Old 09-24-2012, 02:34 AM   #2071
carborush's Avatar
stiffer yes, but also much more fragile
the plastic bits can take quiet a beating, the reinforced ones crack much faster after even a small impact
my facebook : search for the "Bananairbrush RCbodies" page
carborush is offline   Reply With Quote
Old 09-24-2012, 10:05 AM   #2072
Originally Posted by carborush View Post
so buying all that carbon reinforced parts saves you +- 10gr ? an costs so much money...?
I'd say get yourself a lightweight battery that way you can save up to 100 grams or more !
this weekend we used 96 spur and 49-51 pinions in the tamiya benelux cup so the ratio was 4.25 - 4.08
I didn't use a bigger pinion then 48 (my gear ratio was 4.34) and you noticed for yourself that i was faster overall and not on the straight part of the track.
My car was by far the lightest of our class, i even used a lightweight body and all the carbon hop-up parts.
All the reinforced parts are parts that don't easily break during an impact, cause the things you can easily break are the suspension parts and that's not the case here.
Standard plastic parts do wear out much faster then the reinforced ones wich results in more play between the parts and will cause a less predictable car during the race.
Sometimes reinforced parts do have more purpose then just saving weight.
And it's better to save weight on the car itself then to buy a battery that's much lighter but isn't that much powerfull as an normal up to date battery.
addicted2blue is offline   Reply With Quote
Old 09-25-2012, 07:41 AM   #2073
jdawg81's Avatar
Looks I bought the wrong gears because I got 48 pitch and you guys must be using 64 pitch because I noticed those were smaller in diameter. I can't even get my gears to fit.
The guy in the shop recommended 10K wt diff oil for the rear. Is that ok or is it too high? I'm using 120k up front so I think that's ok but for the rear i'm seeing people using 1k oil.
jdawg81 is offline   Reply With Quote
Old 09-25-2012, 09:32 AM   #2074
I always use between 800 and 1200 in the rear.
Old 09-27-2012, 03:06 AM   #2075
carborush's Avatar
yes you're right, and no you're not.
LRP LiPo Hyper Pack 4000 - 7.4V - 25C - Stickpack Hardcase 227gr
Turnigy nano-tech 6000mah 2S2P 65~130C Hardcase Lipo Pack 313g
86 gr saved. price is +- the same and no risk of loosing power quicker i'd say. (as long as your not running modified class or some super quick engine)
I once broke 5 pieces carbo reinforced in one race. And there was not one broken because of a big hit, all broke with a very small tap on the front wheel.
I have yet to brake my first plastic piece.
you're correct that some pieces are located in places that are not so vunerable. but then you loose only max 10gr in weight, it costs much more.
all just to gain some extra stiffness ? + you have a much higher risk for broken pieces.
I'd say it's just not worth it... altought I must admit it's fun to tune the chassis like you did, looks superclean to say the least !
Old 09-27-2012, 09:13 AM   #2076
Skitee's Avatar
Here's a video of the Super Stock A main from our local Tamiya Cup Finals in South Africa. TA-06 1ST and 3RD
+ YouTube Video
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 10-01-2012, 03:44 PM   #2077
Trader Rating: 46 (100%+)
Tamiya TA06 Pro
If anybody is interested in a TA06 pro, please PM me. Thanks.
Yellowtaro is offline   Reply With Quote
Old 10-01-2012, 11:33 PM   #2078
Anyone raced the TA-06 with the Exotek chassis conversion? Racing mine for the first time this weekend in 21.5 interested to hear any reports from others with the same kit.
ript is offline   Reply With Quote
Old 10-03-2012, 03:26 AM   #2079
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
Does anybody know (or can measure for me) the distance from the centre of the pin hole to the bearing shoulder on the TA06 Tamiya gear diff outdrives?
dontfeelcold is offline   Reply With Quote
Old 10-03-2012, 04:28 AM   #2080
The attached picture describes the measurement I need a little better.
Old 10-03-2012, 04:38 AM   #2081
Josh
See craig, im pretty sure he just used the long side out of the 417 diff outdrives.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-03-2012, 05:14 AM   #2082
I was hoping the TA05/06 outdrives were the same as then I would only need to buy one packed of outdrives, not 2.
Old 10-03-2012, 09:03 AM   #2083
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Default TAMIYA got it right.
Ok,here is an observation.
Two of my good friends,Andy Cooke and Heath Murray are both running these,one in mod,one in stock.
Tamiya have got it right with the battery down the centre of the chassis.This makes the car grip,and roll superbly.
I have a serpent s411,I've had X-rays,losis,Corallys,old serpents and they are all basically the same car.
I just think this car is going to be the "correct" design to follow.
Regards you lucky Tamiya owners,
Tim Phillips
P.S.Anyone wanna swap for an over-engineered Corally RDX Phi09?....lol
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 10-04-2012, 02:01 AM   #2084
08TBSS's Avatar
The chassis is definitely stiffer and snaps a lot more out of the hole but that's how mine was setup. For this weeks race ive dialed the car back to what I would consider a starting point and I'm looking to adjust from there. After my first series in GT3 (silver can) I moved on to GT2(17.5), and what worked in GT3 hasn't translated too well for GT2. Hopefully I can get the car dialed so I can be a little more competitive in this newer class.
08TBSS is offline   Reply With Quote
Old 10-12-2012, 09:00 PM   #2085
williamsfw2427's Avatar
Send a message via Yahoo to williamsfw2427
I'm not sure I'm asking this in the right place but here goes. I've been looking at the TA 06 pro and was wondering if its a competitive car ? I'm not sure I'd even race it. I would like too trying my hand at drifting but if I did want to race touring cars at the local track would it at least do ok in say a stock class? I just don't want to buy a drift car and if not for me be stuck with a car that can't hit the track...
B4.1, B5M, SCX10, RC8T, Bomer RR10, TA 06, TT-01E, SC10, SCT410
williamsfw2427 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
