Old 09-14-2011, 07:54 AM   #796
OSherman's Avatar
Originally Posted by rtypec View Post
Orlando, if you need a rabbit to chase this weekend or vice versa, Edgar and I are running our TRF41-whatevers in full-blown angry mode
Donor electronics go in tonite..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 09-14-2011, 09:02 AM   #797
MikeR's Avatar
Trader Rating: 14 (100%+)
psst...Mike, make me order a TA06
You will want to order the TA06 the end of Oct
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-14-2011, 10:08 AM   #798
I haven't rebuilt my IFS shocks on my FF03 in 3 months...seemed to work fine at the nationals a couple weeks ago. I haven't rebuilt my shocks in my IFS 05 since I rebuilt it at the begining of the year. They're not that bad and are no different when you're giving your car a once over.
hm, I use the Groskamp method to build the shocks, and air gets in after every race. Maybe the negative rebound have more tendency to suck air in
I'd like to run my IFS bodies but the air issue and that angle of the rocker arms are not cutting it for me
btw, has anyone got a hold of the reinforced chassis yet?
also, next month will have lots of new parts for the TA06. Namely the other reinforced parts and the CF shock towers.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 09-14-2011, 11:02 AM   #799
gom
Originally Posted by Shameless121 View Post
Order the TA06 its an excellent car. The IFS I guess you just have to know how to drive I have mine setup and im running high 12's low 13's and its not even diled all the way yet and thats on a LRP ESC and a Novak 17.5 motor. your still putting the weight down the center anf front of the car the shock are in the middle, yes it may not be right next to each wheel but weight is dispursed properly if you built it right. Takes time getting used to but its great. I normally will just cycle the shocks a few times after ebery run so they are getting there full ins and out working. I have had no issues in 5 months with air getting inside. Get the proper sway setup on it silver in back red/ pink in front. soften the suspension infront and stiffin in the rear. lower droop to 4 in front 5 in the rear. It Handles!!! Ive had it on carpet and Asphalt
Hi, I have a question about your setup. Actually, a few other guys set the car up more or less the same way on this forum. And I don't quite understand why.
Right now you generally have the front suspension softer than the rear. that includes springs rate, sway bars, damper and droop. My understanding is that this will produce an oversteer (more loose) in On and Off power situation.
When I first build the TA06, I used the manual setup as a base, which has the front and rear suspension in pretty much identical stiffness. eg. yellow springs, same damper, same droop all around. I found the car oversteer a little on and off power.
So if we stiffen the rear suspension even more, wouldn't that make this car oversteer alot on and off power?
This post has nothing to do with IFS by the way. It's a pure car setup question from a newb. I am just really confused seeing a few guys up here setup their car with a stiffer rear.
gom is offline   Reply With Quote
Old 09-14-2011, 11:11 AM   #800
I ran the car stock setup as well and with stock gearing. Changed gears first thing and it was a huge improvment on the speed. then I upgraded everything I could. I stiffened the rear to help roll but still it has give to lean. I loosend the front and put the red sway in front and it has a very smooth lean not fast just enough to steer perfect. The droop is set at that height because the car is closer to the ground for cornering and less drag, the rear is higher so when the car acelerates each time the car has more force and weight to distribute to the rear tires and the suspension and its stiffness levels out to all 4 wheels and it goes! I may try something diefferent this weekend with a little less droop but other then that the car is sweet. If you have access to a setup board and tools maybe a friend or person at your local track can tweak your car and do your setup for you.
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 09-14-2011, 11:37 AM   #801
I am getting good results with the front spring one level softer than the rear. I think this is because the rear is heavier than other TCs(motor way back, gearbox assembly)
I use med sways in the front and rear, but the rear is kind of loose upon exit, so I'll try softs next time. This also might be coming from the gear driven rear which will react faster than the belt driven front.
redbones is offline   Reply With Quote
Old 09-15-2011, 12:18 PM   #802
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Exactly! I'm tuning the ray speed reds it's between the tamiya yellow and tamiya reds.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 09-15-2011, 12:19 PM   #803
Is that a hint at what exotek is planning? Dear god, I hope so!
Old 09-15-2011, 03:38 PM   #804
gom
thanks for the responses guys. I'll give that suspension set up a try in the next race.
Old 09-15-2011, 04:02 PM   #805
OSherman's Avatar
Mazda6-Angry?!?
•KO Propo America
•EXOTEK
Old 09-15-2011, 06:25 PM   #806
Originally Posted by OSherman View Post
Mazda6-Angry?!?
Hulk smash angry?
Old 09-15-2011, 07:20 PM   #807
stitchy's Avatar
Just got the new carbon hatch and alum. rocker arm set
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 09-15-2011, 07:29 PM   #808
stitchy what do those cost?
Old 09-15-2011, 07:32 PM   #809
rtypec's Avatar
Mazda6-Angry?!?
Lol...after driving scale Tamiya shells for the past year...the speed 6 brings out more ferocity
rtypec is offline   Reply With Quote
Old 09-16-2011, 10:16 AM   #810
you may want to click on the links he provided...
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
