Like Tree1Likes
Old 04-21-2012, 08:09 AM   #1876
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by cementsurfer86 View Post
I have a killer VTA setup for the 06: (Carpet)
3k in the rear
Spool up front
40wt all around
Kit white springs all around
silver rr swaybar
pink ft swaybar
2 degrees camber all around
1 degree toe out up front
The car is on rails with this setup and is a blast to drive, fast too.
I removed my front sway bar due to slight rubbing that was affecting my handling. Do you have this issue?
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 04-21-2012, 11:40 AM   #1877
3k in the rear
Spool up front
40wt all around
silver rr swaybar
pink ft swaybar
Are you running IFS or stand up
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 04-23-2012, 08:43 PM   #1878
Alright... I got this baby pretty balanced and light.... First, the tamiya stock center shaft is..well, I sold It when I sold my spares... The lightweight tamiya one is .5 grams. The 3 racing ff3 shaft is .8 g.
My corners are as follows:
Fr-310.7
Fl-320.3
Rr-384.8
Rl-345.2
Total:1361
Btw, thats with exotek ifs setup, alum bulkheads,alum rear uprights, alum steering, alum center stiffener, body and tamiya mounts, and east coast 200 mm wing! I'm sure if i stuck to all plastic, I can get to 1300...
I can adjust the suspension to balance it a bit...
Old 04-23-2012, 08:49 PM   #1879
Did you use 3-4 electronic scales to measure the car's weight distribution? I saw there is a scale that has a LCD controller that comes with 4 different scales, have you tried it before?
Own Team Associated TC6.1 & XRAY T3 2012
LRP Vector X20 Modified - 4.5T
HobbyWing Xerun 120A ESC
Shop at RC-Mushroom & Tower Hobbies
"There is no best way of tuning a car, all depending on your driving style"
edwardcs is offline   Reply With Quote
Old 04-23-2012, 09:16 PM   #1880
Harbor freight sells scales for 14.99 I got them on sale for 9.99 plus 20% off. I bought 4.
Old 04-23-2012, 11:38 PM   #1881
cementsurfer86's Avatar
I'm assuming that you're talking about the ball cups hitting the CVD?
I moved the cup out so that it's just a hair inside of flush with the end of the sway bar, works good and no rubbing.
Tommy, as of right now I'm running stand-up. That setup is my most current with the stand up shocks.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is online now   Reply With Quote
Old 04-24-2012, 01:21 AM   #1882
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by VooDooPH View Post
the tamiya dcj's look a bit short for the TA06 (stock is 46mm)... will test fit a set on mine and take pix...
finally took the pix...
they fit but look to be a bit too short... a bad enough bump and you'll have an axle pulled out of the outdrive...
pic on the left = 44mm tamiya DCJ
center pic = both axles
pic on the right = 46mm stock axle
Tamiya Ta06-220420121287.jpg   Tamiya Ta06-220420121286.jpg   Tamiya Ta06-220420121285.jpg
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-24-2012, 06:13 AM   #1883
redzone's Avatar
Tamiya are about to release a 46mm shaft for the DCJ part number 42230
79 mk1 Sand Scorcher, 09 Buggy Champ, TB01 Lancer Evo 7, TL01 Lancer Evo 6, TA02 Castrol Celica, TA02SW Taisan Porsche, TA02W Castrol Supra, TA03F Starion drifter, M06pro Gemini coupe, Tamiya Dyna Storm 5.5t, Stadium Blitzer, Bear Hawk, Baja FAV, Egress!
redzone is offline   Reply With Quote
Old 04-24-2012, 11:28 AM   #1884
BJS414 is offline   Reply With Quote
Old 04-24-2012, 12:56 PM   #1885
Thanks I'll give it a try .Right now I'm all messed up haha
Overgeared Racing
GH Racing
Old 04-24-2012, 04:22 PM   #1886
I was able to reinstall it and clear the driveshaft. Thise shafts look heavy.
Old 04-24-2012, 05:14 PM   #1887
I ran the IFS setup for quite awhile, and the car was pretty fast with that as well, but the problem I had was keeping the slop out of the moving parts. The cups wear out and create dead space in the front suspension if not kept up. The other problem I had was I didn't have the Alum. rocker arms, those are a MUST. The plastic rockers develop slop almost immediately.
I've just found the upright setup to be more consistant at the moment. I will have to try the IFS again soon though.
If you PM me your email I'll send you a copy of the full setup sheet. It's a great starter setup to build from.
Old 04-24-2012, 11:22 PM   #1888
selling one of my ta06 pros all hopped up. maybe selling the other soon as well. but heres the on on rctech i just posted today.
FS Tamiya Ta06 Pro/Many Hop Ups must see
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 04-26-2012, 10:02 AM   #1889
kwkride's Avatar
Last night was much better for my TA06.
I was back in the "A" and managed a 3rd overall.
I'm now running about 4mm of droop front and rear,
I changed the rear toe to 2.5 degrees,
and I added 1mm spacers under the rear upper arms where they mount to the chassis.
I am running blue springs in front and yellow in the rear.
I also changed out the shock oil, 40w in front, 30w in the rear.
I no longer have the issue with the rear being very loose.
Now I just need to work on making the handling a little sharper.
It felt like the handling was sluggish.
Thanks for the help on tracking down issues.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 04-26-2012, 08:43 PM   #1890
I would maybe try 40wt in the rear. That should make it a little more crisp. With all the weight seeming to be mostly to the rear, that's what I found would help.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
