Old 01-02-2008, 07:24 AM   #1
Default 4000maH non-trickle Charger
I am a newbie to proper RC. I decided to start off with a tt-01 i have all the equipment i need and i decided to buy a 4000mah battery cos the 1600 one that came with the car is a bit weedy. My only problem now is i cant find any details about the charger that came with it and i dont want to undercharge it. I decided that whilst i am looking i may as well get a faster charger too.
What i'm trying to find is a charger that can charge 4000mah quickly, but i don't want to spend any more than 30 but will pay more if necessary. I had a look at a range of chargers but not all were conclusive to a mah charging capacity and its tricky to find these specs. Another thing that i gt stuck at was the 1-2-4amp charge rates of others. Basically whatever you can do to help is appreciated.
EllTG is offline   Reply With Quote
Old 01-02-2008, 07:31 AM   #2
joe of loath's Avatar
so, you want to cahrge quickly. how quickly? a 1-2-4 amp charger can charge a 4000mah battery in an hour. i owuoldn;t suggest going above 5 amps, since it's probably a stick pack, and might blow up if you charge too fast. i suggest if you have a 12v power supply or car battery you get the ansmann X base
or if you don't, the slightly more expensive version that has a mains cable
and then you're sorted
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 01-02-2008, 08:36 AM   #3
Thanks for the quick response. I would buy that xbase deluxe but unfortunately it is on order..
Do you have any alternatives? I was looking at this but was unable to tell what type of connector i would need on the end were i to buy a 12v mains adaptor. Any clues?
Alternatively there is this if that would work then i would be sorted for both power sources.
Thanks again.
WTB: Lipo Charger, Power Supply if needed, Pack 4000maH and ^^ Associated-08 R/C Items: Wanted to Buy 2 03-04-2008 06:08 PM
Max amps 20,30,50c 5s and 4s 4000mah Fishmasterdan R/C Items: For Sale/Trade 1 10-07-2007 06:55 AM
what exactly is trickle ? thahookup Rookie Zone 10 05-15-2006 07:15 PM
trickle charger.... aquito Electric On-Road 6 05-09-2006 09:34 PM
TRICKLE charge tdragon Electric On-Road 2 05-18-2003 03:00 AM
SEO by vBSEO 3.5.0
