Old 08-11-2011, 05:22 PM   #691
nexxus's Avatar
Trader Rating: 297 (100%+)
Originally Posted by Kregger View Post
Has anyone checked to see if the rear shock towers from the Ta-05 line up with the Ta-06?
They don't.
Awesomatix A800X / A800
nexxus is offline   Reply With Quote
Old 08-11-2011, 10:18 PM   #692
Originally Posted by amateur888 View Post
did anyone of you guys tried to make the TA-06 dr
ift? (I am planning to)
ohhh, wait till you see what the guys over at techracing is making. whacky stuff.
www.tech-racing.co.jp/sin-2011-8flame.html
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 08-12-2011, 02:00 AM   #693
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
sexy...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-12-2011, 02:27 AM   #694
Chrissy C's Avatar
According to the translation of the Tech pages that is a drift conversion - can't see why it wouldn't work for racing if you like that sort of thing.
Also from the Tech page is this;
Tamiya TA06 18T spur gear with built-in pulley holder (black)
Integrated spur gear pulley holder made ​​Touring Car Tamiya TA06.
spur, we reduce the blurring of the pulley, the drive significantly reduces the loss are also support high-power motor, excellent durability!
TA6060B Release Date: October Release Product No. 8: TA6060B
Price: 2,800 yen
Think that could be useful/more efficent than the standard item.
Also they mention big bore shocks...guess we'll see about those soon!!
Chrissy C is offline   Reply With Quote
Old 08-12-2011, 11:12 AM   #695
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
I like the rear shock mount, but the carbon chassis itself has waaaay too much carbon, you can reduce a bunch of weight if they start carving into it! Its only for pretty, not function.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 08-12-2011, 12:46 PM   #696
rear shock tower is the most ugly part i have seen on a rc car! wouldnt use that in racing, one hit and its broken..
the chassi looks to have lot of flex in it judging from how its been milled out (hard to tell from a picture)
looking forward to see more cf kits for the car availible on the market!
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 08-12-2011, 02:46 PM   #697
Im not looking at looks, Im looking into adjustability and weight savings.
its also 3mm carbon fiber. Its going to take quite a bit to break it. I would trust this over the plastic factory piece!
Old 08-12-2011, 03:36 PM   #698
i have broken cf towers before when being hit, and the tech one will most likely crack in a hard crash due to its design, i think
a "normal design" cf tower would be maybe 2g heavier, i would take those any day if it makes the car more durable
its easy to get blind with weight saving things, but its important to look how it affects the car both in handling and in strength, a light with less strength car is worthless when sitting broken on the side of the track!
would like to see what Alien RC`s car weights with his cf chassi compared to a std ta06..wish i had a scale here!
Old 08-13-2011, 09:19 AM   #699
[QUOTE=VooDooPH;9515160]sexy...
Can someone design the rear shock tower with the body post on the outside? And if possible put a couple of extra holes in it to install body post pointing towards the rear of the car? Shock towers should be at least 2.5mm thick, preferably 3mm thick.
Juan Aveytia is offline   Reply With Quote
Old 08-13-2011, 11:59 AM   #700
[QUOTE=Juan Aveytia;9520130]
Originally Posted by VooDooPH View Post
sexy...
check the site. it says 3mm thick. Im just curious to see if the holes are in the same location.
Old 08-13-2011, 12:17 PM   #701
props to translate.google.com
Carbon Main Chassis 2.0mm matte High Traction
High-traction mat ○ 2.0mm Carbon Upper Deck
Matt Carbon rear ○ 2.0mm stereo Fina Library
Heavy-duty mats ○ 3.0mm Carbon Front Shock Stay
Heavy-duty mats ○ 3.0mm Carbon Rear Shock Stay
○ Hybrid Rear Spur Housing
○ Big Bore Shock Drift Spec (Black)
○ High Performance Drift Spring winding 8.5 (NEW)
○ Post-kind made by aluminum (light blue anodized)
Old 08-15-2011, 11:13 AM   #702
alien rc's Avatar
Here is some news of the testings I have made with my Carbon kit.
Track Conditions :
The track is very bumpy and abrasive. It's the track of the coming french Cup at the end of the month.
Car :
3mm thick lower plates give a lot of stiffness. Too much infact compared to the top Car like Yokomo and Xray.
Because I have fix the esc behind the steering servo (didn't want to buy extra long motor and sensor cables), I had to add 60 gr on the right side of the car...
So the car, was really too heavy...
On the track, the car was faster than the original one but not enough to follow the top cars...
Work is already done : 2mm thick lower plate and Steering servo on the right hand side of the car.
FB : ALIEN R/C
www.alienracing.fr
alien rc is offline   Reply With Quote
Old 08-15-2011, 11:22 AM   #703
I'm putting my servo on the front of the car
The ESC close the the engine and my reciever on the right side woth some lead.
amateur888 is offline   Reply With Quote
Old 08-15-2011, 12:14 PM   #704
putting the ESC near the motor requires you to put more lead to balance the car. This amount is way more than the extra weight from the longer motor wires.
Because the motor is so far back, this car needs a little more weight up front to get better high speed steering. That's why the ESC is mounted where it is. Probably why the car felt better with the standard front damper layout than the IFS.
I normally ran all four of the same springs on my 416, but for this car, it feels better with a one step softer on the front.
will post a vid later today from Sunday's race. I was able to hold my own against the other high end chassis.
TLR 22 3.0
Apex RC Proshop
Old 08-15-2011, 05:18 PM   #705
alcyon's Avatar
this car should, the basic science behind it is wayy better than those 415 type of cars. The motor and batteries in the middle is already a big plus.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
