Old 06-25-2011, 12:11 AM   #346
Morbo's Avatar
Sorry if this has been covered before, but has anyone come across a problem with the steering linkage screws (connecting K4 to K5 & K6) hitting the support ribs on the sides of the chassis as the bellcranks go back and forth? After some disassembly, I cranked the screws a little tighter but to no avail. Any ideas?
All humans are vermin in the eyes of Morbo.
Morbo is offline   Reply With Quote
Old 06-25-2011, 01:39 AM   #347
Finally got mine ...
May the build begin !
Ha ha ha ... Ha (evil laugh)
grinta is offline   Reply With Quote
Old 06-25-2011, 08:15 AM   #348
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Between school and a second child on the way, I decided to sell my HPI formula 10 when I was at work. I get home to pack it up to ship, and my 7 year old son gives me the "but daddy, WE were supposed to race it and we never did!" guilt trip... So... Guess what I bought?
I splurged for the front and rear ball diffs, Ta05VII alum sus mounts and nitride ball ends. I plan on running 21.5r, and Was curious during my build what oil is reccomended for the transfer case? What are the benefits of higher/lower oils? This is my first car with a gear diff, but my 5th tamiya, 4th ta chassis(TA05, TA05ifs, Ta05 vII previously)
I am getting the GT500 GTR body shell...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 06-25-2011, 09:36 AM   #349
jds5150's Avatar
You are using the wrong screws. There should be 2 other screws with shallow buttons in the same bag.
jds5150 is offline   Reply With Quote
Old 06-25-2011, 05:29 PM   #350
Here's my car. Car comes in race ready at 1398g. Almost 50g disadvantage compared to the CF cars at my track, but not bad for a plastic car. We'll see how she runs.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-25-2011, 05:41 PM   #351
nice install! I like the way you installed the servo, but I wonder how it will take a T-bone. I guess you have to add weight to compensate if you bring the esc on the left. The shorter motor wire is a good idea too.
TLR 22 3.0
Apex RC Proshop
Old 06-25-2011, 06:55 PM   #352
YR4Dude's Avatar
Trader Rating: 44 (100%+)
I don't think there is hardly any weight difference between the Tekin RS and that receiver. You might be better off putting the ESC closer to the motor.
YR4Dude is offline   Reply With Quote
Old 06-25-2011, 07:13 PM   #353
The tekin is 50 something grams w/wire. The servo is another 43 grams. So that's a total of about 100g on the left side if you put the esc on the left. The receiver/ponder is 14g
Even if you count the motor plate/spur/pinion(10-15g??), belt(2g), pullys(5-10g), the right side will be considerably light with just the receiver. You need to add weights to balance the car which kills the savings from cutting the motor wire short. The only advantage after that is the efficiency of the motor wire conductivity.
I don't have 4 kitchen scales, but the builds that I have seen with the esc on the right have reported that they get almost 50/50 with no weights.
TLR 22 3.0
Apex RC Proshop
Old 06-25-2011, 08:01 PM   #354
JimmyMac's Avatar
What would the weight difference be between IFS setup vs stand up shocks?
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 06-26-2011, 08:43 AM   #355
Couldnt imagine much, But figure the aerodynamic impact also. The IFS setup allows lower/longer hoodline in addition to overall lower body.
Im curious how long the servo sensor wire is...
Old 06-26-2011, 09:48 AM   #356
hacker's Avatar
Trader Rating: 140 (100%+)
Default arms part#
cannot find a manual online yet.
Does anyone know the part # for the arms? I thought maybe I saw somewhere they use tb-03 arms, but cannot be sure.....
hacker is offline   Reply With Quote
Old 06-26-2011, 10:56 AM   #357
might wanna look a little harder...
http://www.tamiyausa.com/pdf/manuals/58492ml.pdf
p/n 51363
comes in one pair of arms per item and front and rear is the same part number.
Old 06-26-2011, 12:42 PM   #358
Almost finished the build and I'm very impressed with the quality of this mid end kit.
No slop at all, no excessive play either !
Silky smooth dampers as usual for tamiya, nice materials choice ...
What can I say ? Perfect !
Old 06-26-2011, 02:21 PM   #359
JimmyMac's Avatar
That only applies if you want to run TCS bodies. Not everyone does or can ya know.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 06-26-2011, 10:14 PM   #360
Just came back from a race. The handled well for its first run. Ran 17.5 boosted.
However, I noticed something. During the middle of the qualifying, I noticed that my belt was skipping on braking. Thought that the belts have broken in, and tried to tighten them up. But what I noticed is that the plastic front pulley holder (the one held down by two screws) has moved diagonally, causing the belt to become excessively loose. I had to tighten the two screws just before the point of stripping the thread to get a good hold on it. Even then, occasionally had to re-torque them down through out the day. That piece is in dire need to be produced in aluminum. The carbon reinforced parts are going to be a must for this car if you are going to be running faster than RCGT speeds.
Other than that, the car has lots of potential.
TLR 22 3.0
Apex RC Proshop
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
