Like Tree198Likes
Old 05-30-2011, 07:07 AM   #15031
Originally Posted by Joe_Keaveney View Post
Hi, thanks for the info. Did you put an additional O-ring on all four shocks or just the rear shocks?
I have them on all four and my ride height is 3.5mm using the standard Tamiya rims/tyres (S grips/A's/B/s). Think that is our legal limit for our local TCS.
mr lee is offline   Reply With Quote
Old 05-31-2011, 12:12 AM   #15032
Andyjk's Avatar
thought I'd share my M-05 with you all. Added a bit of weight with al the aluminium, but she looks good and drives well, so I'm happy!
HPI RS4 3 Evo (custom electric), E-Savage, TT-01, DF-01, Slash, CC-01, M-05S, M-04L, TT-01 Rally, HZ Champ, HZ Super Cub, Turnigy 118B, 2 x Dark Impact
Check me out at www.youtube.com/kpkracing
Andyjk is offline   Reply With Quote
Old 05-31-2011, 01:20 AM   #15033
Hi Andyjk,
Is that the Yeah Racing steering set you have on there? I was wondering how it's supposed to go together - I assume you don't need to use the #54191 steering post set as yours doesn't use it?
Cheers
Joe
Joe_Keaveney is offline   Reply With Quote
Old 05-31-2011, 01:27 AM   #15034
Andyjk's Avatar
Hi Andyjk,
Cheers
Joe
Yeah it's the Yeah Racing steering kit. Doesn't need any extra parts to put it together and it came with instructions on how to do so.
Old 05-31-2011, 02:16 AM   #15035
Thanks! I've just been out to my workbench and sorted mine out - thanks again!
Old 05-31-2011, 02:40 AM   #15036
Andyjk's Avatar
No worries, glad to help!
Old 05-31-2011, 03:49 AM   #15037
IndyHobbies.com's Avatar
Is there a foam bumper assembly made for the M-03? Seems like I've seen them before, but can't find them now that I'm looking...of course!
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 05-31-2011, 04:20 AM   #15038
oldnwise's Avatar
Square do a M03 bumper.
http://www.rc-square.de/english/squa...amiya_m03m.php
oldnwise is online now   Reply With Quote
Old 05-31-2011, 05:48 AM   #15039
Any advice people can give to reduce traction rolling? My m05 requires you to be a bit too delicate with the steering. I can get a single quick lap in here and there but the car is just too easy to roll. Running 5mm ride height, fitted 6mm hubs. I was thinking sway bars may help (maybe just fitting it in the rear as to not lose any front steering) but not sure what I can do.
John
J-PaP is offline   Reply With Quote
Old 05-31-2011, 06:02 AM   #15040
Andyjk's Avatar
John
What tyres are you using?
Old 05-31-2011, 06:04 AM   #15041
I)arkness's Avatar
John
super hard springs and oil on the front will also help
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 05-31-2011, 09:44 AM   #15042
gtfour93's Avatar
Trader Rating: 22 (100%+)
Originally Posted by oldnwise View Post
Is this bumper much stronger than the 3Racing bumper? The bumper base is the weak point on the 3R.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 05-31-2011, 10:17 AM   #15043
This is everything I have on the m05 (It is a pro so has the alloy rear upright)
TA03 ball diff
6mm wheel hub
Alloy steering
TRF mini shocks (Hard front, medium rear) 40wt oil all around
front steering link has a 2mm gap.
5mm ride height.
rear turnbuckle has a 1mm gap, can't remember this second if the ball joint is on the upper or lower hole on the upright.
20g of weight in the front bumper, another 20g ontop of it.
Tyres:
Ride 60d front
Cross 36 rear (I've got both the round and square edge). Square edge traction rolls less but most others use the round edge's with no problem.
Also using the fiat 500 body which I've been told isn't helping either.
Running MWB but I will be switching to SWB most likely shortly.
Old 05-31-2011, 03:28 PM   #15044
IronRing Racing's Avatar
I'm just finishing my M06 build, what have guys been finding works for tires/inserts and camber?
I hear the box setup tires/inserts works well, but also all S-Grip Radials all around?
Are guys double stuffing the rears to get gearing, like the fronts on the M03?
For camber, 1.5 front 2 rear (just a total guess)?
Thanks in advance!
IronRing Racing is offline   Reply With Quote
Old 05-31-2011, 04:38 PM   #15045
I)arkness's Avatar
TA03 ball diff
6mm wheel hub
Alloy steering
5mm ride height.
Tyres:
Ride 60d front
those ride 60d tyres are causing the problems, on low grip tracks they seem to be alright, but if the track has some bit it will grab the soft side walls and you will be off
if you are determined to run those front tyres id suggest trying long wheel base.
front- white springs, 50wt 3hole
rear- red or yellow 40wt 3hole
silver swaybar on rear
front shock position all the way out(if using option shock tower)
keep everything else the same
and the reason you find the square edge cross's better is that its actually removing some rear grip, which in you case is helping the car?
B.Portelli
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 21 (0 members and 21 guests)
