Old 03-11-2012, 09:29 AM   #1711
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Juan Aveytia View Post
Car is much slower all the way around. Stick with the full size packs
+1. there is one that is from orion that you can adjust the weight ballaststo balance better that i am interested in trying out.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 03-11-2012, 09:31 AM   #1712
Originally Posted by Johnn27 View Post
Who makes the rear chassis brace/fam holder is that part of the exotek conversion or is it ma 3racing peice?
eagle racing. best $8 ive ever spent.
Old 03-11-2012, 10:09 AM   #1713
Johnn27's Avatar
Trader Rating: 68 (100%+)
Where can I get one of those?
Johnn27 is offline   Reply With Quote
Old 03-11-2012, 10:20 AM   #1714
bencason's Avatar
Default TA-06 outside?
I am considering buying a TA-06 Pro for a summer racing series in a parking lot.
  • How does the TA-06 perform on low-medium traction asphalt?
  • Does high heat/humidity affect it any more/less than other TC?
  • Are there any problems with debris getting in the belt/pulley system?
  • Any thoughts on "must-have" up-grade parts? I've seen mention of a "chassis stiffener" but I'm not sure where it installs. If it limits flex, it may not be useful to me on the outdoor asphalt.
My plans include purchase of some spares such as:
  • C-hub carriers,
  • steering uprights,
  • suspension arms.
Are there any spares that are likely to break on hard hits that I have missed?
There is no LHS associated with the series so I have to bring spares. I do have a LHS kind of near home and mail-order, of course.
thanks for any/all responses.
The RC cars are in storage but not forgotten
One of these days, I'll be back to racing... somewhere
bencason is offline   Reply With Quote
Old 03-11-2012, 12:55 PM   #1715
Default TA06 Pro Equipment
Originally Posted by Fleshlight View Post
what servo, motor and speed control are most of you running with it? also what radio? does any of that even come with the kit because it doesnt look like it? Im going to order everything soon.
I'm using top of the line stuff:
Futaba FASST, 4PK
Futaba BLS451
Tekin RS
Trinity D3, 13.5BL
Reedy 5000 LiPo
red7fifty is offline   Reply With Quote
Old 03-11-2012, 01:02 PM   #1716
  • C-hub carriers,
  • suspension arms.
Are there any spares that are likely to break on hard hits that I have missed?.[/QUOTE]
Add rear hubs too, and some bearings.
TIP: The front lower knuckle screws....pull out easily or break out the steering upright mounting hole, because they are 1.5 mm too short. Change these out to slightly longer ones, so the threads just go flush on the inside. Be careful... too long, and they will interfere with the cvd and pop off the retaining clip. The kit supplies with flat head screw. I just changed out to longer cap head, and added a washer (for clearance) and have not had that issue since.
Old 03-11-2012, 01:35 PM   #1717
I got mine off some guy off ebay, this is where you can buy it regularly.
http://www.broadtech.hk/eagleshop/sh...spx?id=TA06-15
I bought tons from them; front & rear bulkheads, rear cf tower, c hubs, rear knuckles, carbon chassis(which i am currently selling- unused, but opened [on ebay] ) VDF ackerman arm extenders, ta05 weighted bumper ( for drift) among other things.
I just sugguest the ems shipping it gets stateside in about 10 days, otherwise it takes about 27... I am impatient.
Old 03-11-2012, 01:49 PM   #1718
Futaba FASST, 4PK
Futaba BLS451
Tekin RS
Trinity D3, 13.5BL
Reedy 5000 LiPo
Spektrum DX3R
Hitec HS-7966HB
Speed passion 7.5R
Speed passion GT2.0
Venom 5000 50c LiPo
Old 03-11-2012, 02:29 PM   #1719
bencason's Avatar
Thanks, I hadn't read about those. I'll add them to my list and make the screw change if I get get a TA-06.
Old 03-11-2012, 03:12 PM   #1720
If you get one, get the TA06 PRO, instead of the standard TA06.
With the PRO, you get:
CVDs (instead of dogbones)
TRF Threaded Alum Shocks (instead of plastic preload spacer shocks)
The Aluminum turnbuckles are a double edge deal.....I like them, but my friend has bent 3 of them (so far). But, that is an easy swap, for some similar length Traxxas steel turnbuckles (cheap), or some Associated Titanium equivalents.
Although, with the PRO kit, you also don't get a body (which, btw, won't handle as well as a Protoform race body) or a stock 540 silver can.
Old 03-11-2012, 04:04 PM   #1721
bencason's Avatar
If I get one, it will be the Pro. I'm looking for a used TC first, to save money, but want something that will share parts with my TA05. As you pointed out, the shocks and CVD are worth the extra money and less than buying the parts later. I'd replace the turnbuckles with steel, I bump into things [or occasionally someone bumps into me] so I need the extra strength.
The class I am planning on running is a spec silver can type class with race truck bodies [something different ] and probably VTA wheel/tires or something like that. So, the lack of tires/body/motor is no big deal.
Old 03-11-2012, 08:54 PM   #1722
Default TA 06 Stabiliser
Hi Guys..
is any of you guys put stabilizer on ta06?
are they the same as 417?
can you guys give me the manual on putting stabilizer on this car..
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 03-11-2012, 09:29 PM   #1723
Originally Posted by k4mp4q View Post
Hi Guys..
thanks
its a different diameter. marc reinhard uses the ta06 bars on his tc.
Old 03-12-2012, 12:16 AM   #1724
Hi Guys..
thanks
I have not had the need, as it don't roll anywhere near as much as the TA05 did.
DA_cookie_monst is offline   Reply With Quote
Old 03-12-2012, 09:58 AM   #1725
after trolling a little and following silverhkswrx i am going to order a pro really soon. I just need to decide on controller, servo, speed control ect........im so confused and new to everything.
I was looking at the kit combo on tower hobbies which i tried to link but cant yet due to posts. Do you guys think its a good kit?
Also il take any help as above others stated their setups
Silverhkswrx do u have a wrx? just sold my modded 11 STi sedan im deploying
Fleshlight is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
