Old 03-01-2012, 08:04 PM   #1681
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by cementsurfer86 View Post
Gear diff works great, the issue I still have is keeping fluid in it. It still seems to seep out of the o-rings. I'd like to try the ball diff to see how that feels, but the gear diff works pretty dang good. Maybe someone can chime in on the ball diff.
Ball diff has yet to fail me(running 7.5r boosted) I don't like the leaks and tge fact tgat I have to refill and take apart about 1/3 the car to do so. Only issue is if a part breaks, there are no spares on the market. You need to buy a whole new diff.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 03-02-2012, 11:25 AM   #1682
Gear diff front ball diff in the rear. I replaced the original diffs and seals two times prior before switching out to thicker oil and the ball diff. Seems the rear was shot after about a 5 minute practice. Working on proper gearing still I've almost perfected it on carpet. Setup is still slightly off. But ta06 pro with just about every upgrade I can get on it handles well.
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 03-03-2012, 02:05 AM   #1683
I have to say, my Pro is almost kit stock, except for springs and suspension blocks, and it is running on foams and is absolutely dialed, no hop-ups or stiffer parts. My only grumble has been the rear diff, seams to be able to retain fluid as well as a bucket with small holes.
DA_cookie_monst is offline   Reply With Quote
Old 03-03-2012, 05:49 AM   #1684
Ive said from day one... The rear diff needs 2 o-rings for the outdrives instead of one.
Old 03-03-2012, 07:56 AM   #1685
Thumbs up
Is that 2 per side? No binding or anything?
I'll try it thanks
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 03-03-2012, 08:06 AM   #1686
I'll try it thanks
Yep, 2 per side. There is slight bindage. I also used the hpi red o rings. They're stiffer and a little thinner.i lubed them prior to install to reduce the binding.
Old 03-03-2012, 10:58 AM   #1687
He is saying for the seal that's green that seals the gear up completely. I tried two works ok. The ball diff is much better I know it costs 40 or so but to not have to remove the entire back of the car everytime you blow out a stock diff is much better. I have sway bars front back, all aluminum blocks, all titanium tie rods ( this was learned the hard way unfortunately), etc
Old 03-03-2012, 11:26 AM   #1688
Red face
I bent mine too.... I had a 20% coupon to a store and bought all titanium turnbuckles, And the tamiya coated ball joints. Now that I think about it... All of my chassis is upgraded. I just need another and dampers for it.my son wants one so....
Old 03-03-2012, 01:01 PM   #1689
kwkride's Avatar
I used Green Slime on the gaskets and o-rings when I assembled my diffs and haven't had a problem yet.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 03-03-2012, 02:00 PM   #1690
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
question to TA06 owner
how it is compare to TA05 V2 on the track?
OVA is offline   Reply With Quote
Old 03-03-2012, 02:10 PM   #1691
Ta05 is lighter. Much lighter.its definitely noticeable. However this seems.... More balanced. It's also better handling.
Old 03-03-2012, 02:42 PM   #1692
OVA
OVA's Avatar
Are you saying it the TA06 is more balanced and handing better compare the TA05?
Old 03-03-2012, 04:08 PM   #1693
Handling yes. Balance, nO
Old 03-03-2012, 04:47 PM   #1694
I originally built the rear gear diff with black AE grease. Then I decided to use 1500 oil. I left all the AE grease on the seals and no leaks.
Juan Aveytia is offline   Reply With Quote
Old 03-04-2012, 02:18 AM   #1695
Green slime is a huge help absolutely I think everyone should have it in there tool case. And yes I bent up the front turnbuckles really bad and went titanium on all the steering and adjusting ones. I'm debating though on getting the carbon chassis by VBR racing or possibly the exotek one. It's just the battery load is highly inconvenient you either use the batteries with the deans connections that come from the corners or you have to use the posts and make sure the terminals are far enough apart to fit it once the battery is loaded.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
