Old 04-06-2012, 10:51 AM   #1816
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by VooDooPH View Post
Might help...
Front:
Blue springs
50wt oil 3-holed pistons
6mm droop
c-c blocks
shock 2nd hole from innermost
Middle swaybar thickness
6mm hexes
long camberlink 4mm spacer
rear:
White springs
50wt oil 3 hole pistons
6mm droop
xa-d blocks
shocks 3rd hole from innermost
thickest sway bar
6mm hexes
3mm spacer on camberlink (inner)
Use inner hole on the bulkhead and shorter hole on the hub
I'm running no sway on front, heaviest on rear, 50wt all around yellow fronts blue rears, front spool,rear ball diff a little loose. I also changed all my balls to the flourine coated. I had signs of wear on the blue balls (that's what she said) and I decided to swap them out. The worst wear was on the ifs ball studs. My ifs link is very long to preload the dampers.
I would also reccomend putting more weight and a looser diff in the rear. The stiffer springs reduce the rear dive due to the additional rear traction.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 04-06-2012, 10:00 PM   #1817
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by @Art_Mighty View Post
What? No nuggets of wisdom from anyone?
Carbon shock towers front and rear
alum suspension blocks
Alum racing steering set
Alum hexes
Thick oil (300-500k) or putty for the front diff
Carbon reinforced arms chub and uprights
Swaybar set
My chassis is pretty much the stock plastic one
In this case woulden't you want a stiffer front / softer rear spring?
Ta06 is very heavy at the rear. Harder setting at the rear stabilizes it and prevents it from swinging around on corner entry. Keeps the rear planted when powering out of the corner as well.
Btw I'm running putty in the front diff and 2k oil at the rear.
Hths
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-07-2012, 09:36 AM   #1818
@Art_Mighty's Avatar
Carbon reinforced arms chub...
I'm not sure what part you're referring to. What page / step is it in the manual?
My chassis is pretty much the stock plastic one...
...interesting. I would have thought the stock unit would flex too much.
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 04-07-2012, 09:54 AM   #1819
VooDooPH's Avatar
Sometimes, flex is your friend.
Use the same arms, c-hubs, front and rear hubs as the 416/417. They're harder and sturdier than the stock plastic ones.
Refer to steps 14, 16, 18, & 20 (page 10 - 12)
Old 04-07-2012, 10:05 AM   #1820
Originally Posted by alcyon View Post
i think 3 degrees camber at the rear is too much. try reducing camber to 1.5 at the rear, and dont forget to check the suspensions tweak/ weight balancing.
camber 1.5 to 2 degrees and 2 to 3 degrees of rear toe in
Juan Aveytia is offline   Reply With Quote
Old 04-07-2012, 12:47 PM   #1821
Ironically it seems there is a tad more flex in the exotek than the graphite from tamiya...
Old 04-07-2012, 01:36 PM   #1822
So even in the "pro" version of the TA-06 chassis all of the plastics are the softer formulation? Interesting...
ALL IS LOST
Old 04-07-2012, 01:38 PM   #1823
Originally Posted by kwkride View Post
I think that you should get some of the carbon reinforced pieces.
You will find that with the stock plastic there is quite a bit of flex.
I would also suggest mounting a fan over the motor. They don't get much airflow with this chassis design.
Thanks for the heads up...
ALL IS LOST
Old 04-07-2012, 01:39 PM   #1824
kwkride's Avatar
Yes
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 04-07-2012, 01:51 PM   #1825
The upside to geting the pro is:
Alum turnbuckles
Alum dampers
alum ball ends
HD low friction ball cups
I wish I woulda gone without the PRO and just got the TRF dampers, TRF titanium turn buckles and flourine coated balls. I did it on the pro, (except the dampers) I just spent money i didnt need to...
Old 04-07-2012, 05:57 PM   #1826
Alum turnbuckles
Alum dampers
alum ball ends
Are the universals in both the pro and non-pro kits?
ALL IS LOST
Old 04-07-2012, 06:22 PM   #1827
I believe so. Check the manual on tamiyas site.
Old 04-07-2012, 07:38 PM   #1828
kwkride's Avatar
No, the non-pro has regular dog bones.
Jim
Old 04-07-2012, 09:21 PM   #1829
Better yet, get one light weight and one regular...
Old 04-08-2012, 12:39 AM   #1830
In the UK, the Pro with a Tamiya shell only works out to be about 10 more expensive than the base model...
DA_cookie_monst is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
