Old 02-11-2012, 10:46 PM   #1636
stitchy's Avatar
It's a fun car to drive, that's for sure. Very different from all the current TCs out there too!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-12-2012, 09:02 AM   #1637
FNG RIDER's Avatar
Originally Posted by stitchy View Post
Hi Wayne. You're welcome! I actually enjoyed writing it and trying to recall all of the happenings of the race. I usually forget the details as soon as I come off the driver's stand
es
Give us a call anytime at the shop (626.237.0807), especially if you're set on what car and components you want so we can have it all ready for ya!
Look forward to meeting an old customer of Steve's
Ok! Its going take a while to secure funding because i will need everthing. After being out of the loop the TA06 appeared to look like just another Touring car. When I took a closer look, wow direct drive and single belt to the front, thats thinking out side the box! : )
RC10B5, Tekno 410 sct, TA05 v2 Reedy 17.5, Revolt 30, Seaport Tug, Axial SCX10 Rubicon ess sound system.
FNG RIDER is offline   Reply With Quote
Old 02-14-2012, 12:02 AM   #1638
Travis S's Avatar
Trader Rating: 46 (100%+)
Just showing an updated pic of the weight distribution after moving the speedo to the stock location and my quest for 50/50 weight distribution. The wiring is a pain in the butt however it is the weight is much better this way. I wish they made the steering reversible so you could flip the speedo and servo without having to mod anything.
Rear = 711.2g - 54%
Front = 606.4g - 46%
1317.6g
Travis S is offline   Reply With Quote
Old 02-14-2012, 02:45 AM   #1639
Originally Posted by VooDooPH View Post
would you know if a 43/44 pinion will fit with a 96t spur (will they mesh)?
Yes you'll have plenty of room to mesh but you'll need to check your fdr before hand. I'm running carpet track and I'm trying to grab a 4.0 fdr or close to it. I did change spur gears yesterday to a 92spur and stayed with the 50 pinion and I had enough room to back it off and mesh it properly. Ran fast and I got first so I couldn't complain.
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 02-14-2012, 03:53 AM   #1640
Johnn27's Avatar
Trader Rating: 69 (100%+)
Questions?? weight and springs
Rear = 711.2g - 54%
1317.6g
Because this car has slightly more weight in the rear do you find you are using a heavier spring in the rear versus the front ???
Johnn27 is offline   Reply With Quote
Old 02-14-2012, 05:24 AM   #1641
kwkride's Avatar
Not necessarily, I was running GT2 at the TCS race last weekend. I ended up with a set of ultra hard Tamiya springs on the front. Without them it was very loose off power. We'll see what happens Wednesday when it's back to my VTA setup.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 02-14-2012, 07:55 AM   #1642
cementsurfer86's Avatar
I've actually gone back to more of a kit style setup, 40wt all around and the stock medium springs all around. The spool makes it a blast to drive, although I'm not sure of makes it the fastest car in the bunch.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 02-14-2012, 09:37 PM   #1643
FNG RIDER's Avatar
Other than providing a low profile, I don't see the advantage of running the shocks cantilevered. Maybe a lower CG? If the cantilevered configurations was so great, why didn't Tamiy employ them on the 416 or 417? Upright would make making the bias toward the front a lot easier.
Given that I still may use the cantilevered set up just to be able to run the low profile Tamiya NSX body.
Ive used the NSX before. it make a big difference!
Old 02-18-2012, 04:33 AM   #1644
Default Unstable at high speed
Hi guys!
Just bought the pro kit and when I am at full throttle , the car tends to slowly veer to the side. Any way to increase stability at high speeds? Steering trim and the works are all set right.
Johnaye is offline   Reply With Quote
Old 02-18-2012, 07:55 AM   #1645
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Johnaye View Post
Hi guys!
I assume you are using the Tamiya reccomended esc/transmitter location? If so, Im assuming youre pulling to the left on acceleration. I noticed that on mine when I didn't balance out the front.
the rear tucks when accel more than any other tc ive ever driven. the servos weight seems to be causing it, when I used a lighter servo, it was less noticable.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-18-2012, 06:08 PM   #1646
Hi guys!
Your car sounds very tweaked. My car doesn't do any of that stuff
Juan Aveytia is offline   Reply With Quote
Old 02-18-2012, 09:17 PM   #1647
Hi guys!
Another thing might be different length shock and shock oil
I would check these first
There once I drove a whole day until the mains and was shocked to find one was oil-less. Haha pun intended
Overgeared Racing
GH Racing
TommyAfrica is offline   Reply With Quote
Old 02-19-2012, 12:23 AM   #1648
Are you running IFS? if so, maybe the pushrod length is off. Those have to be spot on for both sides, or else the car does some weird stuff....
Old 02-19-2012, 03:22 PM   #1649
Grrrr, sounds like I have done a second set of rear diff gears!
DA_cookie_monst is offline   Reply With Quote
Old 02-19-2012, 05:50 PM   #1650
3 racing and r spec both make an aluminum ff03 gear. Since I replaced the plastic one, my gears have stayed in tact!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
