Old 05-16-2013, 12:18 PM   #2251
Trader Rating: 29 (97%+)
a complete kit
zaraz is offline   Reply With Quote
Old 05-17-2013, 09:36 PM   #2252
redzone's Avatar
Does anyone make alloy stiffeners that have a notch already in them for fitting a brushless motor with the terminals coming out of the top rear of the case?
79 mk1 Sand Scorcher, 09 Buggy Champ, TB01 Lancer Evo 7, TL01 Lancer Evo 6, TA02 Castrol Celica, TA02SW Taisan Porsche, TA02W Castrol Supra, TA03F Starion drifter, M06pro Gemini coupe, Tamiya Dyna Storm 5.5t, Stadium Blitzer, Bear Hawk, Baja FAV, Egress!
redzone is offline   Reply With Quote
Old 05-19-2013, 04:13 PM   #2253
Originally Posted by VooDooPH View Post
hpi vektor motor has its wires coming out from the endbell's top tight? might be an iffy fit for the TA06... esc should be fine.
for the radio, if you plan to race, suggest you go with the midlevel radios from futaba (4PL) or sanwa/airtronics (MT4) if budget is tight...
It was actually a good fit no mayor problems as far as the motor wires coming from the top or being to short. I'll upload pictures when I get on a computer.
papabear is offline   Reply With Quote
Old 05-21-2013, 03:15 PM   #2254
in my quest to order parts, I have two items that are doubles, therefore selling them, tech racing direct center aluminum pulleys, these can be mounted without the e clips and looks so clean, and tech racing aluminum spur gear holder with intergrated gear, again looks super clean, selling both parts for 50 shipped anywhere, cost me around 75, please look at my for sale thread, for pictures thanks
Old 05-24-2013, 09:02 PM   #2255
TB03Racer09's Avatar
The new MS chassis looks awesome! I was set on the ta06 pro but now cant decide if I want the ms aaaaaaagh!
I here people saying that the ta06 pro is heavy, is this in comparison to carbon fibre cars only or to plastic cars like the ta05v.2 also?
Aiming for under 1400 grams all up with the pro if its possible. Maybe a shorty Lipo will help me achieve that
TB03Racer09 is offline   Reply With Quote
Old 05-25-2013, 10:14 AM   #2256
Mine weights lower then 1400gr, it all comes down to what body, battery, electronics and parts you are using. When i drove the car with a brushed motor/esc combo the weight was about 1250gr. A lightweight body and a short lipo will get you in the right weight direction
addicted2blue is offline   Reply With Quote
Old 05-26-2013, 05:09 PM   #2257
hi I have some aluminum parts for sale these are for the ta06,
square top front bulkhead
square top rear bulkhead
square rear hubs for ta06, elimanates the extra screws and weight
tech racing aluminum spur gear holder with aluminum gear
tech racing aluminum center pulley system direct drive, elimanates the e clips and looks super clean
I paid over 175 for these parts brand new, these are still in packages, will accept any reasonable offer, or will trade for radios, other cheaper kits, brushless systems, etc etc let me know what you have thanks
Old 05-26-2013, 05:23 PM   #2258
nolo148's Avatar
what parts, body, battery, electronics were you using to get under 1250 gr?
nolo148 is offline   Reply With Quote
Old 05-27-2013, 01:42 AM   #2259
thanks Addicted2blue
I was planning on getting the Hobbywing Xerun 120a V2.1 cause it can do everything but it weighs 105g and is pretty large too 43mmx36mm can it fit, I wonder
There's also the XTREME esc which is a lighter version of the 60a xerun i believe (46 grams). That's more like it, though the xerun 120a is only $20 more....decsions
I will definetely need a shorty pack at least
Old 05-27-2013, 09:26 AM   #2260
I was using a tamiya NSX 2005 light weight body set, battery was a short type and the electronics are tamiya volac esc, low profile servo servo. And of course all the carbon & carbon reinforced parts, titanium&alu screws and TRF417 diff outdrives (they are much lighter then the standard steal ones) also a carbon shaft for the idler gear in the gear box. You can also use some light weight swing shafts for the universals but this can only be used with low powered motors such as 21.5T or 17.5T motors with blinky mode. Just check the swing shaft protections on regular base. and there are some other small things you can do to save weight, but that will rase the amount of money you put into it.
Old 05-27-2013, 09:29 AM   #2261
I've got the Xtreme stock esc installed now on my TA06 and it works great. If you are not going to use a modified motor then the Xtreme stock esc is more then enough.
Old 05-27-2013, 07:06 PM   #2262
Thanks bro for your help
Old 06-05-2013, 07:42 AM   #2263
R-Sector's Avatar
Only @ $79.99 Limited quantities!!!
http://rsector.com/index_eproduct_vi...?products_id=8
www.rsector.com
R-Sector is offline   Reply With Quote
Old 06-05-2013, 08:10 AM   #2264
Chiefy 707's Avatar
man! I wanted to get this for my TA06! Only problem is I haven't got my TA06 yet
I like the look of this conversion more than the others
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 06-05-2013, 10:02 AM   #2265
izzyracer's Avatar
Trader Rating: 27 (100%+)
Does the conversion work if I us the conventional stand up suspension setup in the front?
Izzy
izzyracer is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
