Old 02-09-2012, 03:23 PM   #1621
Airwave's Avatar
Originally Posted by Travis S View Post
Car is all setup and ready to go!
Pic #1 - The car balanced out nicely. I did have to put about 30g in the front right. (RR 376.5g LR 378.9g FR 307.9g FL311.9g = 1375.2g)
Pic #2 - I did mount a Novak Ballistic motor. In the pic you can see the 3mm Tamiya motor spacer and I did still have to bend the tabs on the motor.
Pic #3 - All Ready for TCS! To bad I have another month to wait.
Are you sure these values are usable?
It seems that you leave the suspensions on the car, so the scales are displaying the tweak and not the mass repartition... Because your spring could have different pre-constraints..
Don't you think so?
Airwave is offline   Reply With Quote
Old 02-09-2012, 03:55 PM   #1622
Travis S's Avatar
Trader Rating: 46 (100%+)
Don't you think so?
This might be true. I just did the same thing but without the springs on the shocks. (I assume this would be more accurate.) The front was about the same. 305-310g range each side. Within a couple g's the rear was off more then I thought. The speedo side was about 45g more around 385g vs 345g on the other side. I would have thought the motor mount would account for more weight, but I guess not.
I will be moving my speedo to the front like they recommend. I just didn't like how long the wires need to be for that and mine were not currently very long from a past car. However, it would let me take out the weights I have there currently and should make it closer to 50/50.
A bit more: I guess the only really accurate way I can think of to measure this is if I had solid links where the shocks go so it had no give. I can tell from both ways with/without the springs that the rear is about 50g more at each rear wheel then the fronts in my current setup.
Travis S is offline   Reply With Quote
Old 02-09-2012, 06:48 PM   #1623
cementsurfer86's Avatar
I was kinda thinking that would be the case. I wanted to have the speedo on the driver-side, just for ease of wiring, but I assumed it would throw the balance off. It's a pain to route those wires, but I guess that's what you have to do to balance out the car.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 02-10-2012, 12:05 AM   #1624
Travis S's Avatar
Ok I did a bit more playing around and since a few people are interested in this I will post my findings. This is starting to become an obsession for 50/50 Front/Back and Left/Right weight distribution.
I moved my electronics around and the best balance I could get is how the kit shows it. (Go figure! ) I haven't gone as far as the re-wire yet, but when placing the electronics in the recommended place I came up with these figures:
LR - 344g
RR - 356g
RF - 290g
LF - 310g
Total = 1300g (No body and I took out the weights I had in the front right from the picture and have also changed to ti-scews and the graphite battery holder.)
So this is 54% weight in the back /46% front. Once again this is running the IFS so with the shocks all the way in the front I can see it being 52/48. Add that shorty lipo and mount it towards the front I am sure you could get the 50/50. I am tempted to buy one just to see if I can get to 50/50 running the IFS shocks.
Weights of my electronics:
Servo with screws: 60g
ESC: 57g
Battery: 274g
Rec: 13.5g
Motor: 175g (3mm spacer is another 5.5g)
Transponder: 5.5g
Old 02-10-2012, 12:36 AM   #1625
Anyone have a picture of a Novak Ballistic motor mounted in a TA06 and what they did to get it to fit. I saw someone recommend getting http://www.tqrcracing.com/shop/produ....asp?p_id=1817 but is 3mm enough to get this motor to fit? I can only seem to find them overseas. I am still waiting to get my TA06 I ordered and was really hoping to use this motor because I can change just the stators if I am going to run a different class and not need another whole motor. For example I am going to run GT2 (17.5 TCS) but after that is over I would like to use this as my 25.5 VTA car that is required to run a ballistic per rules.
Thanks for your help.
I've fitted the motor without modification on a 96 spur 50 pinion and the motor is completely to the front on the motor bay. The only way to go larger spur and pinion is going to be cutting into and modifying some of the support around the interior of it. I'm going to put in a 92 spur to get the Clearence so I'm able to have somewhat of a gap between the gears.
Your Hate Fuels My Success!!
If your not scraping... Then your not low enough!!!
TQ Raceway, WCRC, Speed Tech
Shameless121 is offline   Reply With Quote
Old 02-10-2012, 01:50 AM   #1626
sosidge's Avatar
Don't you think so?
The scales will always display the correct weight distribution if you sum the two loads on each axle (FR+FL & RR+RL).
Old 02-10-2012, 02:01 AM   #1627
sosidge's Avatar
LR - 344g
RR - 356g
RF - 290g
LF - 310g
ESC: 57g
Battery: 274g
Rec: 13.5g
Transponder: 5.5g
I suspect you are overestimating the difference the weight distribution change you can acheive with these changes... to put it into perspective, to add 1% proportionally to the front axle means you need to add ~27gm directly onto it, and if you are not adding ballast you need to be taking it away from somewhere else in the car. So to get 2% onto the front moving the IFS means adding ~54gm to the front axle... to put THAT figure into perspective, a pair of TRF shocks only weighs 25gm total, and you are moving them by about 25% of the wheelbase.
Same for the shorty LiPo, you get the opportunity to move some ballast around, but again you are moving it around a relatively small proportion of the wheelbase.
But - you are the one with a car in front of you and I only have maths and pictures to work with. You may well get that 50/50!
Old 02-10-2012, 02:37 AM   #1628
samshirley00's Avatar
any chance of pics of that, so we can see if there is anything weird....
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 02-10-2012, 03:12 AM   #1629
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
would you know if a 43/44 pinion will fit with a 96t spur (will they mesh)?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-10-2012, 06:32 AM   #1630
Originally Posted by MC112b View Post
Ta daaa!! I still have to remount the servo, speddo, and re-scale the car.
I had to skim .005 off the outer chassis ridge. The button head screw on the underside of the rack gently rubbed. I think a small height adjustment and I'll have a truly dremmel free install. No cutting, no shimming, and zero extra slop. First run on the car is next Wednesday.
I should have some spares available this weekend.
How/where can I get one from you?
rafyel is offline   Reply With Quote
Old 02-10-2012, 09:02 AM   #1631
Travis S's Avatar
The 2% was a guess. I figured you are adding the shock tower and the shocks over the top of the wheels so I thought it would add a 1-2%. This I don't plan on trying since I already have an IFS body and do not plan to buy a normal one for TCS races.
The shorty lipo's I have seen are around 200g vs the 270g's for my current lipo. So with no body my car would be 1230g. GT2 class is 1400g min for weight. I figure if you mounted the extra weights you will need to "make weight" in a small gap in front of the shorty lipo in the battery area you could get that 50/50. (GT1 class you can be as light as you want with a tubby chassis so I don't know if being 50/50 is better then being say 1300g.)
Old 02-10-2012, 11:23 PM   #1632
FNG RIDER's Avatar
Originally Posted by stitchy View Post
TA06 race writeup. Warning! Loooong
Iíve run the shopís TA06 Pro for a few races now. In the very beginning we received feedback that the car handles great, has good punch and acceleration, but driveline drag affects top speed. Others werenít fond of itís unconventional design.
Stich thanks for the race report! I found it compelling and encouraging as I am returning to TCS racing after over 7 years and was considering the TA06 Pro. Funny also that I was considering the Tekin Redline 17.5 also. LOL I will drop by to check out the TA06 Pro. I'll be needing the Tekin, esc, tires, body etc.
I am an old customer back when Steve ran Speedtech. I suddenly got the need to go racing again after not missing it bit. I'm just a little rusty.
See you soon.
Wayne
RC10B5, Tekno 410 sct, TA05 v2 Reedy 17.5, Revolt 30, Seaport Tug, Axial SCX10 Rubicon ess sound system.
FNG RIDER is offline   Reply With Quote
Old 02-11-2012, 10:02 AM   #1633
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Have you tested different distribution? I went from a center mounted esc to the stock location, just more towards the front. I need to find my scales and post pix. but im also running carbon and alum everything. I have ZERO play.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-11-2012, 10:08 PM   #1634
stitchy's Avatar
See you soon.
Wayne
Hi Wayne. You're welcome! I actually enjoyed writing it and trying to recall all of the happenings of the race. I usually forget the details as soon as I come off the driver's stand
Give us a call anytime at the shop (626.237.0807), especially if you're set on what car and components you want so we can have it all ready for ya!
Look forward to meeting an old customer of Steve's
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-11-2012, 10:21 PM   #1635
Hi all
atm im driving a moderatly hopped up TA05 ver2 is it worth staying with the ver.2 or change to a TA06, i've been reading previous posts here and all seems positive for the TA06
For the ppl who has driven both ta05 ver2 and ta06 is there a huge difference is it worth changing to 06 ??
Cos i really like the central battery/motor as i had a DF03ra and loved the handling on it
Using the car on asphalt track mainly open practise
alex_evo is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
