U.S. Vintage Trans-Am Racing
#9392
Then when you switch to the 25.5 you can just drop in 56P or 58P(if 58P will fit with a 100S) for a 3.8(56P) or 3.67(58P)FDR. Personally I am running a 96/53(3.86FDR) or 96/56(3.65FDR). With the 3.86FDR my motor temps are in the 125* range and around 135* with the 3.65FDR. I am thinking of going to 93/56 (3.54) or 93/58 (3.42) if the motor temps will stay below 160*.
#9393
According to the 2009 rules you will want to gear in the 5.4 - 5.7FDR range. A 64 pitch 100Spur / 41Pinion would be 5.2FDR and 100S / 37P would be 5.76FDR.
I want to Race 1 car in vta.and the other in touring car class with ru her tires but both. Will be complete with all hpi racing parts.
#9394
Pick up the HPI heavy duty ball cups or the RPM ball cups & replace ALL of the stock ones. Go with Robinson Racing for your spur & pinions. They are a couple dollars more, but I have yet to strip a gear.
#9395
My S2S came with the 15T Fireball so I had to switch them to brushless right away. So I have a 21.5 VTA and a 17.5 TC. I did mess around with the stock motor & ESC a few times. I did have a problem with the heat sink coming off the ESC during races.
#9397
I had a problem popping camber and steering links. The RPM cups are a tight fit so you will have to put them on and crush them a little with some pliers to get them to loosen up.
I am not running my s2s with swaybars. But Here is a link to some pictures of the swaybars installed on a s2s. http://www.drccentral.com/forums/ind...dpost&p=140386. This guy used Cyclone TC arms also.
#9399
A 27T motor with 2s LiPo should be at a STRONG advantage to cars running 25.5 and probably to cars running 21.5.
#9400
Be aware that the official rules have NEVER allowed a brushed motor of ANY wind with a LiPo. The battery spec for the brushed 27T motor was the 4-cell NiMH packs and there has never been an FDR limit. What you are looking at as the "2009 rules" are not rules (at least not as regards FDR and 27T / 4-cell systems) but a recommended range.
#9401
if you are coming this way...bring what you have and some pinion gears and we can get you on the right track for starters...you will need to upgrade to the 21.5 or 25.5 asap...but we ran 27t/lipos for awhile against the offical rules..and we have that "magic" FDR for you
#9402
Do u have a number I can call when u race at trinty lane??? Its been awhile, but I have seen the track there. Some guy names micheal Skeen runs the place I think??_
#9403
Hey guys just wondering what people are using for drag brake in VTA? It's been awhile and I don't have any expirence with the 25t. I'll be using an Tekin RS speedo with 208 profile? Thanks
Also what's the best spur and pinion for 5.0 in VTA? RW brand any good? 100t?
Thanks.
Thanks.
