Tekin R1 ESC
#46
We're being told just the opposite on the Sensored Motors...
We're hearing the R1 will NOT run the LOW RPM motors, and because of this they are in the midst of getting a RS version ready to market.
The RS from what I'm hearing WILL be a SENSORED ESC.
Image posted on HobbyTalk by Eric Salvas
#47
havent tekin contradicted itself a little i got the impression the r1 didn't need to be sensored becaue the technolgy inside for the senserless was second to none but now they are saying well actualy you do need to be sensored because it wont run low rpm very good. Am little confused! so its not as good as we all intialy thought.
#48
imo brushless is still very new technolgy for rc cars an idustry standrad would be a little detremental to the industry.
#49
#50
#52
#53
to be honest sensord or not this esc is still looking like the number one choise for me until mrt realese theier brushless cos it will be smaller and fully waterproof but until then defintly the one
#54
The RS is coming out only because the R1 has a problem starting up from a standstill on 4cell oval with the 13.5 motors. This is only due to the very high rollout they're using in that class (4in rollout, that is huge) which prevents a correct feedback to the speedo, especially to help it start.
There aren't issues in the other classes.
#55
#56
I'm a Tekin driver...
#58
#59
#60
what was posted about the Rollout / Motor issue was that the sensorless didn't like anything higher than a 1.5 rollout (Which is virtually EVERYTHING 4 cell expecpt MODIFIED or HOT MOTORS) and even the new LIPO based OVAL classes that are using the 17.5's and 21.5's have a higher rollout number than that...
I personally haven't tested these - the info I've seen and read comes from Team Drivers who did/have.
It has been said the sensorless versions are working great with the HOT MOTORS...
(If the Tekin responds anything like the CC Mamba Max system - IT had these same issues even in MOD off the line about 1/2 to 2/3rds the time. But Mambe had said their system would NOT support 4 cell racing when I spoke to them via email about the issue.)
