Like Tree1Likes
Old 07-23-2011, 04:28 PM   #571
Question for everyone... Is anyone having front or rear or both diffs leaking oil? I had to rebuild both of mine yesterday after it's first time out on the track. Anyone know the cause or a solution? I'm using stock diff oil in both front and rear... Help!! Thanks
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 07-24-2011, 10:36 AM   #572
hacker's Avatar
Trader Rating: 140 (100%+)
just a note for people wanting to put sway bars on this car and thinking of buying ta05 version to fit.
they have a ta06 sway bar kit #54309
http://www.tamiyausa.com/product/ite...oduct-id=54309
hacker is offline   Reply With Quote
Old 07-24-2011, 11:44 AM   #573
iirc, this set has softer bars overall. so instead of the hardest bar, a softest bar has been added.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 07-24-2011, 07:33 PM   #574
Hurricane Sonic's Avatar
this is how I modify it to install servo on RHS...
only grind this part flat on both side...
because the steering arm is grind-ed add 7mm shim here and 1mm between the arm and the steering rod...
another side just install the arm like how the manual told u...
whole view, make sure it is smooth and not too loose...
the chassis is no need to grind like mine, it won't affect the movement...
Hurricane Sonic is offline   Reply With Quote
Old 07-25-2011, 07:44 AM   #575
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by theatriks View Post
does anyone know if a new chassis for the ta-06 is coming out
The carbon reinforced chassis cant come out fast enough! This one has an insane amount of flex!
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 07-25-2011, 08:50 AM   #576
masterhit's Avatar
Trader Rating: 15 (100%+)
Do you feel it is too flexy for racing, or is there another application that you feel a stiffer chassis is better (i.e. drifting)?
I have raced mine on medium bite carpet and the car was very competitive in stock form. With minimal tuning and a base set-up it was within a few tenths of my BD5W in blinky stock. I attribute the time difference more to a lack of a ball diff in the rear and minimal track time with the car.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 07-25-2011, 09:10 AM   #577
hacker's Avatar
Mike Slaughter
it would be good to see if you put a spool and ball diff on your ta06 and see if you get the same or better lap times against a $600 car
Old 07-25-2011, 09:46 AM   #578
masterhit's Avatar
That was kinda my point for buying it! I was curious about that myself.
To be fair though, it really ends up being a $400+ car (before shipping, speedtech + tower prices). A screw kit is a must to prevent owner suicide, as aluminum hexes and XB blocks to get some more toe in it.
To survive our Midwest carpet tracks were tight lanes and 2"x4"s are the norm titanium turnbuckles are a must have as well over the Tamiya aluminum ones.
Then the massive diet plan my car went on, with low profile servo, new mylaps small transponder, leaving off any unnecessary plastic bits, aluminum screws, Tekin with lighter wire, etc.....
And then there was the millwork this weekend to make motors fit better, and different batteries fit better, and a cut-out beneath the motor to aid in cooling....
All of a sudden a "luxury" car doesn't sound that expensive.... But no were near as much fun!
Mike Slaughter
Old 07-25-2011, 10:29 AM   #579
well if you want to be that serious then you might want to go to the 417
important upgrades what i feel is:
rollbars
screwkit in alu or titsnium(i always learn at least one new bad word when building a car with phillip screws..)
suspension blocks in alu
wheel hexes in alu
caster block in graphite
this will make the car better in handling and more durable
and when tamiya releases all the plastic bits in grahite then those will be a hot ticket too
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 07-25-2011, 10:57 AM   #580
Measuring droop is hard on this because of the chassis. The point where the droop screws touch the chassis is so soft that you can actually see the area sag down from the preload of the shocks. The rear is ok, but it is especially bad at the front. When you measure droop, you have to put into account this sag also. Just eye out the droop and make sure the L/R wheels touch the ground evenly. Love how you can fix tweak by twisting the chassis with your hands
But I'm not dissing the car in anyway. My lap times are right there with the other high end cars. Just some kinks that need to be straightened out. Just wish it was lighter. My car is 1420g, while the other cars are just above 1350g. The CF reinforced parts are lighter, I really hope tamiya releases them soon.
TLR 22 3.0
Apex RC Proshop
Old 07-25-2011, 11:01 AM   #581
masterhit's Avatar
I have a BD5W, and all the BD5WX bits sitting on the bench, and a TC6..... It is all about the layout for me.
Luckily I resisted making a crack like "Why would I want a 417 when I have a real car (BD5W) already"?
rollbars
I agree with the castor blocks and roll-bars. So, it is now a $420-470 with the roll-bars and depending on how many of the blocks are replaced with aluminum and if you go for the titanium screw kit......
I'm all about the stock chassis however. Built up with the battery mounted I feel the flex is pretty decent.
Of course, my opinion only.... For it's respective TCS class I'm sure it will be a killer!
Mike Slaughter
Old 07-25-2011, 11:39 AM   #582
hacker's Avatar
the car can be had for $200, post around $35 depending on location.
you don't need ti screws, just replace with hex screws the ones you think you will most likely need to undo, like access to diffs, battery tray.
You don't need alu blocks. There are alot of items you don't need, however they are options should you wish to make your wallet lighter.
personally, I don't think I'm going to bother with the sway bars, there is hardly any roll generated from the layout. I could do with 3.5degree rear toe in, so will get the appropriate block, so $12. Maybe a spool, $15. Wheel hex's, I got some 3racing ones for $10
At the end of the day it will still feel good when you can say "you got beaten by a plastic car!"
Old 07-25-2011, 12:05 PM   #583
Believe it or not, this car rolls quite a lot. When I installed sway bars, the car became even more planted. I would change to alum blocks especially the front. The plastic ones will break on a bad crash.
TLR 22 3.0
Apex RC Proshop
Old 07-25-2011, 12:52 PM   #584
rc_square24's Avatar
You can try shoogoo-ing a piece of cutter blade break-off at where the grub screw lands on, hat will help prevent it from digging into the chassis and give a bit more accurate reading.
rc_square24 is offline   Reply With Quote
Old 07-25-2011, 03:10 PM   #585
well the car doesnt get sooo expensive (yet )
car: $218
rollbars: 13.5
sus blocks: 34 (tamiya split and yeah racing solids)
wheel hexes: 6.4 (3racing)
Screws (only have steel hex screws right now) 20
carbon caster block 5.9
total: $298.8
the car is still about $250 away from the 417!
all parts are bought from stellamodels.net and rcmart.com
alu blocks is needed, at least the D block in the back, i got hit from behind and the right suspension just collapsed, turned out that the hinge pin had POPPED OUT from the block! ther plastic is way to soft in the blocks
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
