Old 07-24-2014, 06:45 PM   #2491
izzyracer's Avatar
Trader Rating: 27 (100%+)
I'm just trying to bump up this thread since its a less popular car than the other TA cars here in US with a story. So I'm competing again for TCS Nat's here in US this year with a TA06 in GT2 class (17.5). As far as I can tell, same as last year, I seem to be the only one running this chassis. Everyone else is either sticking with the TA05/TB03 version or jumping to the TB04. A disadvantage of this is I really have no one else to compare to as far as setups go and advantage is the opposite where no one else can copy me if ever I do well (hehe). Last year during the quals I forecasted to be within top 10. Finishing 4th and 7th in my 1st and 2nd qual. Unfortunately I had a big car accident going back home and could no longer finish the race the next day. So hopefully this year I can prove that the chassis can compete with the proven, lighter and more efficient TA05's. I mean there must be a reason this chassis is a winner and more popular in Japan right?
My TA06 Version R should be coming in soon. I want to try the new low profile suspension and use it as a back up car. Comments or suggestions? Wish me luck, Preparation has begun.
Izzy
izzyracer is offline   Reply With Quote
Old 07-25-2014, 12:59 AM   #2492
Good luck! I'll be looking for you I ran TA06 in TCS regional, but I am intermediate racer so I am in GT3. Plan to run TA06 again. I really enjoy this chassis. I have a lightweight (1450 on the money) a "bulletproof" (much heavier) and a TA06MS (only GT1 legal).
I have just bought a TB04 Pro II to see what everyone else is doing.
torg is offline   Reply With Quote
Old 07-25-2014, 03:56 AM   #2493
TB03Racer09's Avatar
Exactly why do so many prefer the ta05 over the ta06? When I owned it, I thought the ta06 was a very well rounded chassis
TB03Racer09 is offline   Reply With Quote
Old 07-25-2014, 06:30 AM   #2494
kwkride's Avatar
Good luck izzyracer!!
I am the only one at my local track that regularly runs a TA06 chassis.
I have two of them. I'm currently running one in USGT.
I'm sitting in 3rd place in the series and the first two cars are a TRF417 and an Awsomatix.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 07-25-2014, 06:33 AM   #2495
kwkride's Avatar
I think the TA05 is preferred because it's a standard configuration that has been around for a long time.
The TA06 does have more drag in the drivetrain and it can take a while to get a decent setup working.
Jim
Old 07-25-2014, 06:47 AM   #2496
izzyracer's Avatar
Nice, hopefully you will run the TA06 again to give this chassis some boost.
Izzy
Old 07-28-2014, 01:35 AM   #2497
does anyone know a shop that still sells the exotek ex6 ta06 carbon kit?
miseryindex is offline   Reply With Quote
Old 07-28-2014, 07:52 AM   #2498
For those who are searching for more speed in their TA06 chassis, install the TRF418 suspension.
This will make the car faster then it already is.
So far no TA05 chassis has overtaken my TA06 pro chassis and i've been racing it for over 2 years now.
The car is very fast with the right setup.
I've been helping several TA06 car owners and they all improved their laptimes significantly.
It just depends on the right setup and perhaps on the driver too
addicted2blue is offline   Reply With Quote
Old 08-11-2014, 03:46 PM   #2499
Hi all, I want to buy one car and I want to choose between a TA05 or TA06.
I already have a Sakura Xi Sport that I use in the local track, and now I'd like something different
Well, I notice that:
TA-05: has solid axle (front) and ball diff (rear) .. I do hate ball diffs..
TA-06: has gear diff (rear, ok!) but no solid axle in front.. will it cause me to upgrade the front ?
What would you suggest for me to buy between the 2 cars ?
coderzone77 is offline   Reply With Quote
Old 08-11-2014, 05:13 PM   #2500
You can get ball/solid/one way/gear diffs for both at both ends. Tamiya or aftermarket are available.
If you are racing, a solid front (or a gear diff with THICK fluid) and gear diff rear is current best practice.
To add a gear diff to the TA05 is about $20-$25
To add a solid (spool) front end to the TA06 costs about the same.
Or, you can just buy the TA06 pro with upgrade pack (92243 about $280-$300), and then you get a spool, sway bars, DCJs, alloy steering and a few other pieces.
The TA05 is getting harder to get and is an older design, but being a true belt car is closer to the top end race cars in terms of driveline than the TA06 is. The 06 has some neat features and an interesting hybrid driveline, plus good balance but is very fussy with motors, batteries and electronics (wiring!) unless you modify the plastic slightly.
Having said that, the current "R" version of the TA06 (84378 about $220-$250) would be my pick. It uses the new styles TRF418 suspension, plus has alloy suspension mounts, carbon reinforced plastics, carbon shock towers and HEX SCREWS! It is a bit of a bargain and would be a fast spec racer in the right hands.
It has a gear diff at both ends, but you can fill this with 100,000wt oil or putty to give more front end drive. Or change to a spool for not much money.
cplus is offline   Reply With Quote
Old 08-12-2014, 11:03 AM   #2501
thanks cplus!
so in your opinion, to compete with Sakura Xi, Xray T3, Asso TC6, is aTA05 or TA06 enough ?
Old 08-12-2014, 11:16 AM   #2502
ThePanda's Avatar
Trader Rating: 64 (100%+)
Originally Posted by coderzone77 View Post
thanks cplus!
In the right hands a ta06 is enough, but move to a fast mod class and the double deck cars will prove to be superior.
ThePanda is offline   Reply With Quote
Old 08-12-2014, 02:53 PM   #2503
Thanks but
What are the "double deck" cars ?
Old 08-12-2014, 04:01 PM   #2504
Yep!
In reality they are probably only going to be competitive up to 17.5 blinky. And possibly not always then.
Thanks but
This
Second hand you could find a TRF417 for about the same money as a new TA06 (pro kit), a new TRF418 - if you can find one, will be $450+
$450 sounds like a lot, but, you can spend that easily on a 06 to get competitive!
Adding sway bars, hard suspension blocks, alloy ball cups and turnbuckles everywhere, upgraded CF plastics, front DCJs, alloy steering, decent shocks - boom! You've hit the cost of a TRF car.
Ask me how I know!
Old 08-12-2014, 04:06 PM   #2505
oh ok, similar to my Sakura Xi Sport thanks Cplus.
I just was looking for a TA06 to have something different.
Will my Lipo (Turnigy 2S2P 6600 65C, size 138x46x25mm) fit inside the ta06 ?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
