Old 06-28-2011, 05:16 PM   #376
theatriks's Avatar
Hey guys kinda a newbie question but i just wanna make sure im building the rear diffs on my ta-06 and im at the part where i attached the spur gear to the rear diff after i got the spur on i spun it and noticed that one side of the diff was stronger then the other is this normal? is it how some cars have posi and that just doesnt apply here?
Thanks Rob
theatriks is offline   Reply With Quote
Old 06-28-2011, 05:45 PM   #377
JimmyMac's Avatar
Originally Posted by hacker View Post
why are you quoting there are 2 different kits?
I'm pretty sure there is only 1 kit, ta-06 pro kit
and can you show a pic of the mod you made please? I dont have the car yet, so cannot picture what you mean.
There are two kits, the "pro" and the soon to be release "standard" kit that will come with a body, but no nice blue parts and no trf shocks.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 06-28-2011, 06:18 PM   #378
Racecrafter's Avatar
Trader Rating: 25 (96%+)
+1
(and please say hello to Timmie and his lovely GF for me please)
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 06-28-2011, 07:45 PM   #379
JimmyMac's Avatar
Originally Posted by Racecrafter View Post
+1
Haha, no problem JWright. Will do. Need to get Timmie back into TCS racing. I'll be heading to my first one since 2007. Hey, what blinky esc you using for TCS? I need to pick up a cheap one. Wish they allowed Roar Spec, but oh well. I'm looking at the SpeedPassion one. Cirtix I'm thinking.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-28-2011, 07:56 PM   #380
theatriks's Avatar
anybody know what im talking about
Old 06-28-2011, 09:46 PM   #381
After finding out that the car doesn't have enough chassis rigidity, I sat down and looked at it, and did some ghetto mods.
For the front pulley holder, I used different methods for the two screws to hold that piece down. For the front side, I used a little longer screw and put a lock nut from underneath and for the rear side, I used a fairly long screw (20mm). This allowed me to torque the screws really tight to prevent the pulley holder from moving. This should do until someone makes an aluminum version.
The car is pretty flexible in its entirety, adding to the loosening of the center belt upon hard braking. The part that contributes the most to this flex is the point where the upper motor brace meets the top of the battery box. I got some thin card board(from the packaging of parts), and shoved it into the areas you see in the pic. I also closed up any spaces inside the battery compartment to make it a tight fit. I added some card board to the top of the battery, and to the front of it. This surprisingly made the chassis pretty stiff, and the belt doesn't get too loose even if I try to bow the chassis. I still have to test it, but it will have to do until the carbon chassis/parts are released.
Keep in mind, though, that I race on a sugar water track with sorex36 and 17.5 boosted. Hope this will help some people, and if you have better ideas, share them!
BTW, the DUO series motors do not fit unless you hack about 2mm of material from the upper left motor brace. The motor tabs rub big time.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-29-2011, 08:32 AM   #382
theatriks's Avatar
Thanks Rob
DOES ANYBODY HERE KNOW WHAT IM TALKING ABOUT??
Old 06-29-2011, 09:35 AM   #383
TryHard's Avatar
Check your internal diff mesh. Possible that inside the diff one of the crown (big) gears isn't meshed right. Pull it apart and check that the teeth are all moving correctly. I'm not sure on the new tamiya gears, but have a close look at make sure you've not damaged the teeth. I've had this before and had to take the case apart and realign... teaches you quickly to make sure that the teeth are meshed properly before screwing the case down.
HiH
Ed
TryHard is online now   Reply With Quote
Old 06-29-2011, 10:14 AM   #384
theatriks's Avatar
HiH
Ed
Thank you very much for your response
Old 06-29-2011, 11:14 AM   #385
YR4Dude's Avatar
Trader Rating: 44 (100%+)
From the looks of that pic, it doesn't look like the Novak Ballistic or the Thunder Power or the new Reedy Sonic will fit either. The solder tabs are right where that upper left rear motor brace sits.
YR4Dude is offline   Reply With Quote
Old 06-29-2011, 11:18 AM   #386
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The new MD & LRP motors should fit, with their vertical tabs.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-29-2011, 11:27 AM   #387
superspeed's Avatar
Are the CVDs included in this kit? What's their length?
superspeed is offline   Reply With Quote
Old 06-29-2011, 11:51 AM   #388
YR4Dude's Avatar
Nice. But the Murfdogg is not TCS legal. I personally don't care but many others do.
Heres the list according to the rules.
http://www.tamiyausa.com/tcs/rules.php
"Motor Rules: 17.5 motor technologies will be locked down to 4 manufactures to keep things simple for racers and the organizers alike.
A. Novak (item 3417) Pro Brushless Motor 17.5 (Yellow Ring)
B. Novak (item 3617) Ballistic Spec 17.5-yellow tab
C. LRP (item 50850) X-11 17.5 Stock Spec (Orange Ring)
D. LRP (item 50852) X-12 17.5 Stock spec
E. Tekin (item TT2251) Redline 17.5.
F. Speed Passion (item SPF17V2) Ultra Sportsman 17.5 V2."
So its just the LRP, Tekin and SP motors that will fit and be TCS legal.
Old 06-29-2011, 12:31 PM   #389
rc_square24's Avatar
http://www.tamiyausa.com/product/ite...oduct-id=58492
rc_square24 is offline   Reply With Quote
Old 06-29-2011, 01:22 PM   #390
yeah, it unfortunately seems like Tamiya developed the TA06 centered around their own BL motors. That upper brace needs to be redesigned, which will NOT happen. Hoping for an aftermarket alternative.
TLR 22 3.0
Apex RC Proshop
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
