Old 10-13-2012, 03:55 AM   #2086
The car can be very competitive against more expensive (with alu and carbon parts) cars, it all depends on how good the car has been setup.
As long as you don't want the car to be run in modified classes it can keep up very well.
Hope this helps
addicted2blue is offline   Reply With Quote
Old 10-15-2012, 02:12 PM   #2087
izzyracer's Avatar
Trader Rating: 27 (100%+)
has anyone tried a 75t 64p spur with 38 to 45 pinion if it fits?
Izzy
izzyracer is offline   Reply With Quote
Old 10-25-2012, 04:33 PM   #2088
I can't give you a definitive answer as I run 48P gears but I can fit in a 80T spur and 28T pinion (48P) with room to go a few teeth higher so converting that to 64P you should be able to get it in.
I had problems getting higher ratios with smaller gears as they didn't mesh hence why I've whacked an 80T in there.
ript is offline   Reply With Quote
Old 10-25-2012, 05:30 PM   #2089
izzyracer's Avatar
Thanks, I actually figured gearing between 86-88 spur and 48-52 would be ideal running 17.5
Izzy
Old 10-29-2012, 12:47 AM   #2090
Trader Rating: 45 (100%+)
Send a message via AIM to RicerX1
Does anyone know if the rear aluminum stiffener will clear a Revtech motor?
RicerX1 is offline   Reply With Quote
Old 10-29-2012, 08:55 AM   #2091
izzyracer's Avatar
It does have a slight cut out but not sure if it fits.
Izzy
Old 11-01-2012, 01:30 PM   #2092
So how many of you guys run the IFS or standard standup shock setup
I've been running the standup for a year and want go back for the low bodies .
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 11-01-2012, 01:45 PM   #2093
I've always been running the shocks in standard standup position for over a year now and i love it. Never been running the shocks in IFS position on my TA06 PRO but did run them in that position on my TA05 years ago and it did work very well.
Old 11-02-2012, 02:00 AM   #2094
Suspended
Are you guys useing balldiff in the rear.
If someone wants to sell an used carbon conversion chassis to this car please mail me with pics what you have.
Jerzi
jerzi is offline   Reply With Quote
Old 11-02-2012, 08:34 AM   #2095
Jerzi
I use the gear diff with the thinnest diff oil I have and don't fill up the case just enough to coat the gears otherwise it leaks because it's so thin
Overgeared Racing
GH Racing
Old 11-11-2012, 08:51 PM   #2096
Jerzi
I bought one but my mate said they're more maintenance and hassle than they're worth so it's still sitting in the packet.
I bought the Exotek chasis conversion kit, its held up well so far.
With the stock kit oil I found the bloody thing leaked regardless of level and it'd be dry by the end of a race day. I've started using TRF 2000 gear diff oil and has solved this problem as it's a lot thicker. Just do a couple of practice laps to loosen it up before you race otherwise you'll be oversteering like a mofo
Old 11-11-2012, 10:02 PM   #2097
Eagle Racing TA06-24 Competition hop-up kit going at a crazy price. Just ordered 2 of these. I'm using Eagle bulkheads and pulleys have had no problems. The Tamiya versions of the alloy rear uprights alone are valued at $32 so this is an amazing deal.
USD 7.90
SAVE : USD 71.09
http://broadtechonlineshop.com/eagle...spx?id=TA06-24
Old 11-18-2012, 08:11 PM   #2098
jdawg81's Avatar
What oil are you guys using for the rear diff? I'm using 1K oil and after a day of racing it has all leaked out. Other than switching to a thicker oil is there a way to stop it from leaking?
jdawg81 is offline   Reply With Quote
Old 11-19-2012, 01:47 AM   #2099
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
greenslime the o-rings and output shafts to death...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-20-2012, 10:00 AM   #2100
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
I have got the same leaking problem as well... My gear box had oil all over.
Tamiya Addict
KELVIN KHNG is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
