Old 07-17-2011, 07:43 PM   #511
Hurricane Sonic's Avatar
Originally Posted by cherry2blost View Post
Having been the proud owner of numerous HPI Pro 3's over the years, including one of the first into the UK, I always found the chassis to have to much longitudinal flex, basically with the graphite battery bar the belts were to tight and there was no way to relieve it. We constructed a bracing bar to run from front to rear with 4mm (2mm thickness) carbon fibre Rod with liquid metal in the end capturing some threaded rod to which we attached plastic ball cups (the open type. This allowed us to adjust very slightly the tension on the belts, but another unforeseen benefit was the complete lack of longitudinal flex. The Pro 3 was designed to flex and the sideways flex was always useful on cold asphalt tracks, by using a single rod you cut out the longitudinal flex but keep the lateral flex that is designed into the car.
Step forward 12 years or so and I now have the TA06, took one look at the way the font box section was flexing when giving minimal pressure to the belt and have decided to do the same again.
take a look at the pic and you will notice that I have used the front Shock mount stay to attach a ball end, and have drilled the read shock tower to accept another ball end, once the rod turns up from the place I have ordered it from will repeat the Pro 3 trick and do away with the longitudinal flex while keeping the lateral flex built into the car. Using ball ends allows a tiny bit of 'give' so that the chassis is not rigid in an accident also the rod seems to transfer a lot of crash energy to the rear shock stay so it may even protect the chassis somewhat.
Will post a pic of the completed job once it's finished, but I have one question, could someone post up the build /modification for the placement of the servo on the Right hand side of the chassis, I have placed the servo to the rear of the car on the right to check clearances etc. and intend to use a long Pro 3 steering linkage for the task as this shallows down the angle for the servo.
nice idea on the long rod, it must help a lot on this soft plastic chassis...
seems only mine is modified to be RHS servo, pls wait and see if I can take some pics when I rebuild the car...
Hurricane Sonic is offline   Reply With Quote
Old 07-17-2011, 10:29 PM   #512
Trader Rating: 31 (100%+)
Originally Posted by Hurricane Sonic View Post
mine using a 5.5T and ran for 2 days, only need to replace rear gear diff...
Only? That's a pricey part! I think I'll wait for the bugs to be worked out before I consider buying one of these. Does take me back to the TA03 days though....
ittjv is offline   Reply With Quote
Old 07-17-2011, 10:34 PM   #513
Trader Rating: 21 (100%+)
sorry to hear that but that all seems to be problems on building up...
try shimming and remove space on the pulley holder(front 18T)
bevel gears or the whole gear diff?
never heard of a gear diff going off so quick.
fastbynature is offline   Reply With Quote
Old 07-18-2011, 01:31 AM   #514
yes, except some options...
bevel gears only, the housing still like new...
http://trackstarrc.com/trackstar/ind...d=63&Itemid=89
he is right, I follow the manual and seems that it got too much spacing...
Old 07-18-2011, 12:26 PM   #515
C van der Hagen's Avatar
Will an extra shim on both sides help?
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 07-18-2011, 01:25 PM   #516
When I used all three, the diff got too tight.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 07-18-2011, 02:10 PM   #517
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
my ball diff is working just fine
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 07-18-2011, 02:39 PM   #518
so most touring car are going from kit ball diff to aftermarket gear diffs.
and you are going from kit gear diff, to ball diff.
why would you do that? Do you find the car easier to drive with ball diffs? What about front spool?
Old 07-18-2011, 03:19 PM   #519
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
On very high traction situations, you can use a gear diff with no issues. On less traction situations like a prepped parking lot track, the ball diff provides more rear bite.
I would test both and see what you prefer. Here in Socal, this is what we have found, over and over again to no fail.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 07-18-2011, 08:25 PM   #520
I install 3 shims on both side, just fit, will test on Sat...
Old 07-18-2011, 11:16 PM   #521
Racecrafter's Avatar
Trader Rating: 25 (96%+)
I'm glad some people read "how to" articles
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 07-19-2011, 01:19 AM   #522
great stuff, had that page on my laptop under my whole car build yesterday, thanks for the tips!
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 07-19-2011, 06:42 AM   #523
Chrissy C's Avatar
Just wondering if people are honestly noticing any difference in the accleration of the TA06 with the geared rear transmission? I think it's a great idea in principle, especially for stock racing...I just hope it carries over to the track!
Cheers
Chris
Chrissy C is offline   Reply With Quote
Old 07-19-2011, 09:16 AM   #524
still having problems with the car not tracking straight. I know how to setup a car, this car is setup perfect. Really weird as I cannot trace it down to anything in particular.
Old 07-19-2011, 09:21 AM   #525
lightfoot's Avatar
I'm no expert but the times I have encountered that situation it usually came down to servo or servo saver...
Love and Peace...
lightfoot is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
