Old 06-23-2011, 03:44 AM   #316
You should look at 1k for a rear diff, 10K is way to high, you will find the rear end will just swing out
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-23-2011, 04:31 AM   #317
fat500's Avatar
Trader Rating: 29 (100%+)
CB...use the kit supplied 900 wt in the rear. you will be very pleased. most racers at my local track run 1000wt the only guys running thicker are the mod guys and they run btwn 1500 and 2000. I run 1000 in my spec r diff on the rear of my ta05v2,17.5 rcgt class and I place mostly 1st or second (not to brag). i did not notice a difference btwn 1000 and 1500. at 1000 the car drives well and i had to go up a rate of springs all the way around to limit the chassis roll when i switched to the gear diff so the wheel would not lift on sharp corners.white hard ft and rear. we run on a high traction outdoor track(see village raceway thread in florida fourms) the tao6 has less roll which is why I am assuming tamiya used the 900wt. Stay under 1500 and you will be a happy racer you can see my car and setup in the v2 fourms.
fat500 is offline   Reply With Quote
Old 06-23-2011, 05:48 AM   #318
Andrew Barr's Avatar
Trader Rating: 73 (100%+)
Default Titanium screw set
Does the titanium screw set require hex drives or are they phillips head? Thanks
Giant MTB
Andrew Barr is offline   Reply With Quote
Old 06-23-2011, 06:15 AM   #319
hex heads for the titanium screws. Tamiya does cross headed screws separately in packs of 10 etc
Old 06-23-2011, 06:25 AM   #320
Thanks.
Just got my TA06 today. Not sure why I bought it as I have two Corally's already. It will give me something to build while I am on holidays.
Giant MTB
Old 06-23-2011, 06:29 AM   #321
tell me about it.. I have a 417 but I really liked my Ta05, and am tempted to get the 06pro as it looks so different.
Old 06-23-2011, 06:42 AM   #322
tell me about it.. I have a 417 but I really liked my Ta05 and am tempted to but the 06pro as it looks so different.
I could resist the price (good value for money) and the design is so unique. The use of front & rear gear diffs takes me back to when I ran nitro a couple of years ago.
I am very keen to test it up against the "expensive" chassis's in 21.5 spec (non timed/boosted). I am quietly confident it will be very good.
Time to order the screw set.
Giant MTB
Old 06-23-2011, 06:46 AM   #323
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Awesome..ill put that on instead...good looking out bro!!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 06-23-2011, 07:52 AM   #324
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Received my '06 yesterday. Will be finished later this morning for some testing at Cal tonight.
I will be posting a picture filled step by step build on the Track Star site and keep y'all updated on the progress of set ups for this car.
Initial set up will be:
8K front diff
1K rear diff
400wt two hole shocks with yellow springs all around.
17.5 non ramp with Fantom 3200 40C
Sweep 30 or Solaris (H) to start.
Tamiya '08 NSX and HSV-010 bodies.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 06-23-2011, 08:44 AM   #325
hacker's Avatar
Trader Rating: 140 (100%+)
sorry to go bit off topic, what is the equivalent of 70wt shock oil, compared to diff oil?
hacker is offline   Reply With Quote
Old 06-23-2011, 10:26 AM   #326
superspeed's Avatar
I decided to hold off on TA06 Pro and going to run the TA05R at TCS races.
superspeed is offline   Reply With Quote
Old 06-23-2011, 01:27 PM   #327
stitchy's Avatar
TA06 Pro back in stock!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-23-2011, 02:20 PM   #328
you sure?, people are beating their lap times with a bone stock ta06 vs. their setup 05 and TB03s.
Been building my car slowly. It is taking a little longer than expected since I had to transplant the suspension from my old cars. the center belt seems rather tight, but it should loosen after some breakin runs. What's with the diff screws. I think that black coating on the screw made it really hard for the hex wrench to get in. I used an exacto to carve that black stuff out.
The steering system is solid. None of that slop from the older cars.
btw, I hope tamiya sells the outdrives that comes with the diff unit II
http://kentech.blogs.se/2011/06/23/4...t-ii-11364761/
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-23-2011, 03:11 PM   #329
Super Moderator
charlie_b's Avatar
Originally Posted by inpuressa View Post
y What's with the diff screws. I think that black coating on the screw made it really hard for the hex wrench to get in. I used an exacto to carve that black stuff out.
I had the same issue until i use a Tamiya .5mm allen wrench and it was a perfect fit. Go figure.
Old 06-23-2011, 09:05 PM   #330
cheROK1212's Avatar
If I'm correct 70 compares to 700 (very light diff oil very thick shock oil). I use 650cst much more shock oil and was told it's similar to AE or Losi 65.
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
