some help please - is it the diff, do I need to replace tighten and if so do i need to take the whole car apart - arghhh!
toast. is offline   Reply With Quote
Old 07-08-2011, 07:28 PM   #15223
caltek1's Avatar
Trader Rating: 36 (100%+)
What diff did you fit? If you have fitted a ball diff and did not put loctite on the screw, then it may have loosened off. If it is a MO5 ball diff, you can access the screw by removing the bottom hinge pin and tightening. If it is a TAO3 then it is a pull apart job
I would also check the pinion has not moved on the motor shaft.
caltek1 is offline   Reply With Quote
Old 07-08-2011, 08:56 PM   #15224
toast.'s Avatar
Thanks for the quick response, I used the diff that came with the M05 Pro kit (ball diff i think) but did not use any loctite - ill check that.
Update - Pulled the motor out and when i first installed the pinion gear i hadnt used the 'pinion stopper', used it moved pinion gear further out and car is happy again.
Old 07-09-2011, 12:05 AM   #15225
stitchy's Avatar
Hey Granpa, sorry just saw this. We were scheduled to receive some tires this week but had some shipping delays. We should have some by early next week. It would be good to run mini again at WC again. See you at the Tamiya fun race!
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
