Atlas blue can vs red can
Could someone please explain to me the difference between the Atlas-based blue and red can motors?
Thanks,
Kane
Thanks,
Kane
one is blue one is red
Kane...from my experience the blue can you would gear about the same or a tooth lower than the checkpoint 19. The red can motor seemed to be right between the Komodo and the checkpoint as far as torque/rpm goes.
The atlas motors both make good power....red can is just more rpm based than the blue can....I just tried to explain it through gearing as I race with Kane at some series races and knew that he would have ran the other motors that I had mentioned. One red can motor I have actually pulls over 12 amps at 2volts on my Muchmore Motormaster, makes big power on the dyno and pulls very hard on the track......I am always playing around and testing different combos....the Komodos when geared and tuned properly can make really good power aswell....they just seem to have a smaller gearing window to run the fastest. The hemi Chameleons have a little wider gearing window to be fast but still have a sweet spot. I find that the Atlas motors are a little harder to gear correctly because they seem to be relatively fast within a couple teeth. Still the motors to beat seem to be Trinity based. For a big flowing track go for the Komodo....for a smaller tighter track go for the Hemi C2's. For the Komodo gear around a 6.8-7.0fdr and the C2 hemi around 6.2-6.5fdr both with 58.5mm tires....always use lap times for the proper gearing as temp does not always tell you correct(max) gearing. Some motors like to run hot and some seem to run cooler.
the atlas red do seem to draw more amps and give a very good bottom end without compromising top end rpm as for comparing to a kd on the track they are not much diffrent but you have a little piece of mind as the kd are renouned for blowing up (epic quality).
My blue atlas that I bought 2 years ago is by far the fastest 19t I have ever owned/tested. Ran like this since the day I bout it
Thanks,
Kane
