Old 03-04-2012, 10:12 AM   #1696
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Shameless121 View Post
Green slime is a huge help absolutely I think everyone should have it in there tool case. And yes I bent up the front turnbuckles really bad and went titanium on all the steering and adjusting ones. I'm debating though on getting the carbon chassis by VBR racing or possibly the exotek one. It's just the battery load is highly inconvenient you either use the batteries with the deans connections that come from the corners or you have to use the posts and make sure the terminals are far enough apart to fit it once the battery is loaded.
I had the Eagle racing and I liked it. It shaved weight, but no where near as much as the exotek conversion. I am currently selling my Eagle racing carbon conversion (plus some other eagle racing/exotek spares that I recieved in a bundle) Eagle racing builds thier kits and they over-torqued 2 screws and i stripped it, i had to dremel a flat line for a flathead to grab, and there are 2 tiny nicks on 2 of the holes.
The only 2 issues I have with the Exotek conversion is 1: the upperdeck is not level with the lower deck. it opens towards the front. and 2: the steering was binding. I remedied this by placing a .5mm tamiya aluminum shim under the 2 screws that hole the upper steering post support. now its smoother than factory and there is no play.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 03-06-2012, 04:34 AM   #1697
Default C-Hub question
Hi Guys..
I have bought ta 06 pro and running fot tcs on sunday, i love the car..but i crash during turn and broke my c-hub...
my question is, will it be posibble to use 417 part? to replace part c, e and f?
since 417 is carbon where ta 06 is plastic....
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 03-06-2012, 04:39 AM   #1698
kwkride's Avatar
Originally Posted by k4mp4q View Post
Hi Guys..
thanks
If you want the carbon reinforced c-hub, you need part #54031
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 03-06-2012, 07:26 AM   #1699
bencason's Avatar
It has been my experience that the carbon-reinforced c-hub is more likely to break than the normal plastic one. It may be more rigid for more precise function but will break on a hard hit where the normal plastic just flexes and survives. Since I am still sharpening my driving skills, I hit things all too often, so I use the normal plastic c-hub
These are normal plastic:
part #51293
To the best of my knowledge, they fit the TB03, TA05, TA06, 416/417.
The RC cars are in storage but not forgotten
One of these days, I'll be back to racing... somewhere
bencason is offline   Reply With Quote
Old 03-06-2012, 09:22 AM   #1700
TB-03 or TA05-VII parts are the same.
DA_cookie_monst is offline   Reply With Quote
Old 03-06-2012, 09:42 AM   #1701
samshirley00's Avatar
i have yet to break them on my ta06, but if i do, i will probably get some aftermarket aluminium ones like this
http://broadtechonlineshop.com/eagle...l.aspx?id=3468
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 03-06-2012, 09:25 PM   #1702
Johnn27's Avatar
Trader Rating: 65 (100%+)
Thumbs up Shorty Lipo
Hey,
Has anyone tried the shorty lipo in this car with what results and can you tell me what works best,placing the lipo towards the front of the car or the rear???
Thanks!
Johnn27 is offline   Reply With Quote
Old 03-06-2012, 10:09 PM   #1703
Originally Posted by Johnn27 View Post
Hey,
Thanks!
Car is much slower all the way around. Stick with the full size packs
Juan Aveytia is offline   Reply With Quote
Old 03-07-2012, 01:42 AM   #1704
part #51293
Thanks a lot guys for the input...
Another question is...is it better of using ta 06 wide or 417 wide....since I'm goin to use ta06 for tc, but the body will be 190mm, so if I use ta06 then the wheel will be inside...
The reason I asking is I have know idea what is the diferent in tracke width with handle of the car? Is it easier to drive with wider tracke wide or shorter...
Thanks in advance...and sorry for my english..hope everyone understand..
Cheers
Old 03-07-2012, 09:15 AM   #1705
Hey,
Thanks!
If I had to use a shorty, I would put it towards the front, as the weight of the motor at the rear might make it balanced a bit better.
I use a full size hard case in an eagle racing conversion, and it seems fine
Old 03-07-2012, 10:04 AM   #1706
Johnn27's Avatar
Thanks Sam! it is just something I am thinking about trying to play with the balance of the car before I play with weights!
Old 03-09-2012, 03:31 PM   #1707
Do not get those. 3Racing and Yeah racing make some. the tops can use bearings or bushings and one good tap, the bearing is seized. besides, those are for drifting. 8* ackerman and 8* camber. i run 3 racing arms from a 417 and hubs for a TB03D
this is when I HAD the EacleRacing Chassis. I now have the Exotek.
See, i USED to use them for drift. +12mm offset wheels rear and 10mm fronts...
this is MY baby...
Old 03-09-2012, 06:10 PM   #1708
redzone's Avatar
just ordered my TA06 pro kit form stella, got it with the diff cross bars, crp main deck and sway bars.
hoping the crp main deck will be enough to stop the belt stretch when i fire it up with the mamba 7700kv combo i have planned for it...
79 mk1 Sand Scorcher, 09 Buggy Champ, TB01 Lancer Evo 7, TL01 Lancer Evo 6, TA02 Castrol Celica, TA02SW Taisan Porsche, TA02W Castrol Supra, TA03F Starion drifter, M06pro Gemini coupe, Tamiya Dyna Storm 5.5t, Stadium Blitzer, Bear Hawk, Baja FAV, Egress!
redzone is offline   Reply With Quote
Old 03-10-2012, 11:03 AM   #1709
Johnn27's Avatar
this is MY baby...
Who makes the rear chassis brace/fam holder is that part of the exotek conversion or is it ma 3racing peice?
Old 03-11-2012, 07:07 AM   #1710
what servo, motor and speed control are most of you running with it? also what radio? does any of that even come with the kit because it doesnt look like it? Im going to order everything soon.
Fleshlight is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
