Old 03-08-2014, 11:05 PM   #2386
jdawg81's Avatar
Originally Posted by whitrzac View Post
Recommended 17.5 gearing?
I haven't raced my TA06 since last season but for 17.5 blinky I usually started around 3.8 to 4.0 fdr.
I just saw that Tamiya offers carbon damper stays for shorter dampers. Does anyone know what advantages there are from installing these and using short dampers? Are shorter dampers supposed to give better handling?
jdawg81 is offline   Reply With Quote
Old 03-10-2014, 07:43 PM   #2387
Basically finished my TA06 Pro with way too many hop ups. Just got to finish the body off - the chassis and electrics are complete.
the kit was the pro "upgrade" kit so came with spool, rear ball diff, solid steering etc, and then I added solid suspension mounts and a few other neat touches - see if you can spot them all - I went a little click crazy. Oops. Should drive nice.
I can't add urls for images yet, so here's the album location.
rctech.net/forum/members/cplus-albums-ta06-pro.html
cplus is offline   Reply With Quote
Old 03-10-2014, 08:01 PM   #2388
Seems I have enough posts now
Old 03-10-2014, 08:47 PM   #2389
Johnn27's Avatar
Trader Rating: 64 (100%+)
Thumbs up short damper stays
If you run those shorter damper stays you need to run the short shocks "trf short dampers 42273" or you can also use the VBC wildfire shock set with slight modification. lower dampers stays and shorter shocks lower the center of gravity and help handling
Johnn27 is offline   Reply With Quote
Old 03-11-2014, 08:30 AM   #2390
Mitamiya's Avatar
Trader Rating: 14 (100%+)
Is anyone using the new carbon reinforced chassis? If so, how do you like it?
Thanks.
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Old 03-11-2014, 08:42 AM   #2391
whitrzac's Avatar
Trader Rating: 93 (100%+)
Thanks.
There's a new one?
whitrzac is offline   Reply With Quote
Old 03-11-2014, 09:10 AM   #2392
Are you talking about the carbon reinforced lower deck or something else?
Old 03-11-2014, 10:57 AM   #2393
Mitamiya's Avatar
Yes, sorry, lower deck.
MItamiya
Currently Racing
Old 03-11-2014, 08:06 PM   #2394
My build has every carbon item other than the lower deck.
Was out of stock when I ordered otherwise I probably would have.
I went over this thread when I bought it, apparently the stiffer lower deck doesn't handle quite as nice and cracks easier.
Old 03-11-2014, 08:13 PM   #2395
jdawg81's Avatar
I had the carbon reinforced lower deck and it does break easier than the stock deck. I accidentally went too wide going around a sweeper and hit the side wall which somehow cracked the lower deck. The left rear suspension arm fell off and some smaller pieces which I was never able to find on the track. I went back to the stock lower deck and I couldn't tell any difference between the two when I raced in the 17.5 stock touring class. It was also way more durable as it never broke after so many crashes.
Old 03-12-2014, 07:46 AM   #2396
Mitamiya's Avatar
Thanks guys. Nice build CPlus.
MItamiya
Currently Racing
Old 03-12-2014, 07:53 AM   #2397
whitrzac's Avatar
I'm going to start building my pro kit tonight...
Does anyone have any hints/tricks that I should do right away?
Old 03-12-2014, 05:07 PM   #2398
Thanks, it's about as good as you can make a TA06 without resorting to full alloy bulkheads (excepting the old(ish) ESC and motor) which are heavier anyway.
I was tossing up between this and a 417/418 but couldn't justify the TRF for carpark bashing, but then I went a little crazy and possibly spent more than a TRF in the end....
It does look awesome though
Body is 85% done, need an afternoon with some patience to do the stickers.
Old 03-12-2014, 05:17 PM   #2399
- Tap all your threads. Especially if you have the optional carbon stuff.
- Don't tap/screw the bottom screws into the gearbox too tight. It's very easy to deform the casing and get gear rub.
- Mounting the motor is a right pita unless it is rear terminals or you get an extra spacer - even then not all motors will work without trimming.
- Get a 5.5mm spacer set or two. The plastic tree spacers are not great. Especially for the arms. Not so bad under the camber balls etc, but I did all of them.
- The rear hub camber ball mount is just plain odd with an extra add on piece of tree, two screws and a grub.
Get a TA06MS manual and build it like that instead.
- look very closely at shims in the manual. Easy to miss them.
- use the one extra shim in each side of the gear diff(s) they are too sloppy otherwise.
- on the diff subject, don't sand the gears too much to remove the sprues, if you do, use vernier a to make sure they are equal.
Any other tips from me would be generic like use a little moly when assembling turnbuckles for easier adjustment.
Old 03-12-2014, 07:40 PM   #2400
Mitamiya's Avatar
Do you have a part number on the 5.5 spacer set? Waiting for my option parts to arrive to begin building as well.
What is the livery you are going with on that Ferrari 599 body CPLUS?
Whitrzac, sounds like you are about a week ahead of me in the build process. Please post a few pics if you get the time. Good luck and enjoy.
MItamiya
Currently Racing
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
