Old 06-21-2011, 06:06 AM   #301
heretic's Avatar
MDawson, any other comment regarding overall handling and balance ? What body did you use ? tires; surface etc...
Are the A- arms in the kit the long or the short ones ? I would bet on the long ones but not sure at all ..;
It is my understanding that there are two whole A-arm sets of different lenght for tamiya TCs. I'm new to tamiya stuff, sorry for the nooob question.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 06-21-2011, 08:25 AM   #302
Trader Rating: 19 (100%+)
Initial notes:
Initial notes:
  • The car generates a lot of traction
  • Transferring the Tamiya suspension and shocks to a new drive-train platform is genius - can wait for stiffer chassis (molded and CF)
  • New drive-train is snappy. No belt drive lag to the rear tires. Pull the throttle and instant on
  • Setup wise... a little work is needed to get more weight transfer in the car. The central weight balance of the car feels nice and neutral - but will take some different thoughts for softening the suspension to get more roll in the car
  • Ran with similar race trim as my 417; LTCR, spool, Solaris (H), 17.5 and 6200mah lipo - the car felt like it has a lot of potential
  • The arms are same as the 417 but not the graphite arms set.
MDawson is offline   Reply With Quote
Old 06-21-2011, 08:34 AM   #303
What gear ratio's can be used on this car ? tempted to get one but will need to gear down in the low 3's running 17.5 non boosted at my local tracks.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 06-21-2011, 08:41 AM   #304
Running a 88 spur will get you down in the mid/low threes
Old 06-21-2011, 08:50 AM   #305
Originally Posted by Chrissy C View Post
Didn't see that this was answered, but if you look on the pic of MDawson's very nicely built TA06 you can see that he is using plug in LiPo's and that the battery compartment has cut away sections that allow access. Not sure how much clearence there is or if this will be an issue once the carbon chassis hits the shops though, but at least they can be used.
Re weight of the car...Are these coming in heavy? I would probably use a spool and diff combo, this would lose a fair chunk of weight wouldn't it - say 30 - 40g - or am i being optomistic there? Coupled with Ti screws and carbon composite wishbones, hubs etc and normal electrics will it be there or there abouts (1350g)?
Car looks very interesting and very tempting - just waiting for a few more race reports, would be especially interested in hearing if the rear gearbox achieves the Riiiiiiiiiiiiiiiiiiiiiiiip the designers hoped for...
I have used both bullet and deans lipos with no clearance and access issues.
In its present form it would be a challenge to get it 1350g. Ti screws, alum blocks, alum cvds, spool, r-gear diff and race electronics with no body is about 1330.
Old 06-21-2011, 09:31 AM   #306
Trader Rating: 56 (98%+)
acknowledgement up front... new to TC, first tamiya car... questions below are ambiguous, just looking for good starting points / logic.
Kit will arrive today, I'm a complete n00b, bought this to run gt2 silver can at the july TCS race in MD. Will probably then use it for 17.5 blinky in the fall.
High grib indoor asphalt track, TCS rules + silver can to start as mentioned.
Should I start with kit set up for diff and shock oils? again very new driver on high grib asphalt, so looking for easy to drive (i suck) vs super high performance but requires skills?
What fdr should i be shooting for running the silver can?
Thanks in advance for helping out a ignorant, but excited, newcomer.
jhhack is offline   Reply With Quote
Old 06-21-2011, 11:20 AM   #307
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Here is my Set up sheet. Nothing special...just right out of the box.
PDF set up sheet will be available on the Tamiya Site soon.
Here is a JPG version for everyone to print out.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 06-22-2011, 04:16 AM   #308
heretic's Avatar
Originally Posted by MDawson View Post
Initial notes:
Initial notes:
OK; thanks for your answers. Not quite sure if you mean that a stiffer chassis is needed or not. It would easily save 25 grams though; on my tc3 the graphite one saved 35.
Did you purchase the anti roll bars and do you see them as possibly useful at one point ?
Old 06-22-2011, 04:32 AM   #309
For high bite conditions I think we need a stiffer chassis. I used sway bars fit for a 417.
Old 06-22-2011, 06:02 AM   #310
Skitee's Avatar
How would you compare overall chassis rigidity compared to the TA-05V2 ?
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-22-2011, 10:23 AM   #311
interesting vid which shows some on-board camera view of the IFS suspension.
+ YouTube Video
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-22-2011, 10:28 AM   #312
I'd love to know how it goes with a powerful motor. Both videos seem to be running a silvercan, most cars can handle fine going that slow.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-22-2011, 10:37 AM   #313
I havent had the chance to take a look at the TA05v2. When I had a TA05v1 I quickly went to graphite chassis.
Old 06-22-2011, 12:06 PM   #314
I've noticed in the manual that this car uses 1A suspension mounts at the front, but isn't that to narrow?
My guess is that they did take this setup to go with a GT-R body set cause this is a bit more narrow then a NSX or a subaru legacy B4 2.0
I'm using 1C (for front/rear) and 1D (for front/front) suspension mounts on my TRF416X and for me this setup works great and gives me lots of steering respons.
So my guess is that this car has a lot more steering respons then i have with my TRF416X and that gives me the feeling that it would make the rear of the car more loose then my TRF416X.
Or am i wrong?
addicted2blue is offline   Reply With Quote
Old 06-22-2011, 10:58 PM   #315
Super Moderator
charlie_b's Avatar
Gonna do more testing tomorrow. Im gonna lessen the rear diff oil to 10K and see what it does. Track will be much smaller 100x60 but very high grip. Ill post my findings.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
