Peak Voltages: 5 cell and 6 cell
6 cells: 9,3-9,5v
5 cells: 7,7-7,9v
5 cells: 7,7-7,9v
I really don't go by what the charger has declared peak since it varies too much. I go by the "race" voltage which in many cases is between 1.39V to 1.44V per cell after disconnect from charger. So a good pack for me would have about 8.6V before I set it on the track. The charger peak value will always be higher since in order to charger a battery it needs to create a higher potential to push powre into the cells. The higher the charge rate in amps the higher the chargers peak voltage will be to create that push.
charging peak: 1.67 per cell
no-load peak: 1.38 per cell
so basically, this is 10.02v on the charger for a 6 cell pack, and 8.28v when measured with a voltmeter straight off the charger.
hope this helped
Joe
hope this helped
Joe
thanks again for the replies. what im doin is making some of my 6 cell packs 5 cell. just wanted to kno what to look for when i cycle the 5 cells. i just take out the cell that consistantly 'dumps' first on the DPD. mainly making some packs for pratice but i just incase they are good for racing i wanted to know what to look for.
