Old 10-18-2011, 11:42 PM   #961
Send a message via AIM to Profoxcg
Originally Posted by WC View Post
yes both are "short reversible" same as TA05v2, VDF
From TB03 & TA06 kits they are std GF plastic.
For my non basher cars I like to upgrade to stiffer CF parts
as used on TB Evo 5, TRF417 etc. Arms, knuckles, c-hubs.
Have done that to 1 of above cars, difference is noticeable.
I have not yet done CF tub nor carbon shock towers
as they were not shipping yet then.
thank you, do you think the standard shock position is better for you? or I should say which one do you prefer?
Profoxcg is offline   Reply With Quote
Old 10-19-2011, 12:13 AM   #962
SNIPR's Avatar
Where can one find setups for this car runing 17.5/13.5 or even 10.5 on say short tight indoor carpet tracks?
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 10-19-2011, 12:16 AM   #963
The question is what is the standard setup.
I did not see anything in my box other than toe which is done by the blocks.
But my S710 (yeah back in the day) came with a default setup sheet and a blank one. this is my first time owning Tamiya.
Old 10-19-2011, 07:49 AM   #964
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by gom View Post
What is the main advantage of having the Graphite reinforced chassis? Is it for light weight? or is there something else?
If it's for the weight, how much difference is between the Normal plastic chassis and the Graphite reinforced chassis?
It is stiffer, more balanced and can take a hit a little better than the standard chassis.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 10-19-2011, 07:57 AM   #965
not hard... bolt on tower & mount, remove rockers & reposition ballstud
biggest PITA would be changing the shock shafts but if
you've got a spare pair of TRFs then its a nobrainer
586 oz v 616 oz... im surprized that it only increased by that little...
I have opted for all the eacgle racing except the bulkheads. Im rocking the Tamiya graphite ones.
Do you have a part number for the graphite arms?
Old 10-19-2011, 10:06 AM   #966
Trader Rating: 58 (100%+)
Wheres the best place to shop Eagle Racing products? I didnt find much doing a simple search.
MC112b is offline   Reply With Quote
Old 10-19-2011, 11:13 AM   #967
I asked the same question a few pages back. happy hunting!
WC, i found part # 53928 and I wanted to know if your width changed any...It says short sus arms, but the diagrams look nearly 100% the same, even where the holes line up.
53928 **sells by the pair (1F, 1R)**
51353*sells by the set of 4(2F, 2R)**
Old 10-19-2011, 11:36 AM   #968
eagle products:
http://www.broadtech.hk
#53928 are the only arms you will need on the new line of cars. (417, ta06, tb03, ta05v2, ff03)
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 10-19-2011, 02:00 PM   #969
Originally Posted by inpuressa View Post
eagle products:
Ooo la la!! Thanks man.
Old 10-19-2011, 05:00 PM   #970
SNIPR's Avatar
Might be an odd question but our indoor carpet season is only during winter. I am switching from 1/8 eBuggy to 1/10 4x4 SC (Durango) which uses saddle packs. Any chance saddle packs will fit the TA06 Pro?
Not Sponsored by:
Old 10-19-2011, 05:02 PM   #971
highly doubtful.
Old 10-19-2011, 05:04 PM   #972
eagle products:
then why include #51353 in a "pro" version? getting rid of old stock? why not include those in the non pro versions and give us the 53928's?
Old 10-19-2011, 09:55 PM   #973
WC
WC's Avatar
Trader Rating: 28 (100%+)
as a traditionalist... i prefer a shock tower - but i try remain unbiased.
Didn't buy TA05IFS, couldn't avoid it on TB03... until TB03D arrived
with shock tower when mine lost its IFS shortly afterwards
Reasons:-
a, there's more parts to break/jam/loosen/falloff
b, TA06's pushrod can interfere with steering knuckle arm
c, T has done linkage really 'flat' on 06, which causes lateral force on 850s.
Bearings aren't designed to take much sideways load.
d, on 06 IFS they use long shock shaft, no way i'd go buy more just for IFS.
When tuning cars i usually bring a few sets of TRFs in different weights
so i can snap them off/on within seconds to try different settings.
(my filling routine takes hours, never do it trackside)
No other car needs long shaft TRFs!!
e, also on the 06... the pivot for the rocker is on a plastic bit that does flex,
ideally this needs to be on alloy or properly triangulated so it doesn't flex.
T is getting slack, the 05IFS and TB03 pivots weren't noticeably flexy.
(I added a turret brace influenced by T Avante)
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-19-2011, 10:02 PM   #974
WC
WC's Avatar
in the manual they specify what lengths your turnbuckles need to be
if u do those accurately then you will end up with a workable base setup,
without need for any other measurement tools other than a good ruler
(i like 15cm/6" steel rules where the 0 goes right to the square edge)
most of us have our own preference, so when i build i don't bother measuring
and only after everything is at running weight i'll put car on the setup jig.
generally i'll start with
camber 1.5-2.0deg (-ve)
front toe 0-1deg out
rear toe 2/2.5/3.0deg in or whatever is kit std
lately with flexy chassis i'm liking lots of droop, leave screws out
rideheight 4-6mm
www.PandaGFX.com
www.MelbRC.org
Old 10-19-2011, 10:08 PM   #975
WC
WC's Avatar
same
bear in mind IFS car has extra
3 turnbuckles, rockers with 4x 850s, pivots
vs
chunky plastic shocktower and mount wedge
IFS done in stainless hardware vs black steel on the other
but there's not much difference in weight there afaik.
Might lose 20-30g if it were Al or Ti.
www.PandaGFX.com
www.MelbRC.org
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
