Like Tree1Likes
Old 04-05-2012, 08:41 AM   #1801
alien rc's Avatar
Well you're right...
--> It's just because my diff housing is not dead so I don't need to replace it.
Let's see the Spec-R price cause it will be my solution...
FB : ALIEN R/C
www.alienracing.fr
alien rc is offline   Reply With Quote
Old 04-05-2012, 10:01 AM   #1802
kwkride's Avatar
I am having an issue with the setup of my car. It's the "regular" TA06 with TRF shocks, CVDs, and all of the carbon reinforced pieces for the chassis. I am using the stand-up shock configuration. I am running it in VTA with a 25.5.
When coming out of a corner, I need to wait until the car is straight before getting back on the power or the rear end will swing out. If it's a high speed corner, I can stay on the throttle and it holds fine, it's just when trying the accelerate out of a turn.
Another local guy has a TA06 Pro with lay down shocks and he is having the same issue. He is running his in USGT with a 21.5.
Any suggestions?
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 04-05-2012, 10:16 AM   #1803
@Art_Mighty's Avatar
Default Considering a TCS Build...
Hello everyone,
I'm considering building up a TA-06 as a TCS GT2 car for both carpet and asphalt events. Other than making sure I get the TA-06 Pro chassis, what addition hop-ups should I be budgeting for?
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 04-05-2012, 02:57 PM   #1804
wish i could help but im new and im building mine for drift
Fleshlight is offline   Reply With Quote
Old 04-05-2012, 04:08 PM   #1805
Any suggestions?
Post your set up and track conditions
Juan Aveytia is offline   Reply With Quote
Old 04-05-2012, 05:50 PM   #1806
kwkride's Avatar
Medium/high grip carpet
upright front shocks
yellow springs front and rear
40wt shock oil front and rear
5mm ride height
86t spur
46t pinion
2 degrees toe out
3 degrees neg camber front and rear
100,000 diff oil front
"kit" diff oil rear
Jim
Old 04-05-2012, 09:23 PM   #1807
5mm ride height
86t spur
46t pinion
2 degrees toe out
"kit" diff oil rear
Carpet set ups for Tamiya are usually like this:
Tamiya whites up front and blues in the rear. Usually 60w up front and 40w rear. You may want 50w in the rear. Long camber links. No toe out in the front and 2 to 3 degrees in the rear. Run CC blocks up front and xa in the rear and go from there. Heavy sway bar up front and light sway bar in rear. Start the shocks in the middle hole and experiment moving them up and down. Ride height is set to 5mm. And droop 6 and 5. Try this and see how it works. Tire prep is very important on carpet. I like spools up front over a different.oneways are fast on carpet also. Hope this gets you in the right direction
Old 04-05-2012, 10:32 PM   #1808
alcyon's Avatar
i think 3 degrees camber at the rear is too much. try reducing camber to 1.5 at the rear, and dont forget to check the suspensions tweak/ weight balancing.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 04-06-2012, 03:05 AM   #1809
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Might help...
Front:
Blue springs
50wt oil 3-holed pistons
6mm droop
c-c blocks
shock 2nd hole from innermost
Middle swaybar thickness
6mm hexes
long camberlink 4mm spacer
rear:
White springs
50wt oil 3 hole pistons
6mm droop
xa-d blocks
shocks 3rd hole from innermost
thickest sway bar
6mm hexes
3mm spacer on camberlink (inner)
Use inner hole on the bulkhead and shorter hole on the hub
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-06-2012, 03:44 AM   #1810
Any suggestions?
All of the suggestions here are spot on. Personally I would start by increasing the front droop first. I have found that tamiya cars are especially sensitive to droop changes...
ALL IS LOST
Old 04-06-2012, 04:08 AM   #1811
kwkride's Avatar
Thanks for the suggestions. I'll try some of them next week.
I don't have swaybars for it. It looks like maybe I should buy a set.
Jim
Old 04-06-2012, 08:52 AM   #1812
Originally Posted by @Art_Mighty View Post
Hello everyone,
I'm considering building up a TA-06 as a TCS GT2 car for both carpet and asphalt events. Other than making sure I get the TA-06 Pro chassis, what additional hop-ups should I be budgeting for?
What? No nuggets of wisdom from anyone?
ALL IS LOST
Old 04-06-2012, 08:55 AM   #1813
Originally Posted by VooDooPH View Post
Might help...
Front:
Blue springs
6mm droop
c-c blocks
6mm hexes
rear:
White springs
6mm droop
xa-d blocks
thickest sway bar
6mm hexes
In this case woulden't you want a stiffer front / softer rear spring?
ALL IS LOST
Old 04-06-2012, 08:57 AM   #1814
kwkride's Avatar
Hello everyone,
I think that you should get some of the carbon reinforced pieces.
You will find that with the stock plastic there is quite a bit of flex.
I would also suggest mounting a fan over the motor. They don't get much airflow with this chassis design.
Jim
Old 04-06-2012, 09:40 AM   #1815
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Absolutely right.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
