Old 10-21-2011, 11:35 AM   #991
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by masterhit View Post
Just thought I would post up some of my latest TA06 experiments.
In the pics is a layout for a shorty pack. It is really not as cool as you would think since the chassis still needs to be balanced out for the servo which puts about 45 grams back on the outside of the chassis. I went back to a standard set-up to test batteries back to back.
I also removed a whopping 27ish grams from the drive-line with the following parts.
R1101: R1 Wurks 7075-T6 Drive Axles (Tamiya, pair)
TAM54304: TA06 Front Direct Coupling - 39T
TAM53724: Tamiya 46mm Swing Shaft Lw
TAM51469: TRF417 Gear Diff Unit Cup Joint
Hotbodies DCJs are going in tonight before carpet club racing tomorrow. I should have a very good spec rubber tire carpet set-up after tomorrow. I was getting within a tenth of my TCX consistently before the newest diet listed above.
If you run open rubber tires, not only are Sorex better tires, but they will also drop another 20 grams of static weight off of the drive-line.
Running weight with regular battery, 1389 grams.
Running weight pre-ballast with shorty, 1291 grams.
Mike Slaughter
Mike, Im curious to see what your esc temps are. Your ESC is boxed in, and no airflow...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 10-21-2011, 11:45 AM   #992
WC
WC's Avatar
Trader Rating: 28 (100%+)
Originally Posted by jerzi View Post
Can somebody link the carbon chassis that are out there for sell at this moment.
The car has been out for sometime now but in ebay there is none chassis set for sell yet.
meh TA06 only 6mths old since its Shizouka announcement
when TA05 came out took like 15-18mths before any CF chassis sets appeared
factory CF shock towers just about releasing now
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-21-2011, 11:53 AM   #993
WC
WC's Avatar
does he have a spidery CF batteryhatch lid?
www.PandaGFX.com
www.MelbRC.org
Old 10-21-2011, 12:05 PM   #994
Actually there are 3 (2 avail for purchase)and one in the works....
AlienRC(see past pages)
TechRC
race
drift
I also hear Exotek is planning on putting one out around december. Hopefully MikeR or another Exotek rep can provide a teaser pic/vid...
Old 10-21-2011, 12:06 PM   #995
masterhit's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Big Midget View Post
How is this car right out of the box? Anything extra I would need?
It comes stock with front and rear gear diffs right?
Sorry to interrupt guys.
My view is probably going to be a bit unpopular but.....
In my opinion, it is a car you have to "want to drive". All other things being equal, the driver of the TA06 is going to have the harder slog.
It will need some work out of the box to compete with your previous cars. On tight carpet tracks it loses a bit too much coming out of the turns to be competitive. So far I have failed after many hours to free up the drive-train to any where near the level of a two belt car.
Larger sweeping tracks will mitigate the issue.
Box stock it is a serious pig and it shows on the track. The easiest solution to that problem is a shorty pack. An instant 100 grams weight savings for about $60 in the US. They give up a bit in the voltage department, (see pic of my packs at 35 amps) but so far I feel that is offset by the weight savings if you do not have time and $$$$ to trim the weight in other ways. Even then it may have benefits as you are able to put the weight were you want it.
It has been beaten to death, but the stock Philips head screws must go, and as mentioned the aluminum turnbuckles are not conducive to an abusive driving style.....
If your racing in-doors a spool is an essential tuning aid (+ big drive-train weight savings) along with a good set of springs (Ride, HPI).
In the end my personal experience was that it took just as much money, if not a little more, to compete with the fore mentioned cars along with a higher level of commitment to the build. But, it can definitely have it's own rewards taking the path less traveled.
Mike
masterhit is offline   Reply With Quote
Old 10-21-2011, 12:07 PM   #996
Even if he did, the airflow will come nowhere near as much as on it mounted on the chassis. I have the Kawada one and it has the most "open space" and I KNOW it wont have enough flow w/o a fan.
Old 10-21-2011, 12:10 PM   #997
masterhit's Avatar
Ding! Ding!
Like I said though, I pulled the set-up to do back to back battery testing. This weekend will be the first time that I can run back to back with equal weights between the shorty and standard pack.
If I don't see a difference in times between the two pack types I will try the "stealth" install.
I run blinky so normally the speedo temps at around 90 degrees. Having done crazier motors and boost in off-road with the same speedo with near zero airflow, a heavier car and a body running on top of it I do not foresee any issues.
Mike
Old 10-21-2011, 12:17 PM   #998
Send a message via AIM to Profoxcg
I spent almost 2 hours last night building my rear dif (beginning of the kit).
I am wondering though I the kit come with a pinion for the motor I choose to put there or, it this something I need to purchase separately such as the tires ? - I hate the Phillips screws... I cannot wait for my TI stuff.
In regards to building the dif (rear). the instructions ask to fill it up with differential oil, however after looking at the bags that came with the car, I only saw a CLEAR "damper oil" which I am presuming it the "dif oil" and another bottle of yellowish "damper oil in the back with the shocks."
Can someone tell me if I am in the right direction please? also what weight is this dif and damper oil in the kit?
One more question, Do you guys recommend cleaning the kit bearings (taking the grease out with an ultrasonic cleaner) and just lubing with bearing oil?
Thanks,
Profoxcg is offline   Reply With Quote
Old 10-21-2011, 12:40 PM   #999
Mike
I agree with about 3/4.
It is NOT a chassis to run lower than a 7.5T motor in. You CAN do it, but you will be at a MAJOR disadvantage. This is a chassis that is balanced better than many I have raced, but its balanced the opposite of every chassis I have raced. so there is a definite learning curve. I reccomend racing VTA, RCGT(what I race) and similar 13.5-21.5 turn motors.
I have yet to race against other people, being as how I am still very limited on time and still dialing in the car, but my lap times are within the range for the class. Theres a huge difference in handling with the vertical and IFS setup, and you just need to find what will help you. The IFS bodies(why else would you run the IFSsetup?!) are not roar legal, which is the main (and only) benefit of this chassis. I am sure the Exotek version will fix many issues (weight, Servo sticking nearly 2" out, felx-but that is solved with the Tamiya carbon reinforced parts)
Old 10-21-2011, 12:57 PM   #1000
$11.42!
Old 10-21-2011, 03:43 PM   #1001
SNIPR's Avatar
Thanks for the help, I really appreciate it!
yea, definately time to bust out with the dremel.
my battery i am running is Dimensions: 134mm x 45mm x 23mm and its snug.
69.1 x 46.48 x 24.9= 138mm x 92mm x 50mm (too big)
68.9 x 46.32 x 31.73 = 137.8 x 92mm x 64mm (still too big.)
Really trying to figure out if this car is worth it being that TC5R/JRXS-R are going for $150 on here. I think the only other car that has battery in middle would be the Team Magic car... Hmmm
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 10-21-2011, 04:09 PM   #1002
Suspended
Tigermoth v10 http://tigermothracing.com/products_10.html
has also the battery in the middle of the car.
This car (I mean ta06) is superb to drive and it is very easy to handle.
Jerzi
jerzi is offline   Reply With Quote
Old 10-21-2011, 04:18 PM   #1003
SNIPR's Avatar
This is the one my friend told me about but for the life of me I couldn't remember the name - Thank You! but where do you buy it and how much?
Jerzi
Not Sponsored by:
Old 10-21-2011, 04:24 PM   #1004
Suspended
Buy the ta06, great buy.
Jerzi
Old 10-21-2011, 04:53 PM   #1005
Thanks,
My gear diffs are put together loosely. No oil/lube.
As far as the bearings, I wasnt happy with them. after one run they felt grimey, I opted for the Abec 5 stainless. I wish i would have waited for the acer ones.
Whenever i get bearings, i dismantle, sonic clean then put gun oil in it. Not bearing oil. Smooth and if it can handle the heat of a .45 Taurus 24/7 pro, it can hold the heat of a 8 min race.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
