Old 12-16-2011, 02:17 AM   #1441
samshirley00's Avatar
TommyAfrica, that seems like a strange gear combination for the motor/spur. What are the ratios like?
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 12-16-2011, 07:03 AM   #1442
superspeed's Avatar
Waiting for the VBC racing chassis becomes available through Calendra racing for a major chassis change on ta06 pro
superspeed is offline   Reply With Quote
Old 12-16-2011, 11:26 PM   #1443
I'm currently running mid 3s
80 and 50 tooth pinion
But I'll be going to 88 spur once I get mine replaced wreck it that's why it's kinda odd looking
Very fast but lacks a touch of infield zip
Still within 160degrees
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 12-17-2011, 02:53 PM   #1444
stitchy's Avatar
Got some of the Exotek TA06 goodies in stock now:
http://www.speedtechrc.com/store/ebp...catmainid=1045
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-17-2011, 04:38 PM   #1445
YAH
YAH's Avatar
Trader Rating: 77 (100%+)
Hi
Just want to know what pitch and brand of spur you are running to fit the TA06?
I also would like to get the FDR to be around 4.
Cheers
The only Surviving Active Life membership of the Smash 'EM! Racing Team, WA's Home of Fun in RC Motorsport, has retired!!
2013 WCMRC club champion - VTA and Mini.
YAH is offline   Reply With Quote
Old 12-17-2011, 07:38 PM   #1446
Send a message via AIM to Profoxcg
I am running Robinson Racing, they are nice.
Profoxcg is offline   Reply With Quote
Old 12-17-2011, 10:47 PM   #1447
Originally Posted by YAH View Post
Hi
Cheers
Kimbrough and Robinson are excellent choices
88 and 48 will get you there
3.98 or something
Overgeared Racing
GH Racing
Old 12-18-2011, 10:51 PM   #1448
cementsurfer86's Avatar
Originally Posted by Lethal Enforcer View Post
How was the speed? Did you stay with the 99/43 gear combo?
Lethal, I ended up gearing down to a 99/42. That puts it to a 5.11 FDR.
The track is big, but it also has a HUGE technical infield, so with the 43, I just didn't have the punch out of the corner I wanted. They are changing the layout now for January, so We'll see what changes I make now.
Took 4th in the A main on Saturday, car was fast. I got caught off guard when the grip came up, and finally tried a thicker rear diff oil. (3k instead of 1k) It definately seemed to help, but it was still touchy with the grip being so high.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 12-19-2011, 07:36 AM   #1449
finally get to race my car tonight.
Last week i put the wrong screw for the ones that keep the front wheels in, and nobody had a spare one
I don't think i can properly race, because its a caravan/travel trailer/whatever its called special for the end of the year tonight!
Old 12-19-2011, 02:04 PM   #1450
sorry for double post, but does anyone know where i can get the front dogbones from a ta06 pro, because i have been having no end of trouble with mine, and i was wondering if they sold them separately....
Old 12-20-2011, 10:55 PM   #1451
WC
WC's Avatar
Trader Rating: 28 (100%+)
'bones are just standard 46mm also used by TA05v2, TB03 etc
the stubaxle with pin secured by circlip debuted on the TRF417
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 12-21-2011, 02:59 AM   #1452
carborush's Avatar
should there be any slack between these to belts ? (see attachment pic)
i just assembled mine and I can move the two belts for like 10 in opposite direction before they lock.
carborush is offline   Reply With Quote
Old 12-21-2011, 04:32 AM   #1453
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
I raced mine quite a bit and my drag brake was on heavy. The pin that holds the white gear has wobbled loose. I upgraded to the Eagle racing for $16 for both sides and the alum is MUCH less likely to wobble.
Ironically, I got the front bulkhead, motor fan mount, gears(both center pulley ones and the main gear) the center gear holder, carbon chassis conversion, carbon IFS conversion, plus some other parts for the same price as the rest fo the carbon conversions. I have VERY little concern for stripped holes, and chassi flex. I am just curious about weight...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 12-21-2011, 05:37 AM   #1454
carborush's Avatar
thanks for the quick reply
but I just wanted to doublecheck if there's is any slack out of the box on a newly installed ta06pro kit
no wobbling orso...the belt themselves are not lose or anything. there's only some slack in de direction of the arrows (see in my attachment)
I can turn 1 belt slightly whitout the second smaller belt turning along instantly.
Is that normal or should they be 100% fixed to eachother ?
Old 12-21-2011, 11:59 AM   #1455
The parts are plastic, they will wear. there are some tolerances that may be greater or less than another kit because of the cooling of the plastic.
take the white part of the gear offand see if the black part(still on the shaft with the pin) has play, if yes, then that is the issue. If no, put the white part on the black one and see if the play is evident.
Do each side one time. It may be the play between the white/black or pin/black part.... only way to be sure is to test each individually.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
