Which ESC
Which ESC
I need some opinions (pro and cons) and which one you would go with.
Novak GTX
Tekin FX Pro
Novak GTX
Tekin FX Pro
maybe the tekin but i havent run it
gtx no cuz i have been running it and i like the KO or hara better for brush.
but i run BL now and i love the 07 sphere. and you could use it for brush but it is a bit bigger,but it works grand.
I just got the novak XBR to get me started in the brushless. I am not one of those go out every weekend guys so it was goo to start with.
i know a guy that runs that and i think he runs brush right now
it works well little bigger but it works and as long as you have fun thats what counts.
and if you feel you can upgrade later
GTX's in all my sedans and XBR in my dirt stuff. I only am running BL in dirt at the moment. Mainly so I don't have anything to worry about such as motor building.
Do you know if KO ESC works with BL Motor.
Well i think i was converted. I tryed out my brushless system for the first time last night an it ran very good.
Might have to get a GTB or a Sphere
Thanks for your answser. By the way, which ESC should I get? I am new to electric. I am looking for a reasonable ESC. I am planing to run 14t - 19t motor on my 1/12 L4. I have done some research on the web and came up with couple of ESCs. KO, LRP IPC, or Novak Crawler. Thanks.
Don't rule out a brushless sytem either
The Brushless speedo all run brushed motor too and they are only a little more expensive than rehushed speedos. It a good investment in the future.
The LRP Sphere Comp 2007 is the easiest to fit in a 1/12th car. Don't get The LRP TC Spec. It has a hard wired fan that you have to cut off to fit under a 1/12th body and that no good.
The most advanced Brushless speedo is the New Speedpassion GT. It is just a bit bigger in length than the LRP but it does way more stuff than any LRP or Novak unit. It fits just fine in a 1/12th too.
What is the different between SPHERE COMP Digital. and SPHERE Brushless + Brushed DIGITAL. which one is better.
