Like Tree1Likes
Old 01-20-2014, 10:24 PM   #2341
Originally Posted by volracer View Post
I have a TA06 Pro with the TRF black mini shocks. I run outdoors on rather bumpy track. Doses anyone have a problem with the mini shocks on a bumpy track? Does anyone use the regular length shocks?
I use regular length on Tamiya Track in Aliso Viejo. Just got the Short dampers and towers to try next time around.
torg is offline   Reply With Quote
Old 01-22-2014, 04:25 PM   #2342
Has anybody had rear traction issues with the ta06?
The rear on mine slides around bad on turn in and a bit on exit as well.
Racing on med grip carpet.
Atechbh is offline   Reply With Quote
Old 01-22-2014, 04:49 PM   #2343
ThePanda's Avatar
Trader Rating: 64 (100%+)
Could it be the drivetrain? Ya know how the rear is gearbox, and the front is belt? The front will have a "lag effect" i believe, and the rear could be breaking loose under power, because the power is more direct. My theroy anyways. If im am correct, try a softer tire all the way around.
ThePanda is offline   Reply With Quote
Old 01-25-2014, 05:49 PM   #2344
What body works best with this chassis for gt2 21.5?
Old 02-02-2014, 07:10 PM   #2345
When I put my ta06 on the tweak board i have to adjust it quite a bit at the shocks to get it level. Does this mean my chassis is tweaked and needs to be replaced?
If so for carpet do I want the regular or car on reinforced ?
When the tweak is set the ride height is off about .5mm side to side
Old 02-04-2014, 09:55 PM   #2346
jdawg81's Avatar
Carbon reinforced parts will help reduce the weight of your car. I installed all the carbon reinforced parts on my TA06 and had no issues except for the carbon reinforced lower deck. I find that it breaks easier compared to the stock lower deck. I went too wide around a sweeper and cracked the lower deck after hitting the side wall. If you're a good drive and you don't get into big crashes I think you'll be fine with it as it's also a bit stiffer compared to the stock lower deck.
I'm not sure about your chassis tweak though. I looked at mine and it's level on all sides. So it's possible yours might be tweaked assuming everything else on the car looks fine.
jdawg81 is offline   Reply With Quote
Old 02-11-2014, 12:40 PM   #2347
Right now i'm being busy with mounting a full new TRF418 suspension on my TA06, including the TRF418 stabilizers.
Hope to be able to get the car done before thursday, then i can test the new setup in the evening.
addicted2blue is offline   Reply With Quote
Old 02-11-2014, 01:35 PM   #2348
monkeyracing's Avatar
I've been digging through the thread for quite a while and can't seem to find a direct answer to a question I have. If running 64p gears, what size spur gear would be advisable? I've got an 88 in the car now and there's a good sized gap between it and the 44t pinion on the motor.
I'm fairly new to 64p, but I've got many more pinions in this pitch than I do in 48 or .6 mod, so I'd like to utilize them. I'm going for an fdr of around 4.3.
Thanks for your help!
jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-11-2014, 03:34 PM   #2349
How can you get the fittings for the stabilisers? What part numbers please?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 02-11-2014, 05:42 PM   #2350
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
jim
a 90 or 96 spur should work fine for the FDR you're going for...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-11-2014, 05:59 PM   #2351
ThePanda's Avatar
the bottom stock deck is already reinforced with what i think is fiberglass fibers. thats the one piece that i would leave as stock, as it will flex a little more that something with a higher carbon content, which can be a good thing.
Old 02-12-2014, 06:40 AM   #2352
lightfoot's Avatar
Default IFS too a STD
Need help .... Trying to convert my IFS too a STD... The manual doesn't give any instructions on how to do this other then a small pic on page 4... I have the correct front shock arms but can't seem to connect them to anything in the front bulkhead thing ? What am I doing wrong
Please help...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 02-12-2014, 09:34 AM   #2353
Do you mean the stabilizer rod ends?
Old 02-12-2014, 05:47 PM   #2354
VooDooPH's Avatar
Please help...
installing the standard shocks is illustrated from page 20 on the TA06PRO manual...
http://www.tamiya.com/english/rc/rcmanual/58492.pdf
Old 02-12-2014, 10:11 PM   #2355
lightfoot's Avatar
Thank You
Love and Peace...
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
