Old 12-05-2011, 03:50 PM   #1366
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by addicted2blue View Post
a bigger spur with smal pinions gives you more power during acceleration (small and technical circuit) and a smaller spur with big pinions gives you more top speed (big circuit with a large straight).
Thanks for the clarification. I knew it was something like that.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 12-05-2011, 03:55 PM   #1367
Send a message via AIM to Profoxcg
Originally Posted by silverhkswrx View Post
you must REALLY want that top speed!
Tim knows the track, and unlike me who has yet to go drive it, hes actually raced on it. So I am sure his recommendations are good. I just don't want to be so slow that is not fun to drive with other people who are racing. I understand my car wont be as strong performer as other "race chassis" nor will my rusted driving, but I I want to at least we able to NOT be the grandma on the fast lane or on the back straight and cause an accident. I know that with 5:1 my cars feels good in the parking lot with no grip ect, so I think I wouldn't hurt to gear up a little bit. After all the motor is running very very cool still.
Profoxcg is offline   Reply With Quote
Old 12-05-2011, 03:58 PM   #1368
Absolutely trust someone with experience on the track you frequent! I am in the tampa area and I run a FDR much higher. As long as the gear matches your driving style and the pace of your class you're golden!
Old 12-05-2011, 04:04 PM   #1369
^ needless to say, the information no this thread has helped me tons and Ive really learned a lot about this car and 10th scale electric overall. In nitro, I did not mess with gears at all, just the clutch. So this is a bit new to me. (ok I did race mini-z and I do have slot cars but they are completely different to a TC)
Old 12-05-2011, 05:23 PM   #1370
Jrwperformance's Avatar
just wondering something...I come from the older days when I raced a TA02. All the gears were lubed with a wax lube for road bicycle chains. Its called white lightning and it worked great wen TCs had gear boxes ..anybody still using this stuuf?
I need a spare room for this hobby. Stupid rent.
Jrwperformance is offline   Reply With Quote
Old 12-05-2011, 05:42 PM   #1371
lightfoot's Avatar
I've been using White Lightning instead of grease on my dog bones for a while now... It doesn't pick up dirt and the wear is pretty good... less friction then grease...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 12-05-2011, 07:32 PM   #1372
oh wow. Yeah I love that stuff, I use it on my "Zippified" Tarmac - ok let me stay on topic.
I wonder if this car be used on the bearings too instead of bearing oil.
Old 12-05-2011, 09:14 PM   #1373
Originally Posted by MC112b View Post
Thanks for the website.
The right hand steering mod is mounting the servo on the right side of the car. This puts the esc on the left side, away from the belts and with shorter/cleaner motor wiring. You can do it with the stock parts, but it takes some dremel grinding. I made a mirror imaged K6 (in the manual) to make hassle free. PM me if your interested.
Wow. Just got the kit yesterday and only have one run with it as it was getting late..... Using same setup as the plastic chassis this thing is on rail!!! Feels much like my T3 as the directional changes are so much faster.... The right side servo mod do seems like a good idea as it move all the wires away from the moving stuff.... if I can get my wife off my back will try it tonight. Thanks for the headup!!!
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 12-06-2011, 01:56 AM   #1374
Lethal Enforcer's Avatar
Trader Rating: 96 (100%+)
anyone running vta? looking for a base spur/ pinion setup
Axial Scorpion ,Team Associated TC5R , Tamiya M03R, Tamiya RC Onroad.com
2012 TCS Best of show Mini
2012 TCS Best of show TT01
Lethal Enforcer is offline   Reply With Quote
Old 12-06-2011, 05:34 AM   #1375
I mountain bike regularly, and I have tons of this stuff lying around... I never knew this trick. thanks for the tip! I however wouldnt use it on bearings. I personally use gun oil. Good 'ol fashoned remington remoil available at walmart.
(for those who dont know)the white lightning comes out a liquid and solidifies when it dries. It is a mix between a wax and lube. As it absorbs dirt, it gets even harder and eventually falls off. If you put it in a bearing, it will eventually accumulate dirt and metal shavings and with no where to fall or leave, it will seize the bearing. Not good.
Old 12-06-2011, 11:09 AM   #1376
mike, any chance you are going to make a titanium main shaft?
Old 12-06-2011, 11:34 AM   #1377
How can I salvage my 630 bearings for the steering posts. They were a little snug putting them in. i tried to remove one and the outer shield popped and the balls are now somewhere inbetween the crevices in my wood floor. that is the only one that busted.
Old 12-07-2011, 03:45 AM   #1378
samshirley00's Avatar
Just asking, because i got the regular TA06, will the dampers from a TA04 fit on them, because i found some of the nice set of TRF ones on ebay for 20
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 12-07-2011, 04:05 AM   #1379
Yes
Juan Aveytia is offline   Reply With Quote
Old 12-07-2011, 04:27 AM   #1380
Originally Posted by Juan Aveytia View Post
Yes
Brilliant.
Was also wondering, i have a cheap brush-less system, but the cables from the speed controller to the motor are only about 5 inches long, and i am unsure if this is going to be long enough to mount the speed controller on the right hand side
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
