Tamiya Ta06
#2101
http://os.3racing.hk/articles.php?articles_key=133
#2102
Will definitely follow those instructions.
#2103
I use this method when I build my Tamiya gear diff. I'm running 300k Spec-R oil in the front and 40wt Associated in the rear. I have never had a problem with leaking diff.
#2105
#2106
Hi, just want to ask TA06 users about the car's street/parking lot capabilities.
Im about to purchase a TA06 Pro for street (drag) and track use.
• Does it suck up small stones or debris like the TA05 which sometimes jams the drivetrain?
• Does the gear cover effectively deflects small stones or debris and protects the spur and pinion gears better than the TA05?
• Can the stock drivetrain take an 8.5T brushless set up?
• Does it flex like the TA05 or lesser?
• Whats the most important hop up parts to buy first for durability purposes?
• Any known weak part of this kit? Any mods?
• Is it necessary to run a a fan on the motor since it gets less passing air?
#2107
I can't help you too much. I've never run mine on anything but carpet.
I will tell you that there is quite a bit of flex in the stock plastic chassis parts.
I replaced them with the carbon reinforced parts.
Too give you some idea, I needed a fan on a 25.5 motor in VTA.
Replace the stock battery door with the Tamiya Carbon Fiber piece.
It allows a lot of airflow to the motor.
#2108
The chassis of a TA06 has more flex then a chassis of a TA05, chassis of a TA06 is totally different to a TA05.
Every year we have a race at a parking lot with a lot of dust and small stones and the car handles really great (My personal feeling is that the TA06 performs better then a TA05) but it all depends on your setup.
I'm never using the spur/pinion cover and also never use the 06 gears from tamiya, always using the 04 pinions/spurs and i don't have a problem with the gears getting damaged.
But it can be prefered to use the 06 spurs/pinions and the gear cover for driving on a parking lot.
About mounting a fan directly above the motor it's also depending on what kind of motor and gear ratio you are using.
I'm only using a fan when we have a race at a big track and when i need to use a low gear ratio, otherwise i don't use a fan.
Always use a temp gun to make sure the motor doesn't overheat.
hope this helps
hope this helps
#2109
i see! thanks for the feedbacks!
#2110
on what level you guys usualy position the snap pins for the body?
#2112
Anybody know if there's some aftermarket diff cups for rear diff that holds up better then the original... Have a FF03r, and it eats the cups for breakfast (same diff as ta06).
#2115
Anyone chop up their chassis? I hear of people cutting a slot out under the motor to allow for some air flow
