Old 09-03-2011, 08:16 AM   #766
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
This is my first gear diff car and I tried to run the gear diff and I just cant seem do get the "rise" that most get from it... Am I running it wrong? I still prefer the ball diffs on both ends.
Im planning on running a solid front spool to reduce my oversteer. Anyone have luck with that? Stiffer sways arent cutting it...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 09-03-2011, 08:25 AM   #767
Joel Lagace's Avatar
Originally Posted by theatriks View Post
ok i will ask him what is locker fluid
ITs basically very heavy Diff fluid. The stuff ranges from 2000 to 300,000wgt and higher. The heavier the less diff action and closer it will feel like a spool, but like a spool with give(so you can hit walls LOL). Ask to take a lap on Eddie's car. It felt amazing last weekend when i drove it.
Originally Posted by stitchy View Post
I wonder if they mean Ofna diff lock
Yes i believe some guys are using that ofna stuff. The car i drove had 300,000 and it was amazing
With a spool you have to understand that even when not hitting things that very violent forces are in play. You turn a corner and you have high grip and the left and right tires are fighting against each other. All that load and strain goes right through the front end from one wheel nut right to the other side. I have seen spools break from the strain. You will notice outdrives and cvd's wear out way quicker then the same parts at the rear of the car.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 09-03-2011, 08:25 AM   #768
while hunting a location to buy eagleracing parts, I came across more of thier parts! many of them fix the flex issues descrived earlier!
anyone know where i can order some parts? I want both shown above and their carbon rear damper stay. Possibly the pulley mount also...
Old 09-03-2011, 09:59 AM   #769
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
might help: http://www.broadtech.hk
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-03-2011, 10:28 AM   #770
Carbon battery hatch...
vs
Kawada seems thicker/stiffer imo.
Old 09-03-2011, 10:47 AM   #771
Originally Posted by VooDooPH View Post
Sweet! they had the mount above the motor in stock, the rear tower and pulley holder. $35 for all 3 shipped to U.S.! I wasnt going to get the pulley holder but $6 for a little extra bling? Why not?
Old 09-04-2011, 01:52 PM   #772
I was worried at first when I ordered from them, but it came pretty fast. It's a HK site, but my stuff was sent from Japan.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 09-07-2011, 01:23 PM   #773
I ordered it the other day but i havent gotten any response or shipment confirmation. I asked how we can get the servo mount, but there is no response from their email.
Old 09-07-2011, 10:07 PM   #774
theatriks's Avatar
Looking for a good carpet setup .... im thinking medium springs and medium sway with maybe 5mm drive height ......anybody got any ideas?
theatriks is offline   Reply With Quote
Old 09-08-2011, 08:40 AM   #775
theatriks's Avatar
really? nobodies had this car on carpet yet ?
Old 09-08-2011, 11:42 AM   #776
masterhit's Avatar
Trader Rating: 15 (100%+)
Front:
1mm under stock lower blocks
stock inner ballstud shims (stock holes)
3 hole 1.1mm pistons
45 weight Losi oil
HPI Pink springs
Gear diff with putty
2nd out from center upper shock mount, stock lower
Rear:
1.5mm under lower blocks, 3 degree rear toe with aluminum front blocks
1mm under inner ballstuds (stock holes)
37.5 weight Losi oil
HPI blue springs
Gear diff with 1000 weight
Stock width with Sweep 32s. 2 deg. camber all around 5mm ride height, 2mm over ride height droop. Stock wheelbase.
Misc: Stock plastics, chassis milled beneath motor for cooling. PF Speed 6, SXT traction compound, full rear 90%ish front.
No sway bars, but I would have them on if I had them at the time. Next Wednesday is our next carpet night and I will update then.... The car is 90% there, just needs fine tuning.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 09-08-2011, 11:47 AM   #777
dag32's Avatar
Trader Rating: 100 (100%+)
Sorry for the shameless plug but I am selling my TA06 click here
★ David Garcia ★
dag32 is offline   Reply With Quote
Old 09-08-2011, 01:41 PM   #778
Broadtech are good. I have ordered from them and it was shipped directly from eagle to me.
BJS414 is offline   Reply With Quote
Old 09-09-2011, 02:34 PM   #779
theatriks's Avatar
Originally Posted by masterhit View Post
Front:
45 weight Losi oil
HPI Pink springs
Rear:
HPI blue springs
Mike Slaughter
Thanks im hitting the carpet tommorow its first run on carpet with this car ....been racing asphalt all summer.....but basically im gonna leave evrything stock and just go with 50wt oil all around then medium springs and sway all around with 5mm drive height and then i will make adjustments from there......im sure everybodies gonna start carpet soon and im sure there will be more set-up info soon.
Old 09-11-2011, 05:04 PM   #780
gom
Default difference between IFS and stardard shock position
I have a quick question about the front shock positioning of the TA06. I heard that putting the front shocks in the standard position instead of the IFS position would produce better weight distribution for this car. The only advantage of the IFS is that you can use a low profile body.
Have anybody tried putting the shocks upright and found a big improvement to their cornering?
gom is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
