Old 10-06-2011, 04:18 PM   #886
Originally Posted by inpuressa View Post
or you can buy two sets of the gear diff II outdrives, and use the short sides to get the horseshoe. Kinda expensive, but you save weight too.
Found this Japanese site:
http://ani.blog1.fc2.com/blog-entry-856.html#more
you save about 8g of rotating mass when you switch to those outdrives and considerably lighter than a ball diff.
Lol that's what I did at first, and what I have at the front now. Thanks for showing the link very interesting.
The other reason is that I hope the spec r diff will not leak as much as the stock one
Warbird is offline   Reply With Quote
Old 10-06-2011, 08:53 PM   #887
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Profoxcg View Post
very interesting thread. I am on the market for a new car. I want to race again this time electric. But in between racing, I want to do a little casual driving, maybe drifting (just to relax after work).
I was looking at different cars by tamiya:
TA05
TB03
FF03
however I was recently made aware of the TA06. I wonder if this new chassis will fit my needs.
My understanding is that this T06 is the evolution of the TA05 is this correct? Which for someone like me who is getting back to rc, make sense to buy over a T05 (older platform).
its more of a ff03/ta05 ifs hybrid. best part is the Ta06 uses parts from about 5 different chassis:ff03, ta05(and IFS), trf417, tb03d, trf416. My front hubs are from a ta05ifs knucles are from a ff03, rear hubs from a trf417. These are the pix of MY baby. I need to weigh it. I cannot participate in TCS races anymore. lolim racing in RCGT. I have yet to race it since i got my hubs, carbon chassis and abec 7 bearings.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 10-06-2011, 09:19 PM   #888
It looks great, especially those white belts, are those 417 belts?
Old 10-06-2011, 09:26 PM   #889
Kawada low friction for ta06
Old 10-06-2011, 09:41 PM   #890
Mods:
Tamiya:
Ta06 carbon chassis
Ta06 Motor heatsink
Ta06 Titanium screw set
Ta06 Rocker arms
Ta06 front spool
Ta06 rear ball diff
Ta06 steering arms
Ta06 center connect
Ta05ifs alum rocker nut
Trf417 rear hubs
Trf417 46mm rear axleshafts
4mm hubs
Trf Titanium turnbuckles
3racing:
ff03 alum Center gear shaft
Ff03 alum center gear
Tb03 light weight bumper
Tb03 carbon bumper support
Ta06 sway bars
Yeah racing:
Ta05 bearing c hubs
Ff03 knuckles
Kawada:
Ta06 carbon Battery cover
Ta06 low friction blets
Eagle racing
Ta06 motor cover/fan holder
Ta06 center pulley holder
Tech taking carbon rear shock support
Uh.... There are other things but I can't remember
Old 10-06-2011, 11:14 PM   #891
Send a message via AIM to Profoxcg
wow nice car.
The stock chassis from the TA06 pro is not carbon but rather plastic?
BTW your car is very nice. I am almost convinced this is what I want. The TA 06 titanium screws, are they hex?
Profoxcg is offline   Reply With Quote
Old 10-06-2011, 11:52 PM   #892
stitchy's Avatar
Yes, the titanium screws are hex driven.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 10-07-2011, 04:49 AM   #893
wow nice car.
Thx.
Yes they are hex(make sure you buy a Tamiya hex driver) and tge lowerdeck is a soft, forgiving plastic. I'd recommend ta06pro, titanium screws and the carbon reinforced lower deck. The pro comes with tons of hopup options tgat would cost $100 separately.
Old 10-08-2011, 07:07 AM   #894
Trader Rating: 58 (100%+)
Ran my right side steering last night. Car worked very well. Our carpet track had just been steam cleaned. The green condition made it hard to get the car "in the track," but it was very promising.
MC112b is offline   Reply With Quote
Old 10-08-2011, 08:51 AM   #895
Default woo woo!
Okay I ordered my kit
Ta06-PRO
Carbon Reinforced Chassis
T Screws - where out of stock.
Now the waiting game.
It is really necessary to tap the holes before? can't I just tap them with a normal screw? - In the past when Ive built cars I never pre tapped anything with a special tool.
Also, the TAMIYA HEX driver is mentioned? - can I not use my Huddy set?
Old 10-08-2011, 10:12 AM   #896
Ta06-PRO
The tamiya kit is $54. The 3Racing TA05IFS kit is $23. both are the same thing(except the 3 diff case screws that the tamiya kit comes with that the 3racing does not)
If you buy the tamiya screw set, for some reason only the tamiya hexes fit "right". you can use a Hudy but it wont fit right. (dont ask me how/why, just know that this is a KNOWN issue with tamiya phillips and hex heads.)
as far as tapping, yes. Tap it! Tamiya "non hop-up" plastic is very rubbery. you will strip threads! The carbon reinforced is even worse. Its more gritty!
Old 10-08-2011, 12:37 PM   #897
havent stripped any threads ever in my tamiya kits, just be careful when you screw the screws into the chassi!
if you use std phillips screws then pretap the holes if you havent got a good screw driver, the phillips screws are a real pita!!!
havent tried tamiya titan screws yet (have used 3racing screws on my previous kits and they have been working just fine with my hudy drivers)
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-08-2011, 12:54 PM   #898
yeah I use the tamiya ones and i have a tendency to torque just a tad too much.
Exactly! Save yourself $30 and buy the 3 racing. (you will be short the 4 diff case screws and CANNOT get them elsewhere-Atleast that I could find)
Old 10-08-2011, 01:21 PM   #899
about using to much force when screwing into a new hole, its all about getting to know the plastic i have been in this hobby for 20 years so i havent got a problem with it
tamiya plastic is quite soft, booth the std and graphite (especially compared to the plastic in my 3racing sakura xi that i drive now)
Old 10-08-2011, 01:26 PM   #900
know the plastic...
hug the plastic...
kiss the plastic...
lick the plastic...
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
