Old 03-12-2012, 10:15 AM   #1726
lightfoot's Avatar
question...
Is there any tricks specific to this chassis to help free it up ? Other then the usual cleaned and lightly oiled bearings, and making sure nothing is binding, ect...
My chassis just doesn't seem to be as loose as my other sedans...
Thanks for any kind of advice...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 03-12-2012, 03:43 PM   #1727
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by lightfoot View Post
question...
you're running the exotek right?
I have put .3 mm shims under the screws that support the steering uprights. I also changed the gear and shaft in the transmission to the 3 racing alum FF03 one. (same size, legnth and teeth.)-no one will know unless they request you to take apart your transmission it reduces the heat in the transmission, and the gears dont expand as much due to heat.
A personal "trick" i have done was I used the 1mm spacers to raise the rear suspension only. It helps the rear slide out a little more.
I have also used a TON of ceramic grease in the diff. i coated each gear and installed them. there are some spots where it accumulates and will drip onto the gears.
I have changed ALL ball joints to the the flourine coated ones.
As far as setup, I have put 3mm spacers on the diff side of the camber adjusters
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 03-12-2012, 04:57 PM   #1728
question...
Check your belts. They might be too tight. My exotekracing chassis is extremely free
Juan Aveytia is offline   Reply With Quote
Old 03-12-2012, 05:10 PM   #1729
lightfoot's Avatar
Thanks guys... I will go through all this when I get home tonight...
Love and Peace...
Old 03-12-2012, 05:44 PM   #1730
Originally Posted by Fleshlight View Post
after trolling a little and following silverhkswrx i am going to order a pro really soon. I just need to decide on controller, servo, speed control ect........im so confused and new to everything.
I was looking at the kit combo on tower hobbies which i tried to link but cant yet due to posts. Do you guys think its a good kit?
Also il take any help as above others stated their setups
Silverhkswrx do u have a wrx? just sold my modded 11 STi sedan im deploying
any thoughts? or answers?
Fleshlight is offline   Reply With Quote
Old 03-12-2012, 05:47 PM   #1731
Juan, I could not agree more. The factory is tight, the eagle racing is very tight. Like so tight, the chassis flexes. The exotek is loose.
If you run the kawada belts, they're even tighter.
Old 03-12-2012, 06:19 PM   #1732
kwkride's Avatar
A lot of this will depend on what class you're planning to run.
Do you know yet?
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 03-12-2012, 09:28 PM   #1733
Buy a ta06 pro off eBay. By far the cheapest. As far as remote, I prefer spectrum. Never had any issues and it's user friendly. Motor/ speedo/ servo are all your call. I reccomend light with a tq of atleast 80. Motor/speedo depends on your class.
As far as the wrx, I had a 02 rhd Sti s202.(bug eye) it had a greddy t518z 750 cc primaries and 500 cc secondaries pushing 550 Awhp on 93 octane @27 psi. I sold it in 05.
Old 03-13-2012, 06:33 AM   #1734
Originally Posted by DA_cookie_monst View Post
I have not had the need, as it don't roll anywhere near as much as the TA05 did.
Thanks guys for the info...
Now you guys have own 417 as well as ta06, which one do you prefer to use when you have ta06 w/exotek compare to 417?
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 03-13-2012, 10:55 AM   #1735
+1 I tried all the belts, but I went back to the stock ones. too bad, I really liked the Kawada ones since they are more flexible, but just way too tight.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 03-13-2012, 12:13 PM   #1736
Do you know yet?
i will not do any competing at least for a while as there is nothing around me and im no good lol
Old 03-13-2012, 12:29 PM   #1737
samshirley00's Avatar
are there any non aluminum front steering hubs that are compatible with this thing, that ship to the uk? i think i have fucked up the threads on mine
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 03-13-2012, 05:46 PM   #1738
Tsquare's Avatar
Default Is this car better for 17.5 vs TA05 VII
Need some help.
After reading through most of this thread over the months - I am not feeling the love for this chassis as the previous TA0 series chassis's - What am I missing? Is it just not an improvement over the TA05 series?
Question - I am looking to run Tamiya Gt2, is this the car to use, or would I be better served running my current TA05 VII?
Or is this car better for GT1?
Thanks for the advice
_______________________________________________
Tamiya: | TA05 IFS V2 | FF03 Pro | M05 Pro | TRF201X |
Associated: | TC5R | SC10 FT |
Tsquare is offline   Reply With Quote
Old 03-13-2012, 07:09 PM   #1739
kwkride's Avatar
I have been running a TA05-R for over 3 years, I also have a TA05 V2.
I have been running the TA06 in VTA for a few weeks now and I am really liking it.
I guess whether or not you build one and run it in GT2 depends on how much time you've got to get it set up. I built my TA06 with stand up front shocks and I am having an easier time getting it tuned to our track. Your results may vary.
Jim
Old 03-14-2012, 01:31 PM   #1740
Tsquare's Avatar
Thanks for the reply, In the past when Tamiya released a newer version of an existing chassis, the thread would get filled with evaluations and comparisions vs the older version - I haven't seen this with the TA06 - makes me think the TA06 may have been a dud.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
