Xray FK 05
#16
A tight diff will push more then a loose diff. a loose diff will be more reative. But thats the extrems you should just be able to spin the wheel and it will keep spining after you spun it it wont spin for long but it should spin for a little bit of time. the droop is just some thing that every beginer will mess up on and it is easy to fix. good luck!
