Old 11-15-2011, 08:18 PM   #1156
cementsurfer86's Avatar
What are people's thoughts on the inboard shock setup on the TA06? I have a pro coming in the mail, and was just curious if there are any advantages other than using low-slung bodies to this setup. Pro's and con's of each? Thanks in advance.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 11-15-2011, 08:20 PM   #1157
Send a message via AIM to Profoxcg
Smile
Ive been wondering also...
Profoxcg is offline   Reply With Quote
Old 11-15-2011, 08:27 PM   #1158
WC
WC's Avatar
Trader Rating: 28 (100%+)
tamiya sells a few different foam bumpers, all for TB03/Evo5/etc will fit
come in different shapes & sizes - now also in grey or black
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 11-15-2011, 08:36 PM   #1159
WC
WC's Avatar
i've got both running side by side
no 'huge' con with IFS on TA06, seems to work like conventional.
I can't tell much difference between either car's handling
that can be directly attributed to the IFS alone (running sedan shells*)
otoh its extra mechanical bits to fail & fall off
*btw "low-slung" shells create more front downforce further forwards
so you'll be retuning the front suspension stiffer to compensate which can
affect cornering handling too... hard to compare JGTC/lemans vs tourer
www.PandaGFX.com
www.MelbRC.org
Old 11-15-2011, 08:41 PM   #1160
Right on, thanks for the info WC.
On the topic of stiffening up the front to compensate, how stiff are we talking? (Where did you start?) Thanks again.
Old 11-15-2011, 09:09 PM   #1161
I also built (2) TA06 Pro kits, one for me with stand up front shocks, and the other kit for the owner at my Local Hobby shop, with IFS.
I agree, I don't notice any appreciable difference in handling (yet).
Currently, both cars have low track time.
The IFS is smooth, but you'll have to set up the pushrods carefully, (same length) so your geometry is the same left and right.
Tuning IFS, is different from stand up. Example, adding or removing shims at the rocker, changes the mechanical leverage of the shocks. (Haven't got that far playing with the IFS settings)
***Also, before you mount your motor, drill through the motor braces....a 30mm x 30mm cooling fan fits neatly above the motor.
red7fifty is offline   Reply With Quote
Old 11-15-2011, 09:09 PM   #1162
iPearl's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Start with 25 or 30 springs not sure what that equivalents into Pounds.
I am running 25 or 30 on my TA05 and so is my friend on a TA06 with IFS
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 11-15-2011, 10:49 PM   #1163
Are we talking 25-30wt oil? kinda light?
Old 11-15-2011, 10:51 PM   #1164
nevermind, I should read the post more careful, lol.
Old 11-15-2011, 11:12 PM   #1165
iPearl's Avatar
Heheheh no Springs as you already found out.
Shocks i think i am running 35 or 30 with 2 hole pistons instead 3.
Forgot what it was but its been working =D
Old 11-15-2011, 11:17 PM   #1166
I remember the tuning was definately different when I had raced my F201. Being inboard all the way around, it was just different enough to give you a headache, but once I got the hang of it, I found so many different ways to tune the car. Different way of doing the same thing I suppose.
Old 11-15-2011, 11:58 PM   #1167
alien rc's Avatar
Originally Posted by MikeR View Post
Use this method shown here at the bottom to set droop. Its the absolute best way because you are measuring at the wheel and not some random suspension part which is different from car to car. Camber adjustment can affect droop as well and measuring at the arm bottom cannot detect the droop change that happens when you adjust camber.
http://www.tamiyausa.com/articles/fe...article-id=583
With this method my front axle is 24mm and the rear is 25mm.
Well : Very good way to measure it... I will check mine.
FB : ALIEN R/C
www.alienracing.fr
alien rc is offline   Reply With Quote
Old 11-16-2011, 01:17 AM   #1168
^ I noticed the TRF setup sheets reference this measurement style.
Old 11-16-2011, 01:23 AM   #1169
Im not a pro, buy why not just put heavier weight in the front diff to take away some steering ect? (I could be wrong here...)
Old 11-16-2011, 01:39 AM   #1170
Default Shimming?
I was reading a post here on the boards (but I forgot what page) where someone has just shimmed their universals. What does that mean, why is it done and how? Is this something I need to do to my kit and will the shims be in the kit?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
