Old 02-19-2012, 08:40 PM   #1651
cementsurfer86's Avatar
Originally Posted by DA_cookie_monst View Post
Grrrr, sounds like I have done a second set of rear diff gears!
What kind of horsepower are you laying down to burn up a diff gear???
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 02-19-2012, 11:05 PM   #1652
It's the internal gears sound like they have gone... again. Running 30mm wide foams on the rear on small carpet tracks with a boosted 13.5.
DA_cookie_monst is offline   Reply With Quote
Old 02-20-2012, 08:29 AM   #1653
samshirley00's Avatar
the fact its foams means there is a lot more stress on the geadbox, no slip. If they made metal gearing, it would help.
also, anyone know the exact belt lengths?
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 02-20-2012, 01:51 PM   #1654
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
As I mentioned before, Rspec and 3Racing make gears. Its just one gear, but it made a huge difference.
http://www.spec-r.com/default/index....roducts_id=177
or
http://os.3racing.hk/products.php?products_key=4990
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-20-2012, 04:31 PM   #1655
It's not really related to the internal gears, but I am suprised at how fast the main belt stretched on my 06. I can't really tension it any more because of how the wiring is routed. I've been running the car since December, twice a month. Odd, but not a huge issue I suppose.
Old 02-20-2012, 10:08 PM   #1656
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
not to bash but i've found myself blowing up gear diffs ever since i followed the instructional from Jilles (4 sets to be exact)... must be the way i drive or something. so i went back to my old way of doing it... for the crown gears, i just sand enough so that the spurs from the parts tree are removed. this way the crown gear is thicker. i also use a 0.3 shim (not the shims from the gear diff but the smaller one where the diameter of the shim is around same as the length of the pin). this way the gear diff seems to hold up better on boosted 13.5T and TAC-spec 12T.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-20-2012, 11:18 PM   #1657
It just looks like the teeth have been jumping inside the diff, now I got it all apart. I caught it sooner than last time. May do as you say, not to reduce the internal gear down and shim to remove backlash.
Old 02-21-2012, 04:45 AM   #1658
Originally Posted by cementsurfer86 View Post
Are you running IFS? if so, maybe the pushrod length is off. Those have to be spot on for both sides, or else the car does some weird stuff....
Ok thanks I will try to check the shocks and see whether that will solve the problem! Will caster help at high speeds?
Johnaye is offline   Reply With Quote
Old 02-21-2012, 08:05 AM   #1659
It will, but I haven't messed with caster yet on my car, still at stock settings, which i believe is 4 degrees.
Old 02-21-2012, 06:09 PM   #1660
Default batery size
Hi Guys..been reading this tread and I'm happy with all the information you guys give... But need information what is the max batere size can fit on the ta06
And also since I'm goin to use on small size carpet tract for tcs in indonesia.. Any setting that help my starting will be great...
Sorry for my english..hope u guys understand...
Cheers
k4mp4q is offline   Reply With Quote
Old 02-22-2012, 12:00 AM   #1661
K4,
2s batteries fit perfect, as that is the size that this car was intended for. I would recommend a battery with banana plug ports instead of the wires built in, seems to be a bit too snug otherwise. What class are you thinking of running?
Old 02-22-2012, 05:35 PM   #1662
[QUOTE=TommyAfrica;10044236]Gotta love the TUB car ,its so fun to drive it amongst all the high end chassis'
heres mine with all carbon reinforced plastics and most aluminum toe blocks and carbon rear tower .The battery compartment is awesome for tucking away wires .Keeps things tidy
Where/how did you get the right-side Steering Set? I've been looking for a set desperately.
rafyel is offline   Reply With Quote
Old 02-22-2012, 05:42 PM   #1663
Originally Posted by MC112b View Post
Ta daaa!! I still have to remount the servo, speddo, and re-scale the car.
I had to skim .005 off the outer chassis ridge. The button head screw on the underside of the rack gently rubbed. I think a small height adjustment and I'll have a truly dremmel free install. No cutting, no shimming, and zero extra slop. First run on the car is next Wednesday.
I should have some spares available this weekend.
How could get a set from you?
Old 02-22-2012, 10:28 PM   #1664
[QUOTE=rafyel;10368102]
hey rafvel i just flipped the arms left to right and cut and shave areas interfering with ifs rocker mounts and thats it no upgrade necessary and its worked fine with no breakage .take a look my pic and its pretty explanatory
also my servo is mounted with double sided tape and one servo mount block and drill with countersink bit on bottom
all connected together with a long steering connect from mini chassis
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 02-23-2012, 02:41 AM   #1665
I hope that some company makes a modded right hand side steering rack for sale, that would be nice!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
